As I said before, the idea is concept. Obviously, the acual product is not going to have rubberbands but rather an extension spring. There will be safties in place in the event that the spring fails. Though it is unlikely, if it does fail, there will be a screen to catch the valve. It's not going to be made of paper coffe filters and rubberbands. Those are there to demonstrate the mechanisim in action. I'm working on a design of what the product may look like. When I'm done I'll post it.
Quote:
Originally Posted by Bluerd2
My problem with bypass valves are, what is the point of having a cold are when air will be taken from the path with the least resistance, being the bypass valve. but that is just my view on bypass valves in general.
My suggestion would be build it with good materials, like some sort of spring maybe instead of a rubber band.
That path of least resistance will be the filter. Breechan pointed out that...
Quote:
Originally Posted by breeechan
the pressure in the intake piping will be essentially 1 atm. The pressure you want to determine is that in the pipe whilst the engine is trying to ingest water. You must find if this hydrolocking can occur from large amounts of water mingled with air, or by a column of water trying to move up the intake. In the latter case, you could say that the engine will soon deplete the air in the piping and cause a 0 vacuum condition which would draw the water up, as long as the intake piping is not 22 ft deep  . To be safe, you could find the spring that will open under 0.7 or so atm, of course finding a suitable value may require some trial and error.
...which is invaluable advise. There is a spring out there with the right tension that will keep the valve closed until water starts coming in. Perhaps the tension will have to be calibrated for each persons engine. Meaning that, if say I get a maximum vac. of 21 inHg when coming down from a high RPM, water starts making its way up the intake and the vacuum hits 24 inHg, I want to make sure that the bypass valve opens at 22 inHg and the water wont reach the TB.
Quote:
Originally Posted by Tweaked Tay
This is...in general...a BAD idea.
Good theory, and good try, but hit this too low quality to even hold together. Doesn't the pressure get quite high in a bypass valve?
Bypass valves are a bad idea or my design is a bad idea? What pressure? The BP valves are designed to open under vacuum....
