Brakes locked up - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Wheel, Tire, & Suspension
User Tag List
Reply
Thread Tools Display Modes
#1
xalexmaximovx
NewTiburon.com Rookie
xalexmaximovx is offline
xalexmaximovx's Avatar
Sex: Male
xalexmaximovx is an unknown quantity at this point
Old Brakes locked up 01-02-2008 , 11:29 AM
Ok so the ghost in my car is at it again, this morning when I was driving to work I noticed that the car was not pulling too well, when I stopped for coffee literally 2 mins from my house and looked at my back breaks they were smoking. If I take the e brake off and leave it on neutral even on a hill the car wont roll, back brakes are completely locked. Drove the car back to my house to get into my old daily driver, when I pulled into the driveway I didn’t see smoke…so I decided to touch the caliper…what a BAD idea =(
Any ghost busters ideas on what i should do?
Sponsored Links
Advertisement
#2
bms231
Former CIO
bms231 is offline
bms231's Avatar
Sex: Male
bms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another level
Old Re: Brakes locked up 01-02-2008 , 11:49 AM
e-brake cable frozen? it got pretty cold last night. sometimes water gets in the rubber line of the ebrake and freezes it.
one thing i have always wonder about hyundai is how exactly their ebrake system works. i always thought it was an additional piece of metal inside the rotor on the right rear brake. kinda making it a psuedo drum brake.
yea it is i just checked. so i aint smoking crack.
I am no longer an admin. Please do not PM me with site issues. Use the report post button.
#3
xalexmaximovx
Sex: Male
Old Re: Brakes locked up 01-02-2008 , 12:03 PM
It was cold, but the car has seen colder. How can I prevent this from happening if thats the case? brake bleed?
#4
timmy_mpls
NewTiburon.com God
timmy_mpls is offline
timmy_mpls's Avatar
Sex: Male
timmy_mpls
my right rear is locked up too, but the outer pad is worn down to the metal, so i dont think it's the "pseudo drum" thing
- i know my brake light is out -
#5
paxx
paxx is offline
Sex: Male
paxx is an unknown quantity at this point
Old Re: Brakes locked up 01-02-2008 , 12:04 PM
Do you have tension in your e-brake line? If not, frozen or snagged line. You can take off the rear wheels and manually disengage the e-brake by pulling the lever the line is connected to towards the rear of the car. Its not easy, but possible. Try defrosting the line with a hair dryer. If that doesn't do it your line may have snagged. If thats the case, just cut the line and have the dealer do a warranty repair.
If you do have tension in your e-brake line when you release the lever you probably have a stuck caliper. In which case you would have to get a caliper removal tool attach it to a good C clamp and compress the caliper back into its housing.
Edit:
How cold is it in virginia? I don't ever remeber it getting below freezing when I lived there
#6
xalexmaximovx
Sex: Male
Old Re: Brakes locked up 01-02-2008 , 12:18 PM
Edit:
Thanks for the info, two questions. Hows me cutting the break line warranty covered? Is the caliper removal part under warranty?
Its not that cold, but the wind kicks your butt
#7
bms231
Former CIO
bms231 is offline
bms231's Avatar
Sex: Male
Old Re: Brakes locked up 01-02-2008 , 12:36 PM
if u cut the brake line u just say it snapped. hence, warranty coverage. not sure if it is a 'wearable' item though. if ur still under warranty just take it to them and say they locked up.
#8
paxx
paxx is offline
Sex: Male
Old Re: Brakes locked up 01-02-2008 , 12:53 PM
It's not a wearable item. I had to do the same to mine due to a snagged line. They had no problem replacing it under warranty. If you do cut it, just tell them it snapped.
It's possible but difficult to remove the pin from the e brake lever, but its a pain in the ***. Try that route if your uncomfortable cutting the line, but if it already has tension it can be a nightmare.
If its in fact the caliper you can free it using the method I posted earlier. I would then bring it to the dealer and have them replace the caliper.
Edit:
BTW you most likely warped your rotors due to the heat. They will need to be reground, or replaced.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
