DIY: Stop That Awful Trunk Squeaking
2003 Tiburon GT 2.7 V6
My Tib has made a HORRIBLE trunk squeaking since I bought it. It was driving me crazy. I searched around here for a while but havn't been able to find a solution. I've heard lots of other people with the same problem as well. It's not the trunk rattling that many people report, there is already a DIY for that. It's a persistant squeaking noise that happens basically anytime the car is moving. It's not just over bumps, but bumps do make it worse. I read about some people fixing this by tightening their spoiler bolts, but this didn't help mine at all.
So I had my girlfriend drive a little bit while I layed down in the hatch, and was able to isolate a few spots where the noise was coming from. It seemed to be coming from just above the stock sub, but on both sides, and down near the bottom of the taillights. When I would push up on the hatch hard, the noise would go away. So I shoved a couple paper towels onto the rubber contact points, near where the hatch seals, and this completely fixed the noise. It looks like after time these rubber stoppers harden and squeak as they make contact with each other.
So I found a permanent solution and made it into a DIY for others with this problem. There's probably more than a few ways to fix this, but this is what worked for me.
Materials:
-Scissors
-Heavy Duty Double-Sided Outdoor Tape
-Felt Pad
-(Optional) Felt Circles
1. Here's a shot of everything I used. Also, I found some leftover felt circles that you use to put on the bottom of couch legs for a hardwood floor or whatnot.
2. Here are the spots that I isolated where the squeaking was coming from.
Also, these spots where the rubber stoppers on the hatch come down onto.
3. Using any cleaner, clean off all of there areas really good so that the tape sticks well.
4. Line up the felt pad with the rubber stoppers to get an idea of how big to cut your felt squares.
5. Make a few snips to determine the size of the square.
6. Cut out the squares, and line up with the rubber stoppers. I cut mine bigger to make sure no rubber can make contact.
7. If you have those felt circles, find a good size for this spot, or if not cut a felt piece to fit here as well.
8. Take all your felt pieces inside and begin to take off the advesive backings. This adhesive is definatelly not strong enough to stick to the rubber by itself, I tried doing that at first and they fell off as soon as I opened the hatch.
9. Peel back some double-sided outdoor tape, and stick the adhesive side of the felt on it.
