Engine Compatibility Info - Page 2 - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#26
Ravencrow
NewTiburon.com Expert
Ravencrow is offline
Ravencrow's Avatar
Sex: Male
Ravencrow is an unknown quantity at this point
Old Re: Engine Compatibility Info 01-01-2008 , 11:10 AM
I could add the 1.8, although I didn't know it was used on GKs. Thought it was mainly an RD engine, and I don't know if it will play nice with GK trannys (much like the Lambda I posted)
Someone with an intimate knowledge of these engine tranny combos post up or send me a PM so we can clear this up.
Graduating class of 2008---FINALLY
Here I come Texas Tech
Sponsored Links
Advertisement
#27
GuamBomb
NewTiburon.com God
GuamBomb is offline
GuamBomb's Avatar
Sex: Male
GuamBomb will become famous soon enough
Old Re: Engine Info 01-01-2008 , 03:48 PM
Quote:
Originally Posted by GuamBomb View Post
This is great stuf man. Good job!
1.Is there a supercharger made for the Lambda motor?
2.Can an alipine or SNiper fit on the Lambda motor?
3. Can we use the stock ECU(tib) for the lambda or do we have to change whole harness and use the Lambda ECU too?
SUBSCRIBED!
Also another question. Do we have to swap the tranny too if use the sigma or lambda motor? Or can we use our current tranny on our tib for these motors?
Thanks. Thanks in advance for doing your home work ..lol
#28
Ravencrow
Ravencrow's Avatar
Sex: Male
Old Re: Engine Compatibility Info 01-01-2008 , 07:24 PM
The Sigma motor bolts up to our trannys. The Lambda, im not so sure.
#29
2.7Elisa03
NewTiburon.com Novice
2.7Elisa03 is offline
2.7Elisa03's Avatar
Sex: Male
2.7Elisa03 is an unknown quantity at this point
Old Re: Engine Compatibility Info 01-07-2008 , 04:02 PM
would doing a 3.5l swap and keeping the auto 4 make much of a difference than having the 2.7 with i/h/e with the auto 4
or should you switch over ther 5 speed auto too?
*project ORS-350 begins...
*weight = 2780lbs. Down from 3279lbs.
*intake, headers,exhaust, kosei light weight wheels, kumho tires, 8K H.I.D. conv., canuck motorsports lowering springs,custom headlights, KDM Grill, KDM Front valance, KDM side skirts..
*COMING SOON... ,Mystery Final Drive gear
,obxLSD...
#30
Ravencrow
Ravencrow's Avatar
Sex: Male
Old Re: Engine Compatibility Info 01-08-2008 , 08:11 AM
I believe all of the bolt patterns are the same, so you should be able to keep the auto 4. And yeah, it would still make a difference, as the 3.5L is a torque beast compared to the 2.7L.
#31
v6tuscani2004
v6tuscani2004 is offline
v6tuscani2004's Avatar
Sex: Male
v6tuscani2004 is an unknown quantity at this point
Old Re: Engine Info 02-22-2008 , 09:31 AM
Its a shame the 3.3L Lambda is not a direct drop in, that would be the way to go for power!
#32
g8m3rtag
NewTiburon.com Professional
g8m3rtag is offline
Sex: Male
g8m3rtag is an unknown quantity at this point
Old Re: Engine Info 03-19-2008 , 01:21 AM
Quote:
Originally Posted by Ravencrow View Post
As far as I know, there are no bolt-on supercharger or turbo kits for the Lambda in the US. Kpec might have some over there, though. The engine is just so new, nothing has been developed. Can you say custom turbo set up though?
If you are going for pre-tested waters then use the Sigma for a swap. It is mostly drop in.
The Lambda would be interesting to see though. I posted it as a viable swap simply because of it's size and the tranny configurations the new Sonatas and Santa Fe's have. It SHOULD fit, but I don't know any technicalities.
What does "mostly drop in" mean?
03 GT V6 Jet Black
- clear corners, Tuscani emblems, AOS Racing gauge cluster, DD short antenna, Custom 2.5" exhaust, Compaq Evo n180 w/ Xenarc touchscreen, Injen SRI, SSA Headers
To be installed - Custom Short Shifter
#33
BlackSharkGT
BlackSharkGT is offline
BlackSharkGT's Avatar
Sex: Male
BlackSharkGT is an unknown quantity at this point
Old Re: Engine Compatibility Info 04-07-2008 , 07:55 AM
wow cool thread man i would love some more info about the lambda or sigma swaps or maybe see one installed but awesome idea man
2004 Black GT SE
Injen SRI Mussa Exhaust KGB Delrin Bushings Magstar Wires ARK S2K Antenna Valeo Extreme Clutch with Flywheel Conversion RPM Rear Strut Bar
Xplod 12's Xplod 1000w Amp MW Interior Drag DR-17's Falken Azenis Tires Xentec 12000k HID'sWingless Mod 35% Tint Custom Aggressive Eyelids yellow fogs black stockers niteshaded tails
#34
Sevin
Sevin is offline
Sevin's Avatar
Sex: Male
Sevin is infamous around these parts
Old Re: Engine Compatibility Info 04-07-2008 , 11:58 PM
im going to try to get my hands on that 3.3 and swap it. I wonder if ngm's assassin will adapt to it... worth a shot. great thread!
#35
Zurik
Zurik is offline
Zurik's Avatar
Sex: Male
Zurik is an unknown quantity at this point
Old Re: Engine Compatibility Info 04-08-2008 , 12:21 AM
I own a sigma motor lol.. maybe I should start doing my research (i own a kia sorento.. maybe swap the engines?)
#36
nerv
NewTiburon.com God
nerv is offline
nerv's Avatar
Sex: Male
nerv
Old Re: Engine Compatibility Info 04-14-2008 , 10:44 AM
This the things i am looking at
"Kia Optima- the 2006 and better are called the 2.7 Mu, which puts out an extra 15 horsepower for the same displacement" This is the same G6BA engine like our tib's but the Optima's Mu Engine Code is G6A5. These v6 has cvvt (Continuous variable valve timing) like BMW's Valvetronic can alter timing and lift continuously, which is called Continuous variable valve timing or CVVT.
according to alot info gather from the matrix.
now i was thinking if i keep the same lower block but switch the heads and computer with cvvt
would this Frankenstein up able to work ?
Just wondering
#37
jp1884
NewTiburon.com Newbie
jp1884 is offline
Sex: Male
jp1884 is an unknown quantity at this point
Old Re: Engine Compatibility Info 04-15-2008 , 02:52 PM
Hi,
If I change the engine Tibby 2003 2.0. cc by an Delta V6 of Sonata.... Can I use the same speed transmission or I should to change it too ?
IF the answer is yes, which can use ? sonata too ?
What else should I change with the new swap .
I just thinking beacuse I want buy a tiiby v6 but in my country there is no a lot of them, hence the solution would be buy a I4 and change the engine
Thanks
#38
jp1884
jp1884 is offline
Sex: Male
Old Re: Engine Compatibility Info 04-15-2008 , 06:13 PM
Can someone provide me the engine serial number of the Hyudai Sonata v6 2.7 cc in order to order it with my local used motors store
I understand that is the same that the tibby 2.7 use right ?
Thanks
#39
Ravencrow
Ravencrow's Avatar
Sex: Male
Old Re: Engine Compatibility Info 05-21-2008 , 09:01 PM
jp1884, sorry for my lack in response. The 2.7L swap would fit, and would bolt up easily, but the ecu and wiring would have to be completely changed. You might as well just swap a 3.5L for the trouble. Also, for those still skeptical of the 3.5L swap, head on over to the kspec sponsor thread to see their swap. The motor bolts up to our tranny easily, but as far as the ecu and wiring, they DO have to be changed/modified.
Also, for any of those who have/will have/want to have the 3.5L motor, the timing belt change looks like hell in sprocket form.
#40
Ravencrow
Ravencrow's Avatar
Sex: Male
Double post due to sudden internet lag.
#41
NAVYTIB
NAVYTIB is offline
NAVYTIB's Avatar
Sex: Male
NAVYTIB is an unknown quantity at this point
Old Re: Engine Compatibility Info 06-28-2008 , 12:22 AM
Great thread! Anyone know where I could find some more diy pics, parts and info for the 3.3 swap?
#42
2.7Elisa03
2.7Elisa03's Avatar
Sex: Male
Old Re: Engine Compatibility Info 08-09-2008 , 10:21 PM
has anyone started a 3.3 swap?
,obxLSD...
#43
bluedragon436
bluedragon436 is offline
bluedragon436's Avatar
Sex: Male
bluedragon436 is an unknown quantity at this point
Old Re: Engine Compatibility Info 08-15-2008 , 12:20 AM
Just wondering
I was just looking these type of things up myself online... and from what I found it looks to be pretty much the exact same... as far as it should all bolt up and work on the current 2.7 Tib motors.... I can't promise you on the wiring harness though... That part might be a PITA... I would love to do that 3.3 swap though... I know one of the slightly larger V6's was cast iron or steel or something like that... not sure which one though... that might be an issue as far as weight... but would be nice for boosting if setup correctly... Def. might have to look into finding a 3.3 in a junk yard once I get back stateside... Def. going to subscribe to this one though...
Alright just started messing with some more research and found this on wikipedia about the 3.3: Apparently there is a larger version of the 3.3....
The 3.8 L (3778 cc) version produces 263 PS (196 kW) (312 hp (233 kW) in the Genesis Coupe) and 258 ft·lbf (353 Nm). It has a 96.0 mm (3.8 in) bore and 87.0 mm (3.4 in) stroke.
The Genesis variant of this engine makes 290 hp (220 kW).
Applications:
* 2007/2008 Hyundai Azera
* 2007/2008 Hyundai Equus/Centennial
* 2006/2007/2008 Hyundai Entourage
* 2007/2008 Kia Amanti
* 2006/2007/2008 Kia Sedona (Grand Carnival)
* 2007/2008 Kia Sorento
* 2009 Kia Borrego
* 2009 Hyundai Genesis
* 2010 Hyundai Genesis Coupe
2004 Tiburon GT-- Under Construction (Slowly Unfortunately)
#44
f0x_12
f0x_12 is offline
f0x_12's Avatar
Sex: Male
f0x_12 is an unknown quantity at this point
Old Re: Engine Compatibility Info 01-15-2009 , 10:12 AM
i know that our engines fall apart with too much boost and i was wondering if anyone knows how these larger engines take to boosting.?? (3.3/3.5)
it would be nice if one of them was an easy swap and was more reliable at higher boost levels.
my TibBee
#45
darvo
darvo is offline
Sex: Male
darvo is an unknown quantity at this point
Old Re: Engine Compatibility Info 01-15-2009 , 06:45 PM
They must be good with boost since they have iron blocks, and have beefy rods...
" The more posts you have, The more knowledgeable you'll get " Myslow1's MOTTO
#46
mathwieu
mathwieu is offline
Sex: Male
mathwieu is an unknown quantity at this point
Old Re: Engine Compatibility Info 01-27-2009 , 04:06 PM
double post
#47
mathwieu
mathwieu is offline
Sex: Male
does anyone know if the v6 3,8 liter of the genesis sedan or coupe fit into a 2003 tiburon ??
is the sedan manual or just auto ??
just thinking to drive a 312 hp STOCK motor in my tibby just make me dream
#48
tuscaniGT44
tuscaniGT44 is offline
Sex: Male
tuscaniGT44
Old Re: Engine Compatibility Info 01-31-2009 , 01:12 PM
the sedan to my knowledge is automatic and tiptronic. the genesis coupe is optional with a standard 5 speed and 6 speed for the V6.
i like the engine compatibility thread, but i would really love to drop in a 350 LT or LS2 engine into the tib. or a 2jz engine. i have a V6 2005 tib. i think i'd be sick to drop in a V8 crate motor into the tib.
#49
dannylm89
dannylm89 is offline
dannylm89's Avatar
Sex: Male
dannylm89 will become famous soon enough
Old Re: Engine Compatibility Info 01-31-2009 , 01:36 PM
In all seriousness JT that would be a sick project to work on
#50
nerv
NewTiburon.com God
nerv is offline
nerv's Avatar
Sex: Male
nerv
Old Re: Engine Compatibility Info 01-31-2009 , 08:32 PM
it would be nice if it RWD
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
