Official DYNO graph thread - Page 2 - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#26
bluegtv6
NewTiburon.com God
bluegtv6 is offline
Sex: Male
bluegtv6 is just really nicebluegtv6 is just really nicebluegtv6 is just really nice
Old Re: Official DYNO graph thread 04-08-2007 , 04:07 PM
2003 V6, 6 speed.
Engine Mods:
-AEM CAI
-Borla exhaust
-Hotshot headers w/ high flow cat
-NGM stage 4 upper/lower IM
-Crower cams
-Tigerlily 60mm TB
-Real ECU ( 91 octane tune )
-MAFterburner
-Magnecore plug wires
-Fidanza Flywheel
-Centerforce Dual Friction clutch
-NGM poly motor mounts
-Phantom Grip LSD insert
** 4th gear pull **
2003 GTV6 6-speed
Sponsored Links
Advertisement
#27
98tib
NewTiburon.com God
98tib is offline
98tib's Avatar
Sex: Male
98tib will become famous soon enough
Old Re: Official DYNO graph thread 04-17-2007 , 12:12 PM
2005 v6 manual - 3rd gear pull - uncorrected #'s
Performance / Engine Work:
Mafterburner
Oil Catch Can
Cold Air Intake – Powder Coated Silver
Iridium IX plugs
Nology Cool Wires
SSAutochrome Headers
Kartboy Shifter Bushings
Customized Crower Cams
SFR Overdrive Alt. Pulley
Nick Boers Underdrive pulley
RIPP Front & Rear Solid Motor Mounts
Ebay Greddy Cat-Back with Hi-Flow Cat
NGM Stage IV Upper & Lower IM – Silver
Weapon R Engine Damper
PART OUT :
#28
earlmred
NewTiburon.com Professional
earlmred is offline
earlmred's Avatar
Sex: Male
earlmred will become famous soon enough
Old Re: Official DYNO graph thread 05-08-2007 , 10:02 AM
2006 SE V6 6speed
AOS CAI, KORE Exhaust, SSA Headers, NGM STG4 Intake Manifold
4th gear pull, untuned
2006 Tiburon SE V6
Obsidian Black
Duffer Turbo, Sirius, BassTib STS, Tuscani Rebadge, Eibach Pro-Kit Springs, KORE Exhaust. RRM Front/Rear Strut Bars, System Upgrade Center Bar, System Upgrade Shift Knob, Progress Rear Sway Bar, NGM STGIV Intake Manifold, Mafterburner, NGM solid billet motor mounts, Fidanza Flywheel, Clutchmasters Stage 4 6 Puck Unsprung Clutch, KJB Delrin Shifter Bushings, KJB Shifter Base Bushings, 65mm Throttle Body, AEM TruBoost/UEGO/Oil Pressure Gauges
#29
Karma
NewTiburon.com God
Karma is offline
Sex: Male
Karma will become famous soon enough
Old Re: Official DYNO graph thread 05-29-2007 , 06:50 PM
heres my new dyno , with aem cai , ark single , third cat punched out on 93 octaine ( just to prove that it doesnt make less power on 93 , in fact i think it makes more ) next dyno will show what cams will add to the powerband ...........
#30
earlmred
earlmred is offline
earlmred's Avatar
Sex: Male
Old Re: Official DYNO graph thread 07-02-2007 , 08:08 PM
2006 SE V6 6speed
AOS CAI, KORE Exhaust, SSA Headers, NGM STG4 Intake Manifold, mafterburner
4th gear pull, tuned
2006 Tiburon SE V6
Obsidian Black
#31
HokieTib
NewTiburon.com God
HokieTib is offline
HokieTib's Avatar
Sex: Male
HokieTib will become famous soon enough
Old Re: Official DYNO graph thread 07-07-2007 , 05:15 PM
Outside temp was low 90s, not sure what it was inside, but it was definitely HOT and humid!!! All my mods are listed below in my sig (I/H/E/T)
And the tib is gone...
#32
GTSTISL
NewTiburon.com Novice
GTSTISL is offline
GTSTISL's Avatar
Sex: Male
GTSTISL has a little shameless behaviour in the past
Old Re: Official DYNO graph thread 10-16-2007 , 07:38 PM
This is NOT my dyno. It's from www.Injen.com. '06 V6 6sp. w/ the new Injen SRI with MR technology. Pretty good numbers considering it's only a SRI. 6hp 2ft. lbs
#33
187sks
187sks is offline
187sks's Avatar
Sex: Male
187sks
Old Re: Official DYNO graph thread 10-22-2007 , 08:35 PM
2005 Tiburon SE V6 6 speed - bone stock baseline. Hope to update with modded dyno chart later.
161hp 169lb/ft tq.
#34
kartunez
NewTiburon.com God
kartunez is offline
kartunez's Avatar
Sex: Male
kartunez is an unknown quantity at this point
Old Re: Official DYNO graph thread 10-30-2007 , 11:35 AM
Here is mine:
AEM CAI
Tiger Lily BBTB
Nology Hot wires
NGK Iridum plugs
DC Sports headers w/ Magnaflow Hi-flow cat
ARK N2 Dual Exhaust
Results: 177.6 WHP / 198.6 FT-LBS
2003 Silver GT - 177.5 WHP/198.6 FT-LBS - Member of
Looks: 18" TSW Nogaro's w/ Proxes 4's, F/L front with M&S lip, GT Tech Type II sides, AITRacing rear, Seibon SC CF hood...
Power: AEM CAI, Tigerlily BBTB, NGM Upper and Lower stage IV manifolds, Nology Hotwires, NGK Iridiums plugs, nul7 lightweight crank pulley, DC Sports headers w/ Magnaflow Highflow cat, ARK N2 Dual...
#35
andbudzi
NewTiburon.com God
andbudzi is offline
andbudzi's Avatar
Sex: Male
andbudzi has a spectacular aura aboutandbudzi has a spectacular aura aboutandbudzi has a spectacular aura about
Old Re: Official DYNO graph thread 11-16-2007 , 10:47 AM
I/H/E/Mafterburner/ Stage3 IM (U/L) ... 4rth gear pull.... i dont think that i tuned my a/f ratio that good
03 GT 6spd. t3/t4+:
CAI, SSA H/E, Stg3 Lower & Upper IM, 60mm TB, Mafterburner, Cams, Stg.3 SB clutch, Spec Flywheel, spacer, Eibach rear sway bar, strut bar, motor mounts, Megan Racing springs, EBC brakes.
06 RX8 Shinka 6sd.
"A wise man once told me, racing a honda is like being in the special olympics... you may win but you're still a retard."
#36
solracarevir
NewTiburon.com Expert
solracarevir is offline
solracarevir's Avatar
Sex: Male
solracarevir
Old Re: Official DYNO graph thread 01-06-2008 , 03:37 PM
Here are my runs, done on 3rd Gear only Intake and exhaust. 83 octane fuel
STD Corrected
Uncorrected
SAE
Quote:
Originally Posted by ME!
Where you find all those nice emo girls? all I can found are MILFS and whores online...
Monopoly Racing team
Tuned By Trampas
#37
SIX_SEVEN_ONE
NewTiburon.com God
SIX_SEVEN_ONE is offline
SIX_SEVEN_ONE's Avatar
Sex: Male
SIX_SEVEN_ONE
Old Re: Official DYNO graph thread 01-07-2008 , 12:43 PM
Here's a dyno graph of my run...I don't know why the shop onlu sent this one..It doesn't even show my TQ..??
It's alright they did a good job
Silver Turboed SE V6
#38
peterx84
peterx84 is offline
peterx84's Avatar
Sex: Male
peterx84 is an unknown quantity at this point
Old Re: Official DYNO graph thread 01-11-2008 , 10:32 AM
TIB...04 V6 . 5SPD....
MODS.
INTAKE:
HEADERS
FULL EXHAUST (STRAIGHT 2.5 PIPE FROM HEADER TO A DYNOMAX 2.5 EXHAUST)
FPR
MY FPR WASNT WORKING RIGHT BUT...APEX COMING IN THIS WEEK AND A NEW FPR + LIGHTWEIGHT PULLEY...SO NEW NUMBER SOON
Boosted V6...SOON...*THANK GOD FOR ANOTHER DAY*
#39
AF tib
AF tib is offline
AF tib's Avatar
Sex: Male
AF tib is an unknown quantity at this point
Old Re: Official DYNO graph thread 01-11-2008 , 05:55 PM
i did mine on a Mustang DYNO (which i was told was the closest to the real number)
my mods: AEM CAI, ARK headers & cat back system, ARK Pulleys, motor mounts, UNTUNED.
i got 180 WHP, i'm about to get my SAFC2 hooked up and tuned and re-dyno'd, i'll let you guys know the numbers.
#40
Stoeff.at
NewTiburon.com God
Stoeff.at is offline
Stoeff.at's Avatar
Sex: Male
Stoeff.at has a little shameless behaviour in the past
Old Re: Official DYNO graph thread 03-05-2008 , 08:28 AM
As I am putting on headers, racecat and exhaust in a few weeks, i went to the dyno (BOSCH) to see a before/after effect.
Mods: AEM CAI, custom BBTB, stock: 123 KW = 167 HP
1st run: 127,7 KW = 173,6 HP
Wheel HP: 106,5 WKW = 144,8 WHP
2nd run: 128,9 KW = 175,3 HP
unfortunately no WHP here.
#41
groundshark
NewTiburon.com Rookie
groundshark is offline
groundshark's Avatar
Sex: Male
groundshark is an unknown quantity at this point
Old Re: Official DYNO graph thread 04-09-2008 , 08:47 PM
Mod's in Sig.
Name:  dyno results Andre.jpg
175.50 max pwr-177.71 max torque
4th gear pull
___________________________________________________
Aaahhhhhh Booost Alpine Stage II Supercharged
WHAT DO YOU MEAN THIS SHARK CAN'T SWIM
253 WHP 'N RISING
R.I.P '04 Tuscani April'05 to May '09 (sexiest car ever)
Risen from the Flames '04 STi 420 AWHP/ 420 AWTQ @ 22psi and rising!! chasing 11.0 almost there booooosted.....on street tires lol
brake boosting is like CRACK psssssst
#42
187sks
187sks is offline
187sks's Avatar
Sex: Male
187sks
Old Re: Official DYNO graph thread 11-25-2008 , 11:23 PM
Baseline was 161hp, 169lb/ft when stock. (also posted above)
New numbers 193hp, 206lb/ft.
Conditions similar, probably in the 50's and fairly high humidity. Baseline was done on a Mustang Dyno and the new run was on a Dyno Dynamics so it's far from apples to apples unfortunately.
Mods: Fujita CAI, SSA catback, Royal Purple Synthetic oil.
#43
Blackbird
Blackbird is offline
Blackbird's Avatar
Sex: Male
Blackbird
Old Re: Official DYNO graph thread 02-07-2009 , 06:51 PM
Mods:
Injen CAI
SSA Headers
Tsudo Dual Exhaust
Magnaflow Catalytic Converter
91+ Octane
I'm a little disappointed in the HP....I guess I just expected more....might give the Tiburon to the wife and buy a Subaru.....or a Toyota......
Black Guy + 08' Tiburon GT LTD = KDM Sexiness ^_^
Black Guy - 08' Tiburon GT LTD = Altima Desert Boots
Black Guy - 98' Mustang GT = "Found On Road Dead...."
#44
coupetuner
coupetuner is offline
coupetuner's Avatar
Sex: Male
coupetuner
Old Re: Official DYNO graph thread 02-12-2009 , 06:24 AM
Here`s the numbers of my tiburon V6
modifications are
ssa v2 headers
ssa exhaust
aem short ram intake
upsolute remapped ecu
selfmade adjustable cam gears
218bhp/ 290nm BOSCH Dyno 4th gear pull
http://www.hyundaiclubfinland.com/fo...0.0;attach=195
#45
ceploosh
ceploosh is offline
Sex: Male
ceploosh will become famous soon enough
Old Re: Official DYNO graph thread 03-05-2009 , 04:20 PM
I just got my dyno done this morning, have to figure out how to post the picture of the dyno sheet, mods are in signature plus Mafterburner
183 hp/185 tq
2004 Tidal Wave Blue GT V6
Injen SRI
Ark Dual N2 Exhaust
SSA headers
#46
ceploosh
ceploosh is offline
Sex: Male
Old Re: Official DYNO graph thread 03-05-2009 , 04:58 PM
Injen SRI
Ark Dual N2 Exhaust
SSA headers
#47
YoungTibV6GT
YoungTibV6GT is offline
YoungTibV6GT's Avatar
Sex: Male
YoungTibV6GT is an unknown quantity at this point
Old Re: Official DYNO graph thread 03-09-2009 , 04:33 PM
Just had my Car Dynoed this weekend at a local Community College. Had some trouble setting me up, but finally got the Mustang Dyno to read after 20-30mins. It seems to me that the numbers are sort of low because 1) It's a Mustang Dyno 2) They had a lot of trouble setting up the reading for my car
Car: 2004 Tiburon, 2.7L V6, 6-Speed Tranny
Performance Mods (in sig): SSA headers (came with car), SSA catback, AEM CAI (w/ K&N Filter), 61mm BBTB, Stage IV Upper IM, NGK plugs, Magstar wires.
Results: MAX: 168 ft-LB Torque. 171 WHP. *Note*This was a 4th Gear Pull (I wanted to try 3rd, but they recommended 4th).
**Edit**
Found my previous Dyno Graph from last time I ran on the Mustang Dyno (will post once scanned). It appears I got a whole 2whp extra from a Stage IV IM, BBTB, and Plugs + Wires and lost 6 ft-LB Tourge. My results from this weekend must be wrong....
Results: MAX: 174 ft-LB Torque. 169 WHP.
Performance: SSA Headers, SSA exhaust, AEM Style CAI w/ K&N Filter, Stage IV IM, Magstar wires, NGK Iradium plugs, Ark RSB, RRM FSB, and 61mm R-Side BBTB.
Visuals: Emblems, Door Inserts,Shorty Antenna,Black rims, Pioneer Deck, Ark STS, Redlinegoods boot & arm rest, Chrome pieces, clear corners, 10K Korzen HID Kit, Multi-gauges, Cup holder, Katzkin leather seat and heated seat kit. iPod dock in ash tray too
#48
2005GWT
2005GWT is offline
2005GWT's Avatar
Sex: Male
2005GWT is an unknown quantity at this point
Old Re: Official DYNO graph thread 05-24-2009 , 06:59 PM
Injen SRI. That's it.
2005 GT, manual.
166whp, 174tq
// Injen SRI // SFR STS // ARK Shorty Antenna // Subwoofer Mod
#49
Smok3F0X
NewTiburon.com God
Smok3F0X is offline
Smok3F0X's Avatar
Sex: Male
Smok3F0X will become famous soon enough
Old Re: Official DYNO graph thread 09-08-2009 , 09:41 PM
Made 202.5 fwhp and 198 f/lbs of torque go me mods
DC Sports Headers
Greddy Evo 2 exhaust
light weight pullies
Injen CAI
BBTB
tuned with Neo and Innovate wideband
Sorry bad iPhone pics oh well you get the idea!
AWD mustang dyno btw.
Just in case ppl wanted to call BS ImportsNC.com is where I moderate the KDM section and where Robbie Epic Motorsports' tuner posted my numbers so enjoy!
#50
tibbyGTT
tibbyGTT is offline
tibbyGTT's Avatar
Sex: Male
tibbyGTT
Old Re: Official DYNO graph thread 09-30-2009 , 06:04 PM
here is the dyno sheet for my car on 1.5 psi (my bov had a bad leak in it)
garrett 60 trim
tial 38mm wg
NGR type S
full exhaust
map ecu
electronic boost controller
air tep was 95
i will post up video's later i am too lazy right now to do it
The first turbo'd F/L tiburon in utah---- **SOLD**
Mazdaspeed3, 348hp 427tq on E85, 440hp/410tq on 91- hx35
Mazda's blown, epic rebuild coming
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
