Headlight Adjustment - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Appearance / Audio (03+) > Exterior
User Tag List
Reply
Thread Tools Display Modes
#1
dktiburon
NewTiburon.com Novice
dktiburon is offline
Sex: Male
dktiburon is an unknown quantity at this point
Old Headlight Adjustment 10-22-2009 , 03:35 AM
I have an 05 tiburon and just got some body work done. I drove it at night after and the headlights are basically pointing at the floor. ANyone know how to adjust the vertical angle of the headlights? If so pics would be great too. THANK YOU
Sponsored Links
Advertisement
#2
JGresch
NewTiburon.com Post Master
JGresch is offline
JGresch's Avatar
Sex: Male
JGresch is a splendid one to beholdJGresch is a splendid one to beholdJGresch is a splendid one to beholdJGresch is a splendid one to beholdJGresch is a splendid one to beholdJGresch is a splendid one to behold
Old Re: Headlight Adjustment 10-22-2009 , 03:36 AM
your bulbs might just be installed funny. The bulbs base shoudl align with the hole perfectly. I had this problem with opne foglight and it was due to it being a little loose and it was sagging.
look in the diy section for how to paint bezels or somethign that invovles taking it apart if you need pics.
lolwut
#3
dktiburon
Sex: Male
Old Re: Headlight Adjustment 10-22-2009 , 04:42 AM
so our car doesn't have a vertical adjuster?
#4
tibby07
NewTiburon.com God
tibby07 is offline
tibby07's Avatar
Sex: Male
tibby07 is just really nicetibby07 is just really nicetibby07 is just really nice
Old Re: Headlight Adjustment 10-22-2009 , 05:03 AM
Quote:
not that I have seen.
Quote:
robot cry solo.
how's that for a cool story bro anagram....
#5
dernt
NewTiburon.com God
dernt is offline
dernt's Avatar
Sex: Male
dernt is just really nicedernt is just really nicedernt is just really nicedernt is just really nice
Old Re: Headlight Adjustment 10-22-2009 , 09:50 AM
There are two adjusters for each light.
The horizontal low beam is partially blocked by the body work, vert low is easy to see and get to.
Quote:
If screaming into cones at other people is a sport, THEN CONSIDER MY CAPS LOCK THE SPORT OF THE INTERNET!
#6
tibby07
NewTiburon.com God
tibby07 is offline
tibby07's Avatar
Sex: Male
Old Re: Headlight Adjustment 10-22-2009 , 10:05 AM
thats good info to have I didnt think they were adjustable... should be the same type of adjustment for the 07/08 right?
Quote:
robot cry solo.
#7
dernt
NewTiburon.com God
dernt is offline
dernt's Avatar
Sex: Male
Old Re: Headlight Adjustment 10-22-2009 , 10:21 AM
It should be. HMAS doesn't have a good pick of the 07/08 HL, they only show 1 adjuster.
#8
Code Air
Gold member
Code Air is offline
Code Air's Avatar
Sex: Male
Code Air is a splendid one to beholdCode Air is a splendid one to beholdCode Air is a splendid one to beholdCode Air is a splendid one to beholdCode Air is a splendid one to beholdCode Air is a splendid one to behold
Old Re: Headlight Adjustment 10-22-2009 , 11:30 AM
Does anyone know which way to turn (left or right) the horizontal adjustment if you have your HIDs putting off a check design (right side goes up while drivers side stays flat and horizontal). I have seen a lot of people say they are supposed to be that way. But then I have seen someone with a F/L on here and in their avatar their HIDs are completely flat and horizontal?
Hyundai it's the Rodney Dangerfield of the automotive world.
Ignorance is curable (with knowledge), stupidity is not.
2011 October
#9
Richy.inc
NewTiburon.com Newbie
Richy.inc is offline
Sex: Male
Richy.inc is an unknown quantity at this point
Old Re: Headlight Adjustment 10-27-2009 , 03:12 AM
There should be adjustable bolts on the back of the headlights. There is one for low began and high beams as well. hope this helps
#10
xsv-speed
xsv-speed is offline
Sex: Male
xsv-speed can only hope to improve
Old Re: Headlight Adjustment 11-14-2009 , 11:47 AM
Excellent! I'm so glad I was able to find this info. I just put in new F/L headlights with angel eyes and they are WAY off compared to the aftermarket F/L's i got from SFR. TY TY TY!!!
#11
TuscaniGTFL
NewTiburon.com God
TuscaniGTFL is offline
TuscaniGTFL's Avatar
Sex: Male
TuscaniGTFL has a spectacular aura aboutTuscaniGTFL has a spectacular aura about
Old Re: Headlight Adjustment 11-14-2009 , 02:25 PM
some lights have 3 screws some have 4. if you bought your F/L headlights from SFR, they only have 3. and there is a way to adjust the vertical if you only have 3. You have to tighten the one on the bottom which pushes the light up. losening it brings the housing down. the two top ones control horizontal.
The old Tib, 03 GT 6-speed (we all know the clutch problems that had lol)
On the lookout for a new tib...maybe...
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
