rubbing noise when driving slow - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Wheel, Tire, & Suspension
User Tag List
Reply
Thread Tools Display Modes
#1
GtTiburonV6
NewTiburon.com Newbie
GtTiburonV6 is offline
GtTiburonV6's Avatar
Sex: Male
GtTiburonV6 is an unknown quantity at this point
Old rubbing noise when driving slow 02-02-2010 , 09:55 AM
When I am going slow I hear this nose that sounds like the brakes or rubbing or something but it doesnt make a sound when im braking. Also I barely have any hand brake left, I can pull the handle up with ease.
Sponsored Links
Advertisement
#2
bumbleski
NewTiburon.com Professional
bumbleski is offline
bumbleski's Avatar
Sex: Male
bumbleski will become famous soon enough
Old Re: rubbing noise when driving slow 02-02-2010 , 10:24 AM
Quote:
Well, disc brakes always rub unlike drum brakes so that might be a cause. How many miles on the brakes? Maybe you are hearing a wear sensor.
Also, the loose hand brake can be readjusted, I think there is a dyi for it. Check your rear brakes first tho because the looseness might be caused by worn out pads. If the pads are good, the cable can be adjusted to correct for wear and/or cable stretching.
So Long And Thanks For All The Fish
Ultra Racing Lower Front Chassis Bar, Front Strut Bar, Chassis/Room Bar, Ultra Racing Rear 23mm Rear Sway bar, Injen SRI, Billet Grill, Fog Light Surrounds, Tuscani Badging, Tuscani Floor Mats, Numerous Interior Alum Trim mods, DD led Mods, Rear Mussa Tailights, 07 Snowflake Wheels Powdercoated White, Curt trailer hitch, Roof Spoiler.
#3
mbradley2020
NewTiburon.com God
mbradley2020 is offline
mbradley2020's Avatar
Sex: Male
mbradley2020 will become famous soon enoughmbradley2020 will become famous soon enough
Old Re: rubbing noise when driving slow 02-02-2010 , 10:36 AM
Could be a wheel bearing. Or a dust cover rubbing your rotor. My bet is on the wheel bearing.
Quote:
I PHUCKING LOVE YOU !~!!!!
2003 Rally Red GT, T Badged, CIW Wheels, Custom Exhaust, Poly MMs, Nightshaded Tails, STS, Spec / Findanza Combo.
#4
GtTiburonV6
Sex: Male
Old Re: rubbing noise when driving slow 02-02-2010 , 11:15 PM
Well I dont know how many miles are on these brakes cause I just bought the car In August of last year and its a '03. But there is 93,XXX on the car itself
#5
joeyinthemix
NewTiburon.com Novice
joeyinthemix is offline
joeyinthemix's Avatar
Sex: Male
joeyinthemix is an unknown quantity at this point
Old Re: rubbing noise when driving slow 03-15-2010 , 10:12 PM
Hi! i just had the same or more or less the same issue, it was a rubbing noise when i turned left mostly and or at slow speeds. the rotors are new so are the pads...after 3 weeks i finally figured it out, in my case the LEFT rear caliper was misaligned. i took a level and found a diff of -.5 cm. on the bottom screw. so what i did was put a metal spacer with that width (.5cm) and tighted the screws and done. im a happy tiburon driver once again, hope it helps!
#6
nicknos
nicknos is offline
nicknos's Avatar
Sex: Male
nicknos is an unknown quantity at this point
Old Re: rubbing noise when driving slow 03-30-2010 , 01:22 PM
yeah i would figure out what side the noise is coming from and take off your caliper and check your sliders and check to see if the piston in the caliper is sticking alittle ...i wouldn't think its your wheel bearing unless you hear it all the time like at high and low speed but to be safe maybe check them out too.
NICHOLAS NAUSS
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
