Go Back   NewTiburon.com > Information > Do It Yourself > DIY Interior
Reply
Thread Tools Display Modes
#1
Johns03Tib
NewTiburon.com God
Johns03Tib is offline
Johns03Tib's Avatar
Sex: Male
Johns03Tib is an unknown quantity at this point
Old DIY: Removing Trim Parts and Painting Tips! 02-02-2004 , 05:19 PM
OK, here we go. By popular demand, a DIY for removing the trim pieces in your interior and the painting tips I used.
First things first, Removal!
A screw driver is ALL you need to get these pieces apart. A smaller, thinner flat head screwdriver works great!
We'll start here with the door handle. Get your flathead in the small gap on the front side of the door handle. You'll see it if you look in front of the handle. The gap is bigger than the dividing line of the 2 pieces. Place it in, twist and pull a little, you'll see it start to seperate. Dont be affraid to get forcefull, you'll have to! Work your way down as it pulls apart. Once you feel like its loose enough, place your flathead in the starting spot and PULL! PULL HARD! -POP!!!-
To remove the trim behind the door lever, you'll see the screw there in the open AND there is a screw behind the handle. Once you pop off the handle, the 2nd screw will be exposed. Take those 2 out, and the trim can now be removed.
Now, for the window control panel plates. Take your flathead, and place it under the piece in the middle. There are 3 large tabs keeping this part in place, 2 on the front side, one on the back. Just pry up a little (be careful not to gouge your door) working the screwdriver top to bottom, it will pop off once you clear the tabs. As you seperate it from the door, youll be able to see the tabs. EASY!
Now, for the round vents ONTOP of the dash, this was simple. There are 2 tabs (a big one and a small one) holding this down. The tabs are aprox. at 5 and 11 oclock. Just get your flat head under the vent in any location where there is NO tab, and lift. They pop right off.
For the center fascia, no tools are needed. Just pop open the ash tray, get your fingers underneath the fascia, and pull. Again, just tabs all around this piece are holding it on.
If youre interested in doing the trim where your dome light and sunglass slot is, start with the 2 screws you see when you open the sunglass door. Next you'll need to get the plastic part off where the light is.
Now, to get your shifter trim piece off (THIS IS FOR MANUAL TRANS ONLY) remove the shift nob and the spring underneath it. Once you get those off, simply grab hold, and pull up. Just tabs holding this on as well. Now, if you have the Auto-Trans, use JackMcNasty's AutoBoot DIY. Here's the thread. http://www.newtiburon.com/forums/showthread.php?t=8369
For the round AC vents, here is what you do...
-Take out the center console and disconnect all the wires.
-Remove the radio.
-The left vent has three screws, one on the left, one on the right and one on the bottom.
-The right vent only has two, one on each side.
-Take out the vents once unscrewed.
-Unclip the vent rings from the vent, there should be four clips on the vent.
-Take off rings, clip on new rings.
-Put everything back together.
Or, you can just cut them off. If you don't plan on using them again, you can hack them! Get yourself one of those really short screw drivers and that will help you along easier!
If you want to paint the gauge bezel, here's what you need to do. Under the topside of the gauge bezel, youll see 2 screws, take those out. When those are out, grab hold and pull down and out at the same time. It will be tuff to pull, but it will come off. Its only held in there by a few tabs and some insulation. Piece of cake!
Now that you have all of your pieces off, wash them with warm soap and water. NOTHING ABRASIVE!
Now, for the painting tips, here is what I used. Dupli-Color Primer, Paint, AND Clear Coat. If you want to use the same color I did, here are the numbers. Look on the UPC lable...
DS FM 226 SILVER (M)
0 26916 1226 1
Its a 5oz can of Dupli-Color Auto Spray.
OK, Several LIGHT coats of a good filler primer. Here's why. You dont really notice scratches and gouges on your black trim. Trust me, as soon as you lighten it up, every little crinkle, ding, or hack is noticable. The filler primer will help fix this. You may need to sand A LITTLE to fill in or reduce a scratch. The filler primer helps that to be accomplished with better results. Allow 10-15 between coats then a good 30 min before you paint especially if you did any touch up.
Now same thing with the paint. Several LIGHT coats of paint, almost like a dusting. You dont want paint to pool up in your corners. Again, 10-15 between coats. Now you want to let the paint sit for about an hour before you clear coat.
Clear coat is a little different. The first app should be very light, getting a little heavier with each application. Clear coat to me is the key! This is going to make your work shine and also provide protection. I did lots and lots of clear coat on all my pieces. This to me is the most important. And Wa-Laaa! There you'll have it!
Now, what I did for the door handles is a very patient tape job. It took me about 20-30 min for each handle. Lay a long piece of tape along the long dividing line of the handle allowing it to overlap into the smooth part just a little. Then I took a real thin screw driver and pressed the overlapping tape into the crack. Get it all in there. If it looks like its a little sloppy, it WILL be sloppy when you pull the tape. Also, its a good idea to put at least two layers of tape on so it wont leak through, you know, just incase you get a little TOO heavy with the spray. Finally, dont pull the tape until it is good and dry!
If you have any questions, feel free to ask! ENJOY PEOPLE! GOOD LUCK!
#2
nisco
NewTiburon.com Unemployed
nisco is offline
nisco's Avatar
Sex: Male
nisco is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-12-2004 , 07:45 PM
does anyone know how to get out the rear speakers/ rear interior panels....
and the sunglasses holder...
and the piece above teh steering wheel... where teh speedo is...
any tips would help thank you
#3
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-12-2004 , 09:04 PM
Yo Nisco, read my ENTIRE DIY, its all in there....... Shall I highlight it for you?
Well except for the rear speakers. I hear the DIY for the stock amp is the way you get to these suckers!
#4
nisco
nisco is offline
nisco's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-12-2004 , 09:10 PM
ohhh i see
about the sunglasses holder... hwo would you suggest getitn the plastic piece off from the lights
flat head?.... or jus play around with it?.. i know that if theres a problem with your sun roof the manual way is to pop off the plastic piece over teh lights... hmmm
and i see how to get the gauge bezel off.... when i was pullin it i thought i was gonna break something
alrigth thanks alot john
i appreciate everything!
#5
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-12-2004 , 09:34 PM
Just grab that gauge bezel and give it hell. Its going to be hard the first 1 or 2 times, but after that, youre good to go. You'll hear insulation popping and things stretching, but trust me, youll be A-OK!
#6
The Chad
NewTiburon.com Novice
The Chad is offline
Sex: Male
The Chad is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-15-2004 , 01:50 PM
How are the AC vents done? I looked at the other DIY and it was hard to understand withour pics.
#7
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-15-2004 , 05:05 PM
Quote:
Which vents are you talking about? BTW, I PMed you.......
#8
SonicBridge
NewTiburon.com Expert
SonicBridge is offline
SonicBridge's Avatar
Sex: Male
SonicBridge is an unknown quantity at this point
Old Re: Dome Light sunglass holder housing removal?? 02-16-2004 , 09:24 PM
"If youre interested in doing the trim where your dome light and sunglass slot is, start with the 2 screws you see when you open the sunglass door. Next you'll need to get the plastic part off where the light is."
SO HOW DO YOU GET THE PLASTIC PART OFF WHERE THE LIGHT IS? Found the two screws no problem, but when I try to remove the housing it seems like it is still attached somewhere. Don't want to break the plastic. So how is this done? Someone surely knows the answer to this one. Thanks for your help!
#9
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: Dome Light sunglass holder housing removal?? 02-16-2004 , 10:54 PM
Get in there as if you needed to change the light bulb for your dome lights. I used a small flathead to pop them out. Nice and easy!
#10
J-Fizzle
J-Fizzle is offline
J-Fizzle's Avatar
Sex: Male
J-Fizzle is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 02-16-2004 , 11:06 PM
Man that interior looks so nice....I really wish I didn't have that stick-on crap. Oh well, I'd probably break something anyway.
#11
Ruphos
NewTiburon.com Rookie
Ruphos is offline
Ruphos's Avatar
Sex: Male
Ruphos is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-13-2004 , 05:06 PM
Performing this mod right now with my window control panels only, just to test it out... Will post pics after I complete it. Taking a long time to make sure paint doesn't glob up anywhere. 15 mins between coats seem to work good so far, but taking more than SEVERAL coats of primer.. Thanks for the detailed DIY John!
- Nick
2003 Silver Tib GTV6 5 speed
Current: Injen CAI, Custom Grounding Wires, Clear Corners, Red Tails, Red Calipers, AOS Reverse Indiglo Gauges, Stainless Guage Surround, Brushed Alum. Racing Pedals and Dead Pedal, Billet Grille, Chrome Fogs, Silver dash trim, Tuscani Conversion, Kenwood DNX7100, RF Amp, 2 12" Eclipse
#12
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-13-2004 , 06:22 PM
Quote:
Glad it's helpful! Welcome to the boards!
#13
khead717
khead717 is offline
khead717's Avatar
Sex: Male
khead717 is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-13-2004 , 06:59 PM
Can someone explain how to pop the AC vent rings off? I read the post that fixer posted but the pictures are gone.
Rockford Fosgate HU
8000K HIDs
Tuscani Badges
Tibmeister's Ground Wires
AOS CAI
DIY Sub Re-wire
3.5" Antenna
B&M STS
Espelir Springs
#14
Ruphos
Ruphos is offline
Ruphos's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-17-2004 , 01:54 AM
I too wouldn't mind someone explaining how to pop off the center AC vent rings. ClubTuscani mentioned as stage 1 to use a screw driver to pop it off, then stage 2 to cut something. Don't exactly understand what you're suppose to cut, but then again I haven't tried it yet, so....
Anyway, here are the final results from my paint job. John, for the shift trim did you paint over the aluminum looking trim? or did you mask that off as well? I masked mine off, while it took a little over an hour, the results turned out fairly well... Here are the pics.
Nick
#15
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-17-2004 , 10:16 AM
Ahhh, another satisfied customer.
As for the AC rings. I still have yet to do mine. Just have to many other things going on at the moment. But the stage 1 and 2 that they talk about are just 2 different methods of removing the rings. If you DONT plan on EVER using them again, you can get a small hack blade and cut them off. If you DO plan to use them again, you need to go the less violent route. I've felt the screws holding the rings in. I know by that, that removing the rings this way will be a PITA, but there is no other way around it. Pop your center fascia out again, and feel around up/behind the vent rings. Get yourself a really short screw driver, and go for it!
As for the ring around the shifter, I painted it as well....
#16
Halogen78
NewTiburon.com Newbie
Halogen78 is offline
Sex: Male
Halogen78 is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-18-2004 , 06:01 AM
Here is the diy for taking out the side A/C vents so they can be painted.
http://www.newtiburon.com/yabbse/ind...threadid=20381
#17
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-18-2004 , 07:25 AM
Ahhhh, I was WONDERING where your DIY went to. Thanks for bringing it back. Good stuff! Folks, this is for the SIDE VENTS if any is interested!
#18
Halogen78
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-18-2004 , 01:31 PM
i just wish i had taken pics while i was doing it. The diy is already hard as it is and without pics makes it harder.
#19
SlightlyModified
SlightlyModified is offline
SlightlyModified's Avatar
Sex: Male
SlightlyModified is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-21-2004 , 09:00 AM
Wow, I did the cupholder install, and that was hell. Now I'm afraid to even touch those side vents if you're saying they are worse than the cupholders. Hmmm.... worth it... hmmmm......
yeah
B&G 1.6" Springs - Tuscani Emblems
Clear Corners - Chrome Door Handles
Billet Antennae - Blue LED conversion
PAI passenger cupholder - *custom LED conversions
"Other EBAY intake" CAI - Billet Dash vents
#20
lil_law
NewTiburon.com Post Master
lil_law is offline
lil_law's Avatar
Sex: Male
lil_law
Old Re: DIY For Removing Trim Parts and Painting Tips! 03-25-2004 , 10:23 PM
Just a thought instead of going through the hell of having to pull the side vents out could you not just get some kind of plastic and cut it to the same shape and paint it then use double sided tape and apply it over top? Kinda like those stick on kits but in the colours you want? I dunnno sounds kinda ricy but hey at least you won't have to go through hell..
Stupid people do stupid things...smart people out smart each other
#21
03'tiburonz
NewTiburon.com God
03'tiburonz is offline
03'tiburonz's Avatar
Sex: Male
03'tiburonz is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 04-11-2004 , 05:19 PM
hey has anyone found a color that matches the OEM metal interior?
2003 Tiburon V6 Automatic , Hotshot Headers/Cat, SRI. Wanted! - Borla Exhaust ...If your runnin rice you better think twice
#22
matt.blue
matt.blue is offline
matt.blue's Avatar
Sex: Male
matt.blue is an unknown quantity at this point
Old Re: DIY For Removing Trim Parts and Painting Tips! 04-11-2004 , 10:57 PM
Hi,
Am unable to see the pics for this DIY mod, please could neone send them to my email addy in my profile
Nice one
Matt
#23
matt.blue
matt.blue's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 04-11-2004 , 10:58 PM
Forgot to mention AC vents pics I needs
Matt
#24
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 04-11-2004 , 11:57 PM
Quote:
As I stated in my DIY, the paint I used nearly perfectly matches the stock interior silver parts. It just lacks that metallic haze. But the tone and hue are perfect.
#25
Johns03Tib
NewTiburon.com God
Johns03Tib's Avatar
Sex: Male
Old Re: DIY For Removing Trim Parts and Painting Tips! 04-11-2004 , 11:58 PM
Quote:
Originally Posted by matt.blue
Hi,
Nice one
Matt
Check your PMs.....
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2009 www.newtiburon.com. All rights reserved.
Designed by XG3
