so, there's a loud humming noise when i drive my car at any speed... - New Tiburon Forum : Hyundai Tiburon Forums
User Tag List
Reply
Thread Tools Display Modes
#1
Amongthechosenx
NewTiburon.com Expert
Amongthechosenx is offline
Sex: Male
Amongthechosenx is infamous around these parts
Old so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 01:34 AM
Mechanic claims its a bad wheel bearing, but he's already taken apart both driver side wheels and found nothing wrong....
he said maybe its the right, but i am doubtful..
Only thing I can think of is I had gotten a set of Sunny SN3800 tires, and the treads seem to be very loud... could this be it? this noise wasnt here before those tires.
Adam
Sponsored Links
Advertisement
#2
Rushr
Dave: NT Admin
Rushr is offline
Rushr's Avatar
Sex: Male
Rushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another levelRushr is on another level
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 01:46 AM
The tires could cause the humming noise, but I wouldn't think it would be that loud. Where does it sound like it is originating and does it get louder/faster sounding with speed? Mine did that and got to the point it sounded like I had mud tires on the Tib, it turned out to be one of the rear bearings.
#3
bill2
NewTiburon.com Novice
bill2 is offline
Sex: Male
bill2
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 07:11 AM
Quote:
Originally Posted by Amongthechosenx View Post
... and the treads seem to be very loud... could this be it? this noise wasnt here before those tires...
Absolutely. If there is any cupping or choppy wear on the tires they can make noises sounds identical to failed wheel bearings.
#4
dlanes
NewTiburon.com Post Master
dlanes is offline
dlanes's Avatar
Sex: Male
dlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to all
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 07:26 AM
Does it go away or sound different when you turn?
03 Tiburon GT 6 speed Assassin supercharged, NGM race shortblock, Stage 2 heads, NGM stage 1 cams, NGM 90mm throttle body, Hydra 2.6 EMS, 460cc inejectors, Bosch 190lph fuel pump, SSA headers/cat-back, 3.5" SRI, NGM twin disc clutch, Phantom grip LSD conversion, KJB delrin cable bushings, Mishimoto radiator, Ark 22mm rear sway bar, Vogtland springs, Koni adjustable shocks, MOOG endlinks & tie-rods, XG350 brake conversion.
#5
Amongthechosenx
Sex: Male
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 10:24 AM
Quote:
sometimes it does and sometimes it doesnt...
although i can definitely say that i think driving on fresh snow (where theres no friction from the pavement) produced less of the sound than normal...
Have a look here for some info on the tires:
http://www.iwsti.com/forums/gd-tires...ny-sn3800.html
It may very well be a right rear bearing... My mechanic only took apart the two driver side wheels... unfortunately this means im gunna have to give him $300 and i dont want to do that...
is there any way this can be a DIY thing?
Adam
Also heres a pic of the tread:
#6
bill2
bill2 is offline
Sex: Male
bill2
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 11:12 AM
Rear wheel bearing failures are common, and here is a thread that outlines the procedure:
http://www.newtiburon.com/forums/sho...d.php?t=175955
#7
VoodooXTC
NewTiburon.com God
VoodooXTC is offline
VoodooXTC's Avatar
Sex: Male
VoodooXTC has a spectacular aura aboutVoodooXTC has a spectacular aura aboutVoodooXTC has a spectacular aura about
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 11:16 AM
Jack up the right rear and put your hands at 3 and 9 o'clock and try wiggle the wheel then try 12 and 6 o'clock. It should be nice and tight if it's okay. If it moves, it's probably bad.
Quote:
dude you are fvcking mental..... and its awesome!!!
2003 GT 5spd Scattered through out my garage, shed and across North America.
1990 Eagle Talon AWD Turbo 5spd..........
#8
menudude
NewTiburon.com Professional
menudude is offline
menudude's Avatar
Sex: Male
menudude
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 02:07 PM
if its coming from just one area (drivers rear,drivers front,passengers rear,passengers front) then its the bearing. Mine did the same thing, bought a new one, replaced it, sounds gone
#9
TNT
and his new kimchi coupe
TNT is offline
TNT's Avatar
Sex: Male
TNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another level
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 03:29 PM
If the noise wasn't there before the tires, then its probably the hard compound of the tires. My friend had a subaru legacy turbo with cheap Triangle brand tires that sounded like big knobby truck tires because the compound was so dense.
Gone, but not forgotten: 2003 GT V6 6MT in Jet Black @ 102,000 mi
Traded: Early 2003 GT V6 Auto in Super Silver @ 194,869 mi
Current: 2011 Genesis Coupe 3.8 6MT in Silverstone
#10
jeih332003
jeih332003 is offline
jeih332003's Avatar
Sex: Male
jeih332003 will become famous soon enough
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 04:50 PM
i did both of my rears in about an hour , rockauto has them cheap i dunno if any of our sponsors carry them but i had mine in 2 days and i got timkens for replacement , i think the worste part of the job was removing the philips screw in the rotor
#11
jesterking
NewTiburon.com God
jesterking is offline
jesterking's Avatar
Sex: Male
jesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond reputejesterking has a reputation beyond repute
100% positive it is the tires. I have a loud noise with my tires as well... They are cheap Chinese tires and they like to sing while at speed.
Solution, don't be cheap like me and get good (non-Chinese) tires.
Quote:
I've seen worse things on teh ol' internetz than this question. I grew up on teh internetz. Teh internetz iz mah hood, mah people.
Quote:
Maybe you shouldn't visit the depths of the...
Quote:
You may as well pork the pregger.
Start off with a regret and every other time is better by comparison.
#12
menudude
menudude is offline
menudude's Avatar
Sex: Male
menudude
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 05:26 PM
Quote:
Ha ha and make sure you have a 1 1/4 socket
#13
TNT
TNT is offline
TNT's Avatar
Sex: Male
Old Re: so, there's a loud humming noise when i drive my car at any speed... 02-03-2010 , 05:41 PM
Yep. I did my right side last night. Doesn't hurt to lay down some extra red grease on the end of the hub/axle and on the journals where the bearing spins. Just follow the diy, it's very detailed.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
