Location of the Crank, Cam, and TPS Sensors - New Tiburon Forum : Hyundai Tiburon Forums
User Tag List
Thread Tools Search this Thread Display Modes
#1 Old 01-06-2008, 01:44 PM
Addicted2Speed
NewTiburon.com Expert
Addicted2Speed's Avatar
Addicted2Speed
(Thread Starter)
I'm planning to install an AEM FIC soon, and need to know the locations of the Crank, Cam, and TPS sensors. There are two electrical connectors near the throttle body. I'm not sure which one is the TPS. My car has the 2.7L V6 engine.
I will be tapping into the wires near each sensor for ease of installation.
Thanks for any help.
Addicted2Speed is offline
Sponsored Links
Advertisement
#2 Old 01-06-2008, 01:59 PM
VoodooXTC
NewTiburon.com God
VoodooXTC's Avatar
VoodooXTC has a spectacular aura aboutVoodooXTC has a spectacular aura aboutVoodooXTC has a spectacular aura about
Re: Location of the Crank, Cam, and TPS Sensors
the cam sensor is on the right side of the engine on the end of the intake cam of the rear bank. the crank sensor is close to the starter... i think lol i know its in that general region. ya just checked it right above the starter. and i believe the tps is the lower sensor inline with the butterfly
Quote:
dude you are fvcking mental..... and its awesome!!!
2003 GT 5spd Scattered through out my garage, shed and across North America.
1990 Eagle Talon AWD Turbo 5spd..........
VoodooXTC is offline
#3 Old 01-06-2008, 02:18 PM
Rushr
Dave: NT Admin
Rushr's Avatar
Rushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another level
Here you go man. The Crank Position Sensor is down on the block behind the front header.
Rushr is offline
#4 Old 01-06-2008, 10:48 PM
Addicted2Speed
Addicted2Speed
(Thread Starter)
Thanks again for the pictures!
#5 Old 08-21-2011, 02:53 PM
Broken Halo
NewTiburon.com Newbie
Broken Halo's Avatar
Broken Halo is an unknown quantity at this point
Is there a special trick to the clip holding the crankshaft position sensor? I push down that metal clip but I can't get it to come loose for nothing. Its a 2003 so its probably either just stuck really good or I'm doing something wrong.
Broken Halo is offline
#6 Old 08-24-2011, 12:46 AM
MindHacker
NewTiburon.com God
MindHacker's Avatar
MindHacker is just really niceMindHacker is just really niceMindHacker is just really niceMindHacker is just really nice
pull the metal clip all the way off (sideways), then pull the cable off.
Also, don't bump old threads.
Go: Alpine m62 @ 5psi strut/sway/room/lower bars, DTPs, koyo rad, LW fly, +clutch, xg350 bbk, 18x8+35
Show: Lambo's, CF Hatch/hood/trim, diffuser, tint, fenders, volt stabilizer, strobes, AE's, underglow, gilllglow, custom tails
Interior: Integrated radar/eeepc/cb, dynamat, 300w sub, marble & leather, glow, sills, door plates + 2nd handles, Starlight headliner, analog clock, passenger horn
In progress: fixing these.
MindHacker is offline
#7 Old 08-27-2012, 11:39 PM
Miiitchhh
NewTiburon.com Novice
Miiitchhh's Avatar
Miiitchhh
For anyone whos about to do this to their car, i just did it and its a mother to get to.
If you can't find it, look at your coils where your wires plug in, underneith that are two connectors. One of those connections (on my car it was the black one closest to you) leads to the crank sensor. Follow it back with your hands, it goes right into the wall near the bottom of the engine.
I had to remove the hose from my radiator because it blocks your view.
This might not be the case on yours, but i couldn't fit a socket onto the bolt (like there literally isnt enough space between the bolt and the sensor to fit a socket...). I had to use a little 10mm wrench and luckly mine was loose because its so retarded trying to get your hand down in there.
And im not bumping an old thread i read this thread 3 hours ago when i couldn't find the sensor and i wish someone would have wrote this^
South Florida
Miiitchhh is offline
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Show Printable Version Show Printable Version
Email this Page Email this Page
Search this Thread:
Advanced Search
Display Modes
Linear Mode Linear Mode
Forum Jump
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
For the best viewing experience please update your browser to Google Chrome
