Go Back   NewTiburon.com > Information > Do It Yourself > DIY Exterior
Reply
Thread Tools Display Modes
#1
smitty
NewTiburon.com Expert
smitty is offline
smitty's Avatar
Sex: Male
smitty has a spectacular aura aboutsmitty has a spectacular aura about
Old DIY: 03-04 Mesh Grill 09-29-2009 , 10:11 PM
This is a DIY to cheaply transform the ugly 03-04 plastic black grill into a slightly less ugly mesh grill.
Materials:
-1 sheet of mesh gutter-guard from Home Depot/Lowe's
-phillips screwdriver
-03-04 stock grill
-any color large zip ties
-small black zip ties
-pliers
-wire cutters
Here's mine finished:
01. Buy a sheet of mesh gutter guard in color of your preference ($2 or so).
02. Remove stock grill, it's just a series of plastic screws and push tabs.
03. Clean this dirty area under where the grill sits.
04. Line up the mesh gutter-guard with the top edge of the stock grill, and zip-tie it to the front of the grill using the grill’s mounting holes and large zip-ties (these will be cut off later, so color/looks doesn’t matter.
05. Cut the mesh with the wire cutters around the top edge of the grill, continuing to zip-tie them together as you do so.
06. Leave excess “flaps” of mesh off the sides of the grill, so that they can be wrapped around the sides.
07. Wrap the flaps around the sides of the grill, like so, zip-tie, and cut off excess mesh.
08. Use the pliers the bend the mesh along the bottom edge of the grill, still using large zip-ties to hold it in place.
- Enkei - Tsudo - Weapon R - HiFonics - Kicker - JL Audio - Infinity - Nexen -
Quote:
Drifted into any fat chicks lately?
#2
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 10:12 PM
09. This is how it should look thus far:
10. Now you have to deal with the corners of the mesh that stick out, between the bottom and sides.
11. This is probably the hardest part, basically you just need to get creative, bending with the pliers and cutting until the mesh sits flush with the grill in the corners, like so:
12. Now you want to go back with the wire-cutters and cut the mesh around all of the mounting holes.
13. Go around the edges of the grill, placing small black zip-ties in strategic locations where they will hold the mesh onto the grill but not be easily visible on the outside.
14. Cut the mesh out of this top section and place two small black zip-ties there as well.
#3
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 10:13 PM
15. Cut off all of the large zip-ties, and then cut off the excess of the small black ones.
16. Cut the mesh off of the grill’s end tabs.
17. Ready to be mounted:
18. Clean mounting points.
19. Mounting is reverse of removal.
Finished product:
I know it’s not for everyone, but I think it’s an improvement. Comments/suggestions welcome. See my sig for my other DIYs.
#4
Nema
NewTiburon.com God
Nema is offline
Nema's Avatar
Sex: Male
Nema
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 10:14 PM
Haha not bad!
2010 Genesis Coupe 3.8GT: Mirabeau Blue
#5
blue_915_tib
NewTiburon.com Professional
blue_915_tib is offline
blue_915_tib's Avatar
Sex: Male
blue_915_tib will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 10:16 PM
very nice! i might be doing this to my fugly 03 front end. thanks for the diy +1
| Spectre CAI | NGK plugs & wires | Apex'i exhaust | reinforced radiator hose set | bore increase - still slow | 8k hids | tinted tails | 5% window tint | clear corner DIY | MSR wheels | custom blue paint | 15" subs | 7" flip out monitor | fender bender = cracked front bumper & VIS carbon fiber hood FML
#6
korndog517
korndog517 is offline
korndog517's Avatar
Sex: Male
korndog517 will become famous soon enough
looks good, but you have to fix ur bumper sag on the left side, its pretty bad
2003 V6 6Speed
Engine: Injen SRI, Borla Catback, Spec Stage IV Clutch, Fidanza 9LB Flywheel, SSA Header, DUFFER TURBO KIT ON ITS WAY
Interior: Silver GT Trim, SAFC II, Zeitronix Wideband /w Laptop, Footwell Neon, Weighted Shift Knob, Ralco RZ STS,
Exterior: Repainted Fuel Door, 05-06 Stock Rims, Full Razzi Body Kit, T-Badges
#7
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 10:21 PM
Quote:
Yeah the whole bumper has a pretty bad sag actually, it was wrecked before I bought it and probably not fixed right, I'm gonna dive into it in the near future.
#8
Jgordon0505
NewTiburon.com God
Jgordon0505 is offline
Jgordon0505's Avatar
Sex: Male
Jgordon0505
Old Re: DIY: 03-04 Mesh Grill 09-29-2009 , 11:38 PM
I would recommend painting the mesh black. It will look a lot better IMO.
2003 Hyundai Tiburon i4
Mods: Fujita SRI, ARK Shorty Antenna, Red-Outs, Mesh Grille, Red Brake Calipers
Future Mods: Watch Spoiler Fade & Drivers Door Rust
NT Loves Insurance Fraud!.....124k and counting...
#9
Montmont
NewTiburon.com Novice
Montmont is offline
Montmont's Avatar
Sex: Male
Montmont is an unknown quantity at this point
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 12:01 AM
Quote:
I *think* they have black gutter guard. Not 100% sure though. That is a nice looking grill for such a cheap DIY, good post!
#10
tibbythetibron
tibbythetibron is offline
tibbythetibron's Avatar
Sex: Male
tibbythetibron has a little shameless behaviour in the past
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 12:10 AM
yea i want to do this now pretty bad
#11
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 02:35 PM
Quote:
Yeah they do have black, but I believe it's plastic, which I'm not sure how well that would work, but you could easily paint the metal any color.
Also for anyone interested if you look at my bumper there's the same mesh in there. That was just a matter of using 2 or 3 full strips of mesh and cutting the corners to fit in near the fogs and zip-tieing. Took a total of maybe 10 minutes.
You can't see it that clearly in this pic but look down by the fogs.
#12
sstaley
NewTiburon.com Newbie
sstaley is offline
Sex: Male
sstaley is an unknown quantity at this point
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 02:45 PM
im definitly gonna have to try this thanks man
#13
Tuscanirider
Member
Tuscanirider is offline
Tuscanirider's Avatar
Sex: Male
Tuscanirider will become famous soon enoughTuscanirider will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 02:50 PM
very well done
+rep for detailed DIY
Black KDM Tuscani
2.0L Turbocharged, Powered with KDMstuff
#14
JexeRican
JexeRican is offline
JexeRican's Avatar
Sex: Male
JexeRican
Old Re: DIY: 03-04 Mesh Grill 09-30-2009 , 08:45 PM
put some stuff that will keep it from rusting
hi
#15
javi1327
javi1327 is offline
javi1327's Avatar
Sex: Male
javi1327 is an unknown quantity at this point
Old Re: DIY: 03-04 Mesh Grill 10-05-2009 , 05:00 PM
Just finished mine...painting it black tomorrow thanks a lot man!
#16
ElDoradoshark03
ElDoradoshark03 is offline
ElDoradoshark03's Avatar
Sex: Male
ElDoradoshark03 is an unknown quantity at this point
Old Re: DIY: 03-04 Mesh Grill 10-05-2009 , 09:46 PM
awesome! im gonna have to do this but im gonna paint it black. thanks for such a detailed diy.
#17
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 10-07-2009 , 01:45 AM
Quote:
Originally Posted by ElDoradoshark03 View Post
awesome! im gonna have to do this but im gonna paint it black. thanks for such a detailed diy. also the avatar is now my backround so thanks for that too!!!
Right on, post up a pic when you're done, that will look dope on a white tib
#18
Fallen
Fallen is offline
Fallen's Avatar
Sex: Male
Fallen will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 10-20-2009 , 12:55 AM
Definetly a great DIY...
Im gonna paint my black though..
+1 for creativity and sharing..
#19
mazziod
mazziod is offline
mazziod's Avatar
Sex: Male
mazziod will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 10-20-2009 , 04:30 AM
yet another DIY I'm gonna do tomorrow...looks really good I was just sitting looking at the front of the grille today wondering if I could just get some mesh to cover it, and you confirmed it....10000x cheaper than the billet grille too
EDIT: I just did this! it looks so much better than stock...I'm happy with it! Thanks for the DIY
#20
smitty
smitty is offline
smitty's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 10-23-2009 , 07:15 PM
Welcome . Glad it turned out good.
I def prefer the billet grill and some of the other options out there, but when $ is tight you can't go wrong with $2 gutter guard lulz
#21
iscinshs606
iscinshs606 is offline
Sex: Male
iscinshs606
Old Re: DIY: 03-04 Mesh Grill 10-23-2009 , 08:46 PM
thats exactly what i did to mine, but instead of the plastic black things, i got some black superglue..
..superglue gets the job done
#22
03TibbyGuy
03TibbyGuy is offline
03TibbyGuy's Avatar
Sex: Male
03TibbyGuy will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 10-28-2009 , 12:51 AM
awesome! i just did this today and did my bumper to match. ill post pics tomorrow when i get the light. but looks way better
#23
C-Shark
NewTiburon.com God
C-Shark is offline
C-Shark's Avatar
Sex: Male
C-Shark will become famous soon enough
Old Re: DIY: 03-04 Mesh Grill 10-28-2009 , 01:16 AM
Quote:
Originally Posted by techn9ne View Post
this looks cheesy?
Yep, it actually does look cheesy. Personally, I am not a fan of those. I would take my grill over any of those.
Stimulating more than just the ecomony!
#24
03TibbyGuy
03TibbyGuy's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 10-28-2009 , 03:58 PM
im gonna agree that the C-mod grille is way too expensive for the look unless you have alot of spare money to waste which i dont and if i "was" going to spend that much money on a grille, it wouldnt be the C-mod, i'd go with the billet grille. So i just did this and my did my bumper also. looks way better. I know the cars a little dirty.
#25
03TibbyGuy
03TibbyGuy's Avatar
Sex: Male
Old Re: DIY: 03-04 Mesh Grill 10-28-2009 , 04:04 PM
This seriously makes a difference. Great DIY
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2009 www.newtiburon.com. All rights reserved.
Designed by XG3
