AC recharge question - New to Hyundai - New Tiburon Forum : Hyundai Tiburon Forums
Reply
Thread Tools Display Modes
#1
drowner
NewTiburon.com Newbie
drowner is offline
Sex: Male
drowner is an unknown quantity at this point
Old AC recharge question - New to Hyundai 07-22-2008 , 02:59 PM
I'm trying to recharge the AC in my girlfriends 2003 V6. I have the refrigerant and the hose with the pressure gauge on it as well. When i hook up to the low side, it jumps to max pressure, if i turn the car on and turn on the AC, it stays at max. Do we have a different problem besides low refrigerant?
Sponsored Links
Advertisement
#2
valkare
NewTiburon.com God
valkare is offline
valkare's Avatar
Sex: Male
valkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond reputevalkare has a reputation beyond repute
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 03:05 PM
seems odd..... what is max psi on your gauge?
Also, turn on car, turn the AC on and then to max and coldest settings, then hook up the dial. Furthermore, what is the ambient temperature when you're doing this? The psi dial is sensitive to the ambient temperature, and most provide accurate readings for 75-85 degress I believe.
All this aside, if your gauge is constantly reading like 40+ psi, I'd say there's a block in the line somewhere causing pressure buildup, which is very bad, or your gauge is broken, or it's not hooked up properly.
^ note, if someone used that stop leak crap on the system before, a block is possible since that stuff can cake up in the lines from what i've heard and the entire system could need a flush.
2007 e92 space gray 328i w/ dakota gray interior
#3
drowner
drowner is offline
Sex: Male
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 03:11 PM
Its a brand new gauge, and the temp outside is about 77, and i have the dial set to that. THe max on the dial is 90 psi, and its redlined. I did hook up the gauge and put the AC on max, and it didn't move. I wonder if it's overfilled and thats why it's not working.
Should i just let a bunch out, and see if the gauge drops? Couldn't hurt, since it isn't working anyway.
#4
valkare
NewTiburon.com God
valkare is offline
valkare's Avatar
Sex: Male
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 03:12 PM
uhhh.... I think at 90 psi the system and lines would blow up.... I think the gauge might be broken. If someone else has another idea, feel free to correct me.
#5
drowner
drowner is offline
Sex: Male
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 03:21 PM
I just hooked it up to my WRX, and the gauge is most definitely not broken.
#6
valkare
NewTiburon.com God
valkare is offline
valkare's Avatar
Sex: Male
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 03:26 PM
.... hrm..... I guess I'd try and vent the system and then see what the reading is. I think you might have a clogged line somewhere because someone probably used stop leak at some point, which will require more then a simple vent and refill for the long run.
#7
handr_circle
NewTiburon.com Novice
handr_circle is offline
handr_circle's Avatar
Sex: Male
handr_circle is an unknown quantity at this point
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 04:54 PM
Call and talk to the shop at a Hyundai dealership. My dealership told me 85 is normal for our cars with the ac on full blast. But I have not had a chance to fool with mine yet. Just don't start venting it out.
03 GT: Alpine Stage 1, RRM ported/polished IM, BBTB, SRI, DC Headers, Borla catback, MAFterburner Stage 2, ARK lightweight pullies, NGK plugs and wires, SFR BBK, ARK Strut tower bars, B&M STS, Eibach springs and KYB struts, Battery relocation, Delrin shifter Bushings, CF Sunroof, etc... In the process of parting out though :/ Being sold here:
#8
valkare
NewTiburon.com God
valkare is offline
valkare's Avatar
Sex: Male
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 04:57 PM
safe psi for the ac is something like 25-35 with the a/c on and at full blast.
#9
Solidandre
NewTiburon.com God
Solidandre is offline
Solidandre's Avatar
Sex: Male
Solidandre has a spectacular aura aboutSolidandre has a spectacular aura about
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 04:59 PM
yea i charged mine this weekend, due to the header install as i let out all the freeon lol, put it on max a/c threw it on the highest level and filled it, i think mine settled at 33 or so psi
Sniper Charged 2007 Tiburon GT
#10
JWM1986
NewTiburon.com Expert
JWM1986 is offline
JWM1986's Avatar
Sex: Male
JWM1986
Old Re: AC recharge question - New to Hyundai 07-22-2008 , 05:03 PM
Mine peaks when I check it to. And the car was bought new and only has like 10k miles on it. We know the gauge is fine as I checked it on 2 other vehicles.
2006 Tiburon SE --- Dead ---
Audio: Pioneer DEHP6900UB, Infinity REF 6 1/2" components & 6x9's, Kicker ZX700.5 w/ ED 13Ov.2
Interior: LED dash lights, ARK STS
Exterior: T Badges, any-time fog light kit, LED license plate lights, 6K HID lows & yellow fogs
Performance: Injen SES, Injen SRI, RRM Front & Rear SB, ARK GT-F Springs
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Designed by XG3
