transmission removal: tranny stuck - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Transmissions
User Tag List
Reply
Thread Tools Display Modes
#1
Panda
NewTiburon.com Newbie
Panda is offline
Sex: Male
Panda is an unknown quantity at this point
Old transmission removal: tranny stuck 08-04-2009 , 10:10 PM
Alrighty i have an 03 v6 6spd gt, in the process of removing the tranny, everything is off, unbolted and out of the way. Tranny comes off the engine about 1/2 an inch then gets stuck and wont come off any further. Im pretty sure the imput shaft is hung up on the clutch. Anyone have any recomendations?? ive had three guys prying and tugging and it wont come loose, it wiggles ALOT but will not come free. Im really stuck here.
Sponsored Links
Advertisement
#2
03natib
NewTiburon.com Expert
03natib is offline
03natib's Avatar
Sex: Male
03natib is an unknown quantity at this point
Old Re: transmission removal: tranny stuck 08-04-2009 , 10:14 PM
ok have you removed the 2 front craddel bolts and try rotating the trans clockwise
#3
Panda
Panda is offline
Sex: Male
Old Re: transmission removal: tranny stuck 08-04-2009 , 10:24 PM
Quote:
you mean the coupler bolts? because all the coupler bolts are off
#4
03natib
03natib is offline
03natib's Avatar
Sex: Male
Old Re: transmission removal: tranny stuck 08-04-2009 , 10:29 PM
no the craddel bolts them self you will not be able to drop the trans out with out removing them. they are 4 bolts on the black sub frame. im sorry not the 2 front but the 2 on the driver side just let it hang. it is the frame section that connects the front of the car to the tunnel
#5
krazymikeyXJ
krazymikeyXJ is offline
krazymikeyXJ's Avatar
Sex: Male
krazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond reputekrazymikeyXJ has a reputation beyond repute
Old Re: transmission removal: tranny stuck 08-04-2009 , 10:34 PM
i posted a pdf on how to do this. let me find it
2008 toyota prius-Intake, exhaust, lambo doors, leds, spoiler, and more
#6
krazymikeyXJ
Sex: Male
Old Re: transmission removal: tranny stuck 08-04-2009 , 10:41 PM
what is your email
#7
sprague1420
NewTiburon.com God
sprague1420 is offline
sprague1420's Avatar
Sex: Male
sprague1420 has a spectacular aura aboutsprague1420 has a spectacular aura about
Old Re: transmission removal: tranny stuck 08-04-2009 , 11:45 PM
you didnt unbolt the clutch fork... where the slave connects to the top of the trans... there is a nut to hold it in just un bolt it and take the plastic bushing out and it will let the fork move free enough to slip away from the TOB
#8
Whooty
Whooty is offline
Sex: Male
Whooty can only hope to improve
Old Re: transmission removal: tranny stuck 08-05-2009 , 12:32 AM
Unhook the forks from the TOB.
#9
6speedtiburon_silver
NewTiburon.com God
6speedtiburon_silver is offline
6speedtiburon_silver's Avatar
Sex: Male
6speedtiburon_silver will become famous soon enough6speedtiburon_silver will become famous soon enough
Old Re: transmission removal: tranny stuck 08-05-2009 , 01:22 AM
Quote:
Quote:
+1 to both of these you might need to move the lever towards the engine to help it along.
Other toy 99 dodge ram sport work in progress
#10
Panda
Panda is offline
Sex: Male
Old Re: transmission removal: tranny stuck 08-06-2009 , 12:35 PM
I ended up pulling the engine, pulled the clutch fork nut and bushing off, the rod is now loose and i can even pull it out pretty far, but the tranny is still stuck. HELP!!
#11
Panda
Panda is offline
Sex: Male
Old Re: transmission removal: tranny stuck 08-06-2009 , 02:06 PM
got it off finally, just had to muscle it. only problem is that im a little confused about the flywheel. The part that the clutch bolts to is wobbly and doesnt seem like its attatched very well to the flywheel itself. Is this normal? maybe that was why my clutch didnt disengage?
#12
only1db
NewTiburon.com Professional
only1db is offline
Sex: Male
only1db will become famous soon enough
Old Re: transmission removal: tranny stuck 08-06-2009 , 06:50 PM
you removed the engine
you have to remove the entire subframe to get the tranny out...why did you not do that??
you need to rotate the fork and it should slide out.
[sig="http://i46.photobucket.com/albums/f138/only1db/DSC00741-1.jpg[/sig]
#13
salski92
salski92 is offline
Sex: Male
salski92 is an unknown quantity at this point
Old Re: transmission removal: tranny stuck 01-28-2012 , 11:58 PM
it seems everyone has the same problems removing the tranny -__- mine is stuck as well!!!
#14
sethnicity
sethnicity is offline
sethnicity's Avatar
Sex: Male
sethnicity is an unknown quantity at this point
Old Re: transmission removal: tranny stuck 08-26-2013 , 04:48 PM
Found some other info that might be useful fornay one still interested...
Question:
I have an 03' hyundai tiburon 2.0 4cyl. manual trans. and I'm replacing the engine. I took the engine out with the trans still attached. now I'm trying to remove the trans from the engine and I cant get the trans to separate from the engine more than a half inch. I couldn't find any access to the torque converter to remove any bolts. so how do I remove the trans
ANSWER:
Your vehicle uses a pull type clutch. The clutch throwout bearing release fork hooks into the release bearing. You'll need to remove the release fork lever from the top of the transmission to allow the fork to rotate out of the release bearing.
The release fork lever is the lever held onto the top of the transmission with a 14mm nut and attaching to the clutch release cylinder piston rod.
If you'd like to see the diagrams in the shop manual, you can register for a free account at www.hmaservice.com.
I have personally registered at the site and have found lots of usfull information there as well.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
