DIY: __*** BCM Turn Signal Fix ***__ - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > Information > Do It Yourself > DIY Lighting
User Tag List
Reply
Thread Tools Display Modes
#1
optimummind
Coegi vos via~
optimummind is offline
optimummind's Avatar
Sex: Male
optimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another leveloptimummind is on another level
Old __*** BCM Turn Signal Fix ***__ 04-20-2007 , 07:53 AM
Here is my version of the BCM turn-signal relay replacement DIY. More info, more pics, more powah!!
**Who needs this DIY?**
For those people who are having erratic problems with their turn-signals--whether it be the left blinkers, right blinkers, or both.
Some symptoms you might experience that indicate a problem with the BCM turn-signal relay:
(1) When you use your right blinkers, the blinkers get stuck to the "On" position and doesn't blink.
(2) When you use your left blinkers, the blinkers get stuck to the "On" position and doesn't blink.
(3) When using your blinkers, your blinkers' clicking rate starts off normally then begins to blink faster and you've already tried installing new turn-signal light bulbs.
(4) Your blinker--left or right--blinks faster than the OEM rate. This can happen either all the time or sporadically.
(5) When you lock down your car with your keyless remote, the turn signal lights blink once then DON'T turn off but remains stuck on. This may occur every time or once in a while.
(6) The blinker's clicking sound level, on one side only or both sides, has become quieter than the OEM sound level.
**What you can do about this problem.**
(1) Go to the dealer/junkyard and buy a new BCM module. At the dealer, the price range seems to be between $750 to $1300. Buying a used BCM module from the junkyard, obviously, will be cheaper if you can find one in good condition. With a junkyard, though, it's a hit-or-miss.
When you install a BCM, you'll have to have the dealer reprogram your keyless remote/alarm to the new BCM. This service costs ~$50.00.
At my Hyundai dealer where I have a hook-up with the parts manager, I was quoted $540 flat for the BCM module. So if there is anyone who doesn't want to go through the trouble of doing the DIY but want to buy a brand-new BCM module for a good price, PM me/contact me and I'll hook you up.
(2) Do the DIY outlined below. It is a pain in the butt and it's really awkward taking out the BCM module, but it's well worth it since you save HUNDREDS of dollars.
**DIY Parts Needed**
(1) Screwdriver
(2) 10-mm socket & ratchet
(3) Pliers (optional. It will help to have a plier if you run into some stubborn connectors that won't come loose easily. I had to use the plier for one of the BCM connectors).
(4) If you decide to desolder the old relay yourself and solder in the new one, then you'll need a soldering iron and/or a desoldering iron, desoldering bulb and/or braid, and solder.
If you DON'T want to do the soldering work yourself, like me, then you can just take off the BCM module from your car and take it to a professional for the installation of the relay. In my case, I went to a local mom-and-pop TV/radio repair shop and got the relay soldered on for only $10.00 flat. During one of my price-quote hunting sprees, I got a quote from a speaker shop and they wanted $75.00!! Rip-off!!
(5) Replacement BCM turn-signal relay. You can buy one from Mouser electronics. It's only like ~$3.50. The item number is: NEC EP2-3N1ST. Here is a couple picture of the relay.
And here is the link to Mouser's site where you can order the replacement relay:
http://www.mouser.com/search/Refine....1ST+&N=1323038
**Installation Steps**
[1] Disconnect your negative battery terminal. 10-mm wrench is used.
[2] Pull out the plastic fuse cover.
[3] Remove the two screws that hold down the plastic cover underneath the steering wheel then pull off the cover.
With the cover off, it will look like this:
[4] Remove the three 10-mm bolts and one 10-mm nut that holds down the metal knee protection brace.
With knee brace off, it will look like this.
[5] Now, take off all six connectors on the front of the BCM box.
Once all off, it will look like this.
[6] Now, take off the 2 10-mm bolts and 1 screw that hold down the BCM box as indicated in the picture below.
[7] The BCM box is now loose but it won't come off yet because some connectors behind the BCM box is still holding on to it. To reach those connectors, you first slide out the BCM box by moving/maneuvering the BCM box around until you slide it off the two slots as indicated in the picture below.
[8] Once you got the BCM box free from its slots and you have pulled it out, now you can get to removing the 6 connectors on the back of the BCM box.
[9] Once all the connectors on the front and back of the BCM box has been pulled out, the BCM box is now free from the car. The next step is to pull out all the fuses on the front of the BCM box as well as all the relays on the back of the BCM box.
Here are all the fuses that you need to take off on the front of the BCM box.
Here are all the relays that you need to take off on the backside of the BCM box.
[10] With all the fuses and relays pulled off the BCM box, you can now pry the lid open by undoing the clips that hold the BCM box together.
[11] Here is a picture of the BCM box open with the turn-signal relay marked for you. If you want to desolder out the relay yourself, then you'll have to pull out the PCB, turn it over, then desolder the joints behind the turn-signal relay. After that, you plug in the new replacement relay and solder the joints for a tight connection.
In my case, I decided to have a professional solder in my new replacement relay. He charged me $10.00 flat but I ended up giving him a $5.00 tip for a job well-done.
Here is a picture of my BCM PCB with the new relay installed.
[12] Now, you just have to put everything back in reverse order. Thankfully, putting the BCM box back in its place is much easier and less time-consuming than taking it out. At least, that was how it was for me as a couple of connectors on the BCM box were really, really stubborn and wouldn't pull out unless I used a plier and a large flat-tip screwdriver. My finger tips were KILLING me from pulling out all those connectors.
[13] With the BCM box, all of its connectors, knee brace, plastic trim, and fuse cover all neatly placed back, reconnect your negative battery terminal and start up your engine.
If this relay replacement fixed your turn-signal-related ailments, then AWESOME!! You just saved hundreds of dollars!!
If you're still having turn-signal-related problems, then you just might have to buy a BCM module.
Good luck!!!
=멤버프로파일:
=Album:
Sponsored Links
Advertisement
#2
tib on konigs
NewTiburon.com Novice
tib on konigs is offline
tib on konigs's Avatar
Sex: Male
tib on konigs is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 04-20-2007 , 07:55 AM
whats this diy supposed to do?
#3
bms231
Former CIO
bms231 is offline
bms231's Avatar
Sex: Male
bms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another level
Old Re: DIY: BCM Turn Signal Fix 04-20-2007 , 07:58 AM
Quote:
if ur turn signal is frozen on, this is the fix w/o having to pay for a new bcm.
I am no longer an admin. Please do not PM me with site issues. Use the report post button.
#4
slow 2K2GT
NewTiburon.com God
slow 2K2GT is offline
slow 2K2GT's Avatar
Sex: Male
slow 2K2GT is just really niceslow 2K2GT is just really niceslow 2K2GT is just really niceslow 2K2GT is just really nice
Old Re: DIY: BCM Turn Signal Fix 04-20-2007 , 08:34 AM
Thanks for doing that I have been turning right for the last week and a half.
#5
rlaxogus
rlaxogus is offline
rlaxogus's Avatar
Sex: Male
rlaxogus has a little shameless behaviour in the past
Old Re: DIY: BCM Turn Signal Fix 04-21-2007 , 03:02 PM
woot!! thx bro!
saved me $550!!
cost me 50bux for tools and relay
now just to wait for the 26th to come around << when i'll recieve the relay
so i can try this myself! yay thanks again
Why i have a Tiburon...
R.I.P. 00 Elantra
#6
rlaxogus
rlaxogus is offline
rlaxogus's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 04-21-2007 , 03:04 PM
Quote:
hahaha
mine is left too - is it commonly left for everyone else too i wonder?
hope this issue is better on the 05+ but i guess it hasn't been out long enough to get bugged yet huh~
R.I.P. 00 Elantra
#7
Tibzie
NewTiburon.com God
Tibzie is offline
Tibzie's Avatar
Sex: Male
Tibzie
Old Re: DIY: BCM Turn Signal Fix 04-28-2007 , 08:33 PM
Quote:
Originally Posted by bms231 View Post
no problem. like my user title says, i am here to help. even if that means staying up super late to get things done. i am going to have this in PDF as well. i gotta run to work now though. it will be up later tonight.
When I first bought my car, they detailed everything for me and had it ready, when I arrive and they start it. the signal light was doing just as such. They had to order a new BCM and installed it (warranty). I went a few days w/ no signal lights cause I opted to still take the car that day.\
Anybody know what exactly causes this problem ?
08' Civic SI Sedan | i-VTEC | 6 Speed | STS | CF Hood | TB Spacer | P2R Thermal Gaskets | Spoon Catback System | Megan Racing H Brace | M.R. F & R Tie bars | Eibach Lowering Prokit | Mugen Visors | Retrofit 5000k HID | 3000k Fogs/Highbeam |
#8
rlaxogus
rlaxogus is offline
rlaxogus's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 04-29-2007 , 02:03 AM
apparently its the rel2 of the bcm...
R.I.P. 00 Elantra
#9
Vic
NewTiburon.com Newbie
Vic is offline
Vic's Avatar
Sex: Male
Vic is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 09-15-2007 , 04:15 AM
THANK YOU! You saved me heaps of money. My turn signal is working 100% and I can start turning right again. Getting the relay to South Africa was quite a mission but I received great service from the people at Mouser.
Desoldering should best be left to a pro. After hours of frustration an only 4 of the 10 pins desoldered I asked a local tv repair man to take a look and he had the faulty relay removed and the new one fitted in less than 10 minutes. Asked me next to nothing to do the job.
BTW
There are two more Identical relays on the pc board. Do you guys know what they are supposed to do?
VBR
VIc
#10
2fives
NewTiburon.com Professional
2fives is offline
2fives's Avatar
Sex: Male
2fives is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 10-03-2007 , 06:33 PM
So you can't just order a new flasher from Hyundai?? and it's soldered to the friggen circuit board, not just plugged in so this isn't really a user serviceable part??
Mine just started sticking in left turn today.
#11
bms231
Former CIO
bms231 is offline
bms231's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-03-2007 , 07:14 PM
it isnt the turn signal that is the problem... it is the relay on the bcm that controls the turn signal
#12
NovaResource
NovaResource is offline
NovaResource's Avatar
Sex: Male
NovaResource will become famous soon enough
Old Re: DIY: BCM Turn Signal Fix 10-03-2007 , 07:19 PM
Unfortunately, no, you can't just change it. However, if the car is still under warranty, the BCM will be replaced for free. Mine went about a month ago and I didn't pay a cent to the dealer to fit it. Took them about an hour. Just be sure to bring both keyless entry remotes because they will have to reprogram them to the new BCM and you need both with you to program both.
#13
jsdragonsoul333
NewTiburon.com Post Master
jsdragonsoul333 is offline
jsdragonsoul333's Avatar
Sex: Male
jsdragonsoul333 has a spectacular aura aboutjsdragonsoul333 has a spectacular aura about
Old Re: DIY: BCM Turn Signal Fix 10-03-2007 , 08:12 PM
Quote:
So do our cars have a changeable flasher too? Or is this it?
:Moonlit blue 2006 SE
Quote:
"Some men aren't looking for anything logical. They can't be bought, bullied, reasoned or negotiated with. Some men just want to watch the world burn. "
#14
2fives
2fives is offline
2fives's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-04-2007 , 01:13 AM
If you just do this mod there will be no need to do any reprogramming??
I just ordered mine ($4) after inquiring at my dealer how much a new BCM would be. About $760.
#15
TIB16
NewTiburon.com Rookie
TIB16 is offline
TIB16's Avatar
Sex: Male
TIB16 is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 10-04-2007 , 04:48 AM
i did mine and no reprogramming was needed!
anyway,i tried and repaired the oem relay,because the new one would'nt come here before a month passed from the order. so i said why not .i cut the case of it open and i cleaned the inner contacts with a razor blade.(it had something beetween the contacts that forced them to remain closed so the current would go through all the time).then i checked that they work properly,i glued the case back and put everything together.i got the new relay now,but i am not changing it cause the repaired one still works fine.(3 months now)!!!!
#16
NovaResource
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-04-2007 , 07:58 AM
Quote:
No, the flasher is soldered to the board. The only way to change it is to replace the whole BCM or re solder the flasher.
#17
NovaResource
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-04-2007 , 08:01 AM
There is no reason to do this mod if your car is still under warranty. The delership will replace the entire BCM for FREE. The only reason to do this mod is if the warranty has expired.
#18
2fives
2fives is offline
2fives's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-14-2007 , 03:03 PM
I just wanted to to touch on one more thing. I did mine last night and....
1) it worked!!
2)Getting the old one un-soldered from the board was a friggen SOB, took me about 1.5 hrs. You have to be super, super, super careful. You pull to hard on the relay because your impatient and pull some trace of the PCB you might be screwed. I went very careful and used some solder wik and rosin-flux and got the solder completely out of the holes so it would pull off the board easy. Well as good as I could.
3) the part numbers on the old relay don't match the new relay. Don't wory it still works, just an updated part number. The old relay is EP2-3L1T, the new one is EP2-3N1ST.
#19
TIB16
TIB16 is offline
TIB16's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 10-15-2007 , 03:54 AM
1) it worked!!
i used a de-soldering station i have in my company and it took me 2 min.(i am an electrical engineer)if you have the tools its easy.if you don't it can be a disaster.but you can always take the PCB to a pro to do it for you instead anyway,good job man.(aint that feeling you made it great? )
#20
WalaWalah
WalaWalah is offline
Sex: Male
WalaWalah is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 01-17-2008 , 08:03 AM
Thanks guys .... i got the same problem i tried and it works.
#21
Vic
Vic is offline
Vic's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 01-20-2008 , 02:32 PM
This is four months after I did the DIY and it's still working!
Must be one of the most usefull DIY's on this forum
Thanks again!
VBR
Vic
#22
takashi
takashi is offline
Sex: Male
takashi is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 02-08-2008 , 11:02 PM
So after about 3.5 hours of messing with this thing, I have just about as much solder removed as I possibly can and this stupid relay still won't detach itself from my over-priced circuit board. I have decided I am doing something wrong and am giving up for now, until I can seek professional help...DOH!
#23
ozkrow
NewTiburon.com God
ozkrow is offline
ozkrow's Avatar
Sex: Male
ozkrow is an unknown quantity at this point
Old Re: DIY: BCM Turn Signal Fix 02-10-2008 , 10:20 PM
Thanks again!
VBR
Vic
GLAD this diy is still helping people...you have to work the relay out. move it side to side with the soldering iron on the solder and it should work its way out. you have to keep the solder hot. if you dont it will harden up and keep the relay stuck to the board.
#24
takashi
takashi is offline
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 02-13-2008 , 10:36 AM
This DIY is pretty amazing and has probably saved several thousands of dollars by now. After finishing (finally), my right turn signal is now unfrozen and works again...my left blinker, however, does not. It doesn't do anything, not even the indicator on the gauge panel works. I seem to be an expert at breaking one thing while fixing another. Any ideas of what I may have broken? Thanks all.
#25
TIB16
TIB16 is offline
TIB16's Avatar
Sex: Male
Old Re: DIY: BCM Turn Signal Fix 02-15-2008 , 02:12 AM
did you mess a lot with the old relay to take it off?cause you might made a damage to the pcb...if not,and hopefully you solder the new one ok,check that you 've putted everything back and also all the plugs on the bcm...good luck!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
