General Forums
GK Performance (03+)
GK Appearance / Audio (03+)
RD Discussion (97-01)
Information
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
The Members Lounge
Regional
Latest Posts
My driver Door power window will work sometimes just fine and other times won't work and then if it isn't working if I hit the door just below the window switches it will work sometimes it takes 1 to 4 hits and it will work! It is only the driver Door window too! What do you think could be the...2 replies 51 views
Hello. I am getting engine code P0335 "Crankshaft position sensor 'A' Circuit malfunction". The car's engine cranks but won't start. New battery and put gas in the fuel tank. I've tried spraying with starter fluid in the air intake but did not start the engine. Does anyone know where is the...3 replies 108 views
4cyl FWD. Just over 130k on odometer, one owner. Commuter vehicle 35+ miles/day past 4 years - well cared for. Garage kept most of its life. Vehicle fed only Mobil1 synthetic oil every 3k miles, drank only top tier gasoline. Motor runs well and likely will for a long time. Body/chassis has rust...0 replies 46 views
So went to have my CEL codes scanned and these are the codes that were given to me. I’m pretty mechanically inclined, but just need a little help with where everything is and what each code means. Any advice and suggestions is greatly appreciated. TIA44 replies 509 views
Hey guys so yesterday when I was driving I realised when I upshift and put my foot back on the gas the revs go up for maybe a second and then slowly drop . I’m wondering if this is my clutch or could it possibly be something else ?10 replies 97 views
