This is a new DIY by `sl!m2k4T!b - please direct all questions and enquiries to `sl!m2k4T!b
Thanks
Parts: 1 can of paint (you can use $10 VHT caliper paint or you can go to home depot and buy a $2 can of outdoor weather resistant paint, or try the G2 stuff for $50)
1. Jack up the car, take the wheel off. (kinda important)
2. Get a pail with gasoline or some other kind of cleaner (laquer thinner whatever) and wipe down the break calipers - get them really clean. I used gasoline and a hard brush and lots of elbow grease. (if you smoke, this might not be a good time to light up)
3. When they shine their original grey/silver color (make sure they are completely clean on where you want to paint, if there is dirt the paint will end up reallly ugly looking) begin to mask everything around the caliper.
I used tape along the metal lining of the rotor and newspaper all throughout the wheel well and on the fenders - anywhere where you think paint might be blown on to (if your doing it outside - or inside - better safe then sorry) should be masked. see pic!
4. After the calipers are clean and everything is masked you are ready for the first coat. Shake the can up and spray on nice and light - DO NOT GO HEAVY OR IN ONE SPOT - keep in mind you will do at least 5 coats, so be sure to go light!!!!!
5. Let dry - I gave it about 15-20 minutes in between coats. Paint as many coats as you want - about 5 or 6 should be good, but use your own discretion. If you want to go more coats you can, if you want to go less you can also (my car used about 6)
6. After the final coat let it sit at least 30 minutes before putting the wheel on.
7. If you choose to put a clear coat on (not necessary but will help in maintance - I only clear coated the rears, never got around to doing the fronts) you must wait until the paint is completely cured (overnight usually) and then remask and apply the clear coat (the clear coat has to stay on overnight as well - do not drive with the clear coat unless its dry)
8. The hard part is just having the patience to do everywheel and waiting - repeat steps 1-7 on the other 3 wheels
9. Congrats your done! Finished Product:
