Quote:
Originally Posted by xryztyan
very nice!!!! but i wanted to do it before but did not find any way to remove the sub as ican see it was attached to a bolt on the box , where is that bolt, did not see it.
never mind man, just got it.
but one question how much power the stock amp can handle
The bolt goes through the end of that tube that has to be cut and screws into the back of the stock sub.
How much power can the stock amp handle? Do you mean the stock sub or how much power does the stock amp put out?
The stock amp puts out something like 40w RMS, so I would assume the stock sub cannot handle much more than that. You def want to power the replacement sub with an aftermarket amp.
This DIY is just to keep the clean look of the stock enclosure, I wouldn't recommend replacing the stock sub without replacing the stock amp too.
