Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > Information > Hyundai Tech
User Tag List
Reply
Thread Tools Display Modes
#1
geekguy
NewTiburon.com Newbie
geekguy is offline
Sex: Male
geekguy is an unknown quantity at this point
Old Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 03:45 AM
Hello Everyone,
I have this problem with my car, whenever I go to the gas station and pump fuel into my car, my car has got the hardest time starting. When I am done pumping gas I go to turn the car on and it turns off on me. The way I get it started is as I go to turn on the car I have to press down on the gas pedal while in park for about 10 seconds and quickly change into drive to get my car moving.
This problem does not occur again after it has been turned off. My car starts up normally after turning it on and off randomly. I only have the problem where it wont start after pumping fuel.
Another problem with the car is that my RPM's keep on shifting every ones in a while, it constantly moves from 2000 to 1000 to 1500 to 500 RPM while it is in stall over a period of less than 30 seconds.
I have had my car looked at and got my fuel injectors changed and my oxygen sensor cleaned up due to a build up of carbon. Now I am not sure what to do with it. I may believe that it could be a fuel sensor or something.
If anyone out there has got any idea of how to fix this I would be greatly appreciated, I have dealt with this for the past six months and may believe the problem could get worse.
Thanks
Sponsored Links
Advertisement
#2
hotWheelz
Rool : Pron Spammer
hotWheelz is offline
hotWheelz's Avatar
Sex: Male
hotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another levelhotWheelz is on another level
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 03:55 AM
If you're topping off the tank, don't.
Genesis 1:1 "In the beginning, R00l made God. Then, God made Earth."
#3
BurnsvilleTib08
BurnsvilleTib08 is offline
BurnsvilleTib08's Avatar
Sex: Male
BurnsvilleTib08 is an unknown quantity at this point
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 03:58 AM
Could be a few things, are you clicking the gas cap a few times to seal and pressurize the tank?
#4
Newo
NewTiburon.com Post Master
Newo is offline
Newo's Avatar
Sex: Male
Newo is just really niceNewo is just really niceNewo is just really nice
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:13 AM
Quote:
what does that mean?
#5
geekguy
geekguy is offline
Sex: Male
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:45 AM
Quote:
yes i am turning the gas cap three times which is the recommended amount of turns. If i were not my engine light would go on. My engine light only goes on when my car turns off and so does my brake light, but after turning it on, both lights turn off and runs normally, except for the RPM situation
#6
hotWheelz
Rool : Pron Spammer
hotWheelz's Avatar
Sex: Male
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:53 AM
Quote:
Like when you fill up your tank and the nozzle clicks off, some people continue to try pumping gas after that. That's topping off the tank.
Anyway, the reason why it's not good for our cars (or most cars, in general) is that the extra gas may get into the vapor recovery system and clog it up. I think this has happened to other people and it has caused their cars not to start.
#7
hotWheelz
Rool : Pron Spammer
hotWheelz's Avatar
Sex: Male
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:54 AM
Have your idle actuator looked at. Maybe it's toast.
#8
InkTheFlesh
NewTiburon.com God
InkTheFlesh is offline
InkTheFlesh's Avatar
Sex: Male
InkTheFlesh will become famous soon enough
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:20 PM
Sound like a purge valve problem, or a problem with the vent valve on the charcoal canister.
'09 Silverado Crew Cab
#9
tibby007
NewTiburon.com God
tibby007 is offline
tibby007's Avatar
Sex: Male
tibby007
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 04:57 PM
wtf? I've been topping off my tank since day one and never had this problem before....and forgive the noob question, but what and where is the charcoal canister and purge valve? Is that only on the manual tranny Tibs?
2004 Hyundai Tiburon GT, Auto. Apexcone 55W 6000K HIDs, F/L Headlights, LED Taillights (Stop, Turn & Backup), 30% Tinted Windows, Injen SRI, Borla Catback Exhaust, White LED Gauges, Ark Racing Shorty Antenna, Midnight Wolf Custom Tuscani Single DIN Head Unit Plate, Midnight Wolf Tuscani Mission Plate.
#10
InkTheFlesh
NewTiburon.com God
Sex: Male
Old Re: Problems getting a 2004 Hyundai Tiburon GT Automatic to start after pumping fuel? 02-15-2009 , 09:06 PM
Quote:
Charcoal canister filters the fuel vapors that evaporate in the gas tank, every car in the US has one. On the Tib, it's in the rear under the car, and usually the purge valve is somewhere up in the engine bay hooked up to a vacuum source.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
