Go Back   NewTiburon.com > Information > Do It Yourself
Closed Thread
Thread Tools Display Modes
#1
TuscaniFX
NewTiburon.com Post Master
TuscaniFX is offline
TuscaniFX's Avatar
Sex: Male
TuscaniFX is an unknown quantity at this point
Old ***Common DIY URL Links are here*** 01-25-2004 , 03:43 PM
For user ease, we have compiled a list of the most commonly sought after DIY's.
Lighting
DIY New Clear Corners with Painting Tips
http://www.newtiburon.com/forums/showthread.php?t=91968
DIY 05 Headlight Wiring conversion to fit 03or04
http://www.newtiburon.com/forums/showthread.php?t=40681
DIY Clear Tail Lights Modification
http://www.newtiburon.com/forums/showthread.php?t=33
DIY Clear Rear Tail Light
http://www.newtiburon.com/forums/showthread.php?t=6546
DIY Clear Door Light Lense
http://www.newtiburon.com/forums/showthread.php?t=36
DIY Fog Light Ring Removal
http://www.newtiburon.com/forums/showthread.php?t=62
DIY Fog Light
http://www.newtiburon.com/forums/showthread.php?t=34
DIY Yellow Foglight
http://www.newtiburon.com/forums/sho...d.php?t=100164
DIY LED Project
DIY Updated LED Project
http://www.newtiburon.com/forums/showthread.php?t=31621
DIY Interior LED Conversion by Speedy - Updated to 2008
http://newtiburon.com/forums/showthread.php?t=145569
DIY Angel Eyes
http://www.newtiburon.com/forums/showthread.php?t=86979
DIY EL Cable Angel Eyes
http://www.newtiburon.com/forums/showthread.php?t=2422
DIY Grill Lights
http://www.newtiburon.com/forums/showthread.php?t=42
DIY Grounding Cable
http://www.newtiburon.com/forums/showthread.php?t=4260
DIY BCM Turn Signal Relay Fix
http://www.newtiburon.com/forums/sho...d.php?t=102241
DIY Alfa Otto Reverse Indiglow Gauge Install
http://www.newtiburon.com/forums/sho...58#post2101958
DIY HIDs on an 03-06
http://www.newtiburon.com/forums/sho...d.php?t=124180
DIY HIDs + Harness on an 07
http://www.newtiburon.com/forums/sho...d.php?t=106984
Interior
Passenger Cup Holder DIY
http://www.newtiburon.com/forums/showthread.php?t=3763
Center Vent Ring Removal for mod DIY
http://www.newtiburon.com/forums/showthread.php?t=7339
Steering Wheel Emblem (Removal and Replacement)
http://www.newtiburon.com/forums/showthread.php?t=3150
How Remove The Headrest Covers DIY
http://www.newtiburon.com/forums/sho...590#post697590
Hatch Rattle Removal DIY
http://www.newtiburon.com/forums/showthread.php?t=607
ECU Diy
http://www.newtiburon.com/forums/showthread.php?t=263
OEM Handsfree Mobile Kit DIY
http://www.newtiburon.com/forums/showthread.php?t=39
OEM Subwoofer Improvement DIY
http://www.newtiburon.com/forums/showthread.php?t=44
2 Seater Conversion DIY
http://www.newtiburon.com/forums/showthread.php?t=1381
Multi-Gauge Install DIY
http://www.newtiburon.com/forums/sho...ght=multigauge
Window Motor DIY
http://www.newtiburon.com/forums/showthread.php?t=90376
CarPC DIY
http://www.newtiburon.com/forums/showthread.php?t=81264
Fiberglassed Sub Enclosure DIY
http://www.newtiburon.com/forums/showthread.php?t=95990
Safety DIY -- Trunk Fire Extinguisher DIY
http://www.newtiburon.com/forums/showthread.php?t=95460
DIY: Interior Door Handle (Latch/Lock Assembly) Replacement
http://www.newtiburon.com/forums/sho...d.php?t=123340
DIY: Interior Door Panel Removal & Installation
http://www.newtiburon.com/forums/sho...d.php?t=123339
Exterior & engine
C/F Hood and Hood Pin Install DIY
http://www.newtiburon.com/forums/sho...d.php?t=110857
Budget-Friendly Hood Prop For CF Hoods DIY
http://www.newtiburon.com/forums/sho...d.php?t=113122
Painting Over "Tuscani" on Center Caps (for those with "Tiburon" T badges) DIY
http://www.newtiburon.com/forums/sho...d.php?t=107573
03/04 to 05 Front Bumper Conversion DIY
http://www.newtiburon.com/forums/sho...18#post2314618
Mesh Grill DIY
http://www.newtiburon.com/forums/showthread.php?t=1203
Wheel Caps Removal/Exchange DIY
http://www.newtiburon.com/forums/showthread.php?t=16630
DIY Spoiler Removal and Replacement
http://www.newtiburon.com/forums/showthread.php?t=3367
DIY Wingless w/ plugs
http://www.newtiburon.com/forums/sho...d.php?t=107101
DIY 3rd Brake Light upgrade for wingless Tibs
http://www.newtiburon.com/forums/showthread.php?t=98836
OEM Emblem Removal DIY
http://www.newtiburon.com/forums/showthread.php?t=7758
Door Handles Dis-assembley DIY
Door Handles DIY (simple)
http://www.newtiburon.com/forums/showthread.php?t=43
Door Chime DIY
http://www.newtiburon.com/forums/sho...693#post338693
Folding Mirrors DIY (from old forum)
http://www.newtiburon.com/yabbse/ind...;threadid=5042
Painting Rear Diffuser DIY
http://www.newtiburon.com/forums/showthread.php?t=67771
Metallic Fuel Door and Ring DIY
http://www.newtiburon.com/forums/showthread.php?t=95118
Fender Rolling DIY
http://www.newtiburon.com/forums/showthread.php?t=97154
Tuscani Caliper Stickers Application DIY
http://www.newtiburon.com/forums/showthread.php?t=7087
Painted Calipers DIY
http://www.newtiburon.com/forums/showthread.php?t=11845
Brake Rotor/Pads DIY
http://www.newtiburon.com/forums/showthread.php?t=97763
SFR Big Brake Kit Install
http://www.newtiburon.com/forums/showthread.php?t=99181
Coilovers DIY
http://www.newtiburon.com/forums/showthread.php?t=594
Installing Progressive Rear Sway DIY
http://www.newtiburon.com/forums/sho...d.php?t=124981
Resonator Removal DIY
http://www.newtiburon.com/forums/sho...610#post189610
Home Made Cold Air Intake CAI Mod
http://www.newtiburon.com/forums/showthread.php?t=2495
Front and Rear Struts Bar Install
http://www.newtiburon.com/forums/showthread.php?t=1758
Slave Cylinder Valve Removal DIY
http://www.newtiburon.com/forums/showthread.php?t=1962
DIY Clutch and flywheel GK 6 speed transmission
http://www.newtiburon.com/forums/sho...d.php?t=107891
Manual Transmission Gear Oil Change DIY
http://www.newtiburon.com/forums/sho...d.php?t=120043
V6 Valve Covers Install/Removal DIY
http://www.newtiburon.com/forums/showthread.php?t=1765
V6 Upper and Lower Manifold Install/Removal DIY
http://www.newtiburon.com/forums/showthread.php?t=1760
DIY Polished Fuel Rails
http://www.newtiburon.com/forums/sho...99#post1143799
TB / BBTB removal / reinstall
http://www.newtiburon.com/forums/sho...+Throttle+body
V6 Headers Install DIY
http://www.newtiburon.com/forums/showthread.php?t=2784
i4 Header Install
http://www.newtiburon.com/forums/sho...d=1#post325189
Lightweight Crank Pulley Install DIY
http://www.newtiburon.com/forums/sho...d.php?t=105584
Installing Walbro 255 fuel pump DIY
http://www.newtiburon.com/forums/showthread.php?t=67605
Adjustable fuel pressure regulator DIY
http://www.newtiburon.com/forums/sho...d.php?t=112437
Mounting FPR+walbro fuel pump (i4) DIY
http://www.newtiburon.com/forums/sho...d.php?t=123941
Removing Trim Parts and Painting Tips DIY
http://www.newtiburon.com/forums/showthread.php?t=1172
AC Refill DIY
http://www.newtiburon.com/forums/showthread.php?t=97684
DIY Ark Short Shifter
http://newtiburon.com/forums/showthread.php?t=137391
Thanks
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
