Head Gasket (can i change it myself?) - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#1
Anthonyc77
NewTiburon.com Professional
Anthonyc77 is offline
Anthonyc77's Avatar
Sex: Male
Anthonyc77 will become famous soon enough
Old Head Gasket (can i change it myself?) 03-30-2010 , 07:59 PM
So yah my head gasket is leaking oil onto my headers, and it needs to be changed, but im wondering, i this something I can do myself (how difficult is it?) or should I just pay a mechanic to do it even though they charge ALOT of money.
11 Forte Koup EX
Visual Mods: "K" badges, tint
Performance Mods: None yet
Wishlist: Intake, rims,exhaust
Sponsored Links
Advertisement
#2
markstibbyspot
NewTiburon.com Post Master
markstibbyspot is offline
markstibbyspot's Avatar
Sex: Male
markstibbyspot is a glorious beacon of lightmarkstibbyspot is a glorious beacon of lightmarkstibbyspot is a glorious beacon of lightmarkstibbyspot is a glorious beacon of lightmarkstibbyspot is a glorious beacon of light
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:08 PM
are you sure its the head gasket
Work in progress
#3
Anthonyc77
Anthonyc77's Avatar
Sex: Male
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:21 PM
Well after pushing it a little hard, i poped the hood and saw the oil drip down off the head between the cracks onto the exhaust manifold, so im prettty sure its the gasket.
11 Forte Koup EX
#4
dlanes
dlanes is offline
dlanes's Avatar
Sex: Male
dlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to all
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:25 PM
I bet you mean valve cover gasket...If it was your head gasket and you would have more problems than oil on your headers.
03 Tiburon GT 6 speed Assassin supercharged, NGM race shortblock, Stage 2 heads, NGM stage 1 cams, NGM 90mm throttle body, Hydra 2.6 EMS, 460cc inejectors, Bosch 190lph fuel pump, SSA headers/cat-back, 3.5" SRI, NGM twin disc clutch, Phantom grip LSD conversion, KJB delrin cable bushings, Mishimoto radiator, Ark 22mm rear sway bar, Vogtland springs, Koni adjustable shocks, MOOG endlinks & tie-rods, XG350 brake conversion.
#5
Anthonyc77
Anthonyc77's Avatar
Sex: Male
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:32 PM
Quote:
Yah i think that is what i mean, because other then that the car seems to run fine, its just leaking oil out. But about the difficulty on changing this, is it easy or difficult or what? Is it as easy as just taking the head apart and changing the gasket or what?
11 Forte Koup EX
#6
Will51
Retired Staff
Will51 is offline
Will51's Avatar
Sex: Male
Will51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another level
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:33 PM
Could be pushing oil externally and be a head gasket but more than likely it would be pushing coolant as well. I would put my money on piston rings/ valve seals letting oil into your combustion chamber, look for smokey exhaust, and pull your spark plugs and look for oil on them. Also have a shop use a "sniffer" on your coolant reservoir to look for combustion gases and pull your dipstick and look for milky/chunky substances. If you have combustion gases in the coolant or stuff on your dipstick or overheating or unexplained loss of coolant its your head gasket. If neither of these are present I would lean toward piston rings or valve seals.
For quickest response regarding ZMR Mods please email me at
#7
Will51
Retired Staff
Will51 is offline
Will51's Avatar
Sex: Male
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:35 PM
Quote:
Post pics and we can tell if its a valve cover gasket.
#8
iplayapearl
iplayapearl is offline
iplayapearl's Avatar
Sex: Male
iplayapearl
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:44 PM
head gaskets suck...got to taking everything in the head apart, clean everything perfectly, you have to take it to a machine shop to get shaved (at least thats the right way to do it)...its a handful if you dont know how to do it or never done something like that before...but if you do it do the timing belt and water pump and thank me later
Garrett–ARK–AutoMeter–HKS–ExtremePSI–AEM-Fidanza-ACT–TriNET Motorsports– Koni–OBX-R–DropZone
Black Cat Customs–DS Motorsports–OTTO-R–KENWOOD–JL AUDIO–Xentec–Kemmerer Graphics–KONIG-Nankang
#9
UnHolyTib
NT's Death Knight
UnHolyTib is offline
UnHolyTib's Avatar
Sex: Male
UnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond repute
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:50 PM
Quote:
Come on bro... grim reaper much?... it's the kids valve cover gasket...
OP, the valve cover gasket normally doesn't need to be replaced, they are made of rubber, remove the valve cover, remove all the sealant the factory used, clean everything up, coat everything with hi temp RTV and put it back together.. no more leak
You Are Only As Good As Your Last Idea! /
#10
nwsfoto
NewTiburon.com God
nwsfoto is offline
nwsfoto's Avatar
Sex: Male
nwsfoto will become famous soon enough
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:51 PM
Quote:
Originally Posted by unholytib View Post
come on bro... Grim reaper much?... It's the kids valve cover gasket...
Op, the valve cover gasket normally doesn't need to be replaced, they are made of rubber, remove the valve cover, remove all the sealant the factory used, clean everything up, coat everything with hi temp rtv and put it back together.. No more leak
+1.
NT's TV Guy (ABC)
#11
Will51
Retired Staff
Will51 is offline
Will51's Avatar
Sex: Male
Old Re: Head Gasket (can i change it myself?) 03-30-2010 , 08:53 PM
LOL No, just the things he could do to diagnose before tearing into it. It sounded to me like he was saying it was pushing oil out of the manifolds, in my experience the rings are usually what causes this it wasnt until after I posted and then saw his second post about them dripping onto them from above . Thats why I asked him to post pics to see if he was talking about the valve cover gasket after I read his second post..
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
