Removing the front bumper - how to? - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > General Forums > Car Care
User Tag List
Reply
Thread Tools Display Modes
#1
croat
Banned Forever
croat is offline
croat's Avatar
Sex: Male
croat croat croat croat croat croat croat croat croat croat croat
Old Removing the front bumper - how to? 05-19-2007 , 08:00 AM
I need to remove the front bumper in order to have it painted. Anyone have a how to as I would prefer to not purchase the manual to do this. Thanks,
Sponsored Links
Advertisement
#2
The Power of Dreams
NewTiburon.com Post Master
The Power of Dreams is offline
The Power of Dreams's Avatar
Sex: Male
The Power of Dreams will become famous soon enough
Old Re: Removing the front bumper - how to? 05-19-2007 , 04:06 PM
Yeah, it's very simple. Just a matter of removing bolts. Set things aside after removing them. Bag the bolts/ screws with a paper identifying where they belong. Organization is important.
1. Using a Philips screwdriver, remove the two plastic bolts and plastic retainer on EACH side which hold the plastic fenderwell to the front bumper.
2. Remove the black plastic radiator cover. If I remember correctly, there are four metal screws and one plastic bolt/ retainer. They are all directly visible from the front.
3. Take off both your headlights completely, 3 metal bolts on each side.
4. Now that you have your headlights off, you will find a 10mm bolt in the corner where the front bumper meets the fender. Remove the bolt from the top (only way to remove it).
5. Now, look underneath the front bumper. You will see a plastic cover near the bottom of the radiator and the front bumper. It's held on by five or six 10mm metal bolts. Remove and set aside.
6. From the same position, look straight up and you will see TWO plastic bolts/ retainers closest to the side vents in the front bumper. You'll need a long Philips to get them. They're in a rather precarious angle up in there.
7. Once you have those two plastic bolts/ retainers out, stand up and look straight down on your front bumper where it meets the bumper. There are probably two or three plastic bolts/ retainers holding it on. Remove those.
8. At this point, you should have all the bolts and screws. All that is holding it on is a small dowel on the metal bracket on each side. Give it a firm tug on each side.
I might have missed one, but that's it. All you need to do is go around the perimeter and search for the bolts/ screws. There's no special process or anything technical about it.
HONDA: The Power of Dreams
2008 Honda Civic Si Taffeta White Sedan
#3
croat
Banned Forever
croat is offline
croat's Avatar
Sex: Male
Old Re: Removing the front bumper - how to? 05-19-2007 , 10:37 PM
What about the foglights
#4
The Power of Dreams
Sex: Male
Old Re: Removing the front bumper - how to? 05-20-2007 , 12:13 AM
Quote:
Detach the 9006 male connector from OEM harness from the foglight bulb. The foglight housing will be attached to the front bumper when you remove it.It's held onto the bumper by three screws. Remove screws. Done.
#5
M4st3rM1nD
NewTiburon.com Professional
M4st3rM1nD is offline
M4st3rM1nD's Avatar
Sex: Male
M4st3rM1nD
Old Re: Removing the front bumper - how to? 05-20-2007 , 12:22 AM
eeaaassiest way is the way i did it... put it into a guard rail at 90mph... comes right off :-p
2005 Tibby GT 5 Speed - I/H/E - Exedy Stage 2 Clutch and Light Weight Flywheel - Drilled/Slotted Rotors - Painted Red Calipers - 15% Tint - Painted Black Wheels
1999 Audi A4 1.8t 5 Speed - 3 Angle Valves, Ported Heads, High Flow Oil Pump, Kevlar Timing Belt, Stage 2 Clutch w/ Lightweight Flywheel, Full custom exhaust, FMIC, HKS BOV, GIAC Chipped, Custom PSI Gauge
MASTER AT ARMS, MARINE CORP SECURITY FORCE BATTALION BRAVO 3RD/BRAVO USN
#6
The Power of Dreams
Sex: Male
Old Re: Removing the front bumper - how to? 05-20-2007 , 12:30 AM
Quote:
Right, right...no doubt.
Just be careful if you do it that way. Don't hit any midgets in the process.
#7
jayman089
NewTiburon.com God
jayman089 is offline
jayman089's Avatar
Sex: Male
jayman089 will become famous soon enough
Old Re: Removing the front bumper - how to? 05-20-2007 , 01:26 AM
midgets huh?? why you gotta pick on the vertically challenged people?? lol
#8
RedBaron
NewTiburon.com Novice
RedBaron is offline
RedBaron's Avatar
Sex: Male
RedBaron is an unknown quantity at this point
Old Re: Removing the front bumper - how to? 05-20-2007 , 01:41 AM
ah! forget the vertically challenged people. It is those road turtles you have to watch out for they are slippery creatures especially doing 90
Red Baron
#9
Ginostyle
NewTiburon.com Rookie
Ginostyle is offline
Sex: Male
Ginostyle is an unknown quantity at this point
Old Re: Removing the front bumper - how to? 06-01-2007 , 12:23 PM
Hey,
Thanks for the detailed DIY on removing the front bumper.
I will removing the 2004 and swapping in the 2005 bumper......the screws should line back up...right?
Let me know if there are any specials tricks or tips for this.
Thanks,
Paul
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
