stock injectors - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Forced Induction
User Tag List
Reply
Thread Tools Display Modes
#1
DBrady08
NewTiburon.com Newbie
DBrady08 is offline
DBrady08's Avatar
Sex: Male
DBrady08 has a little shameless behaviour in the past
Old stock injectors 04-13-2010 , 06:52 AM
i am putting a supercharger in my 08 v6 2.7L tib, and i want to know what are the stock injectors for the 08. and if the injectors they see will fit the tib or will i have to get them off of the V6 sonanta. and if i have to would that be a stock sonata?
Thanks
DBrady
2008 Black Tiburon GT V6 2.7L Custom exhaust with SS muffler, 1000 watt magnum subs and amp, Pioneer Double Din HeadUnit, 2 blue interior L.E.D lights, 5% Tint all around, MORE TO COME!!!
Sponsored Links
Advertisement
#2
dmdicks
dmdicks is offline
dmdicks's Avatar
Sex: Male
dmdicks is just really nicedmdicks is just really nicedmdicks is just really nicedmdicks is just really nice
Old Re: stock injectors 04-13-2010 , 07:27 AM
What are you asking? If the 08 Tiburon injectors will fit your 08 Tiburon? lol
Or if if 2008 Sonata injectors will fit your 08 Tiburon, which would be a no.
If you want to get the injectors off a Sonata you need the 2.4L version between 01-and 04 I think.
#3
Will51
Retired Staff
Will51 is offline
Will51's Avatar
Sex: Male
Will51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another levelWill51 is on another level
Old Re: stock injectors 04-13-2010 , 07:29 AM
More info needed, what SC are you putting on? Most kits that require a bigger injector size come with the kit from NGM. What do you mean by "the injectors they see"?
For quickest response regarding ZMR Mods please email me at
#4
DBrady08
DBrady08 is offline
DBrady08's Avatar
Sex: Male
Old Re: stock injectors 04-13-2010 , 08:01 AM
Quote:
im putting on the sniper stage 1 S/C
#5
Fullblowntib
NewTiburon.com God
Fullblowntib is offline
Fullblowntib's Avatar
Sex: Male
Fullblowntib is a glorious beacon of lightFullblowntib is a glorious beacon of lightFullblowntib is a glorious beacon of lightFullblowntib is a glorious beacon of lightFullblowntib is a glorious beacon of lightFullblowntib is a glorious beacon of light
Old Re: stock injectors 04-13-2010 , 10:24 AM
Then you dont need injectors....your stock ones will hang all day on the stg1 setup
[/SIGPIC]NGM Stg4 fully built race blk w/fully P&P & flowed heads,Stg2 cams,Fidanza adjstbl sprckts & adjstble cam gears,1mm over Stainless steel valves,NGM Assassin S/C w/icebox & ht exchngr,NGM alky kit,7.5 in lower pully & 2.9 upper,ported lower intake,90mm throttlebody,Map ecu2,460cc injctrs,Zex 190Lph fuel pmp,Zex 150 shot,APE traction bars,Fidanza alum flywl, w/stg4 CM 6puc clutch,Phantom grip LSD,Espilar susp kit,custom SRI,Prosport boostgauge & Innovate w/b
#6
iwb
NewTiburon.com God
iwb is offline
iwb's Avatar
Sex: Male
iwb is a glorious beacon of lightiwb is a glorious beacon of lightiwb is a glorious beacon of lightiwb is a glorious beacon of lightiwb is a glorious beacon of light
Old Re: stock injectors 04-13-2010 , 11:54 AM
Quote:
^^^ This
I was running my Stage 1 on the stock 190cc injectors untuned for over a year without any problem. I suggest you do get all the fuel management (Piggy Back, Wideband combo) in the future, but until you're smaller than a 3.4 pulley the stock injectors should keep up untuned.
If you do buy larger injectors, you are going to need a Piggyback tuner so that you could compensate for the increase in fuel. The 290cc injectors from the Santa Fe and the Sonata (only found in the 4 cyl version, so you would have to find another 2 if you bought that set) run at 33% higher capacity than the 190's, so your tuner would need to be set -33 across the board for them to run at the stock level.
Message me if you want a good price on some 290's and you have fuel tuning planned. I know where to get a set almost brand new, with the fuel rail for $120.
. I . W a n t . B o o s t .
Former Stage 2 Sniped Tib - Forever a GK enthusiast
#7
breeechan
Dedication to Thai Cuisine
breeechan is offline
breeechan's Avatar
Sex: Male
breeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud ofbreeechan has much to be proud of
Old Re: stock injectors 04-13-2010 , 12:01 PM
I really hope you are ESL... and yes, the stock injectors will work fine on stage 1.
Lightest DD tib? 2593 lbs and falling
Quote:
I wish I had 5 Guys inside of me right now...
Quote:
That is pretty much how I felt the first time I had Five Guys...
#8
DBrady08
DBrady08 is offline
DBrady08's Avatar
Sex: Male
Old Re: stock injectors 04-13-2010 , 02:16 PM
Quote:
so i dont have to get my car tuned until i get a 3.4 pulley? yea im goin to get the piggybank the wideband, the oil pressure and the boost gauges. so as long as i have a pulley smaller then a 3.4 i wont have to get it tuned? now if i wanted to get my car tuned will i be able to? and how come u have to get the injectiors off of the sonata? and the stock injectors for the 08 tib is 190CC?
#9
MisterTib
NewTiburon.com God
MisterTib is offline
MisterTib's Avatar
Sex: Male
MisterTib is just really niceMisterTib is just really niceMisterTib is just really nice
Old Re: stock injectors 04-13-2010 , 05:54 PM
DON"T get a pulley smaller than 3.4, smaller pulley on the blower means MORE boost!
NGM/Alpine Stage 2,NGM Budget short block, NGM reflash, Injen CAI, Hot Shots, Mussa single, Fidanza, South Bend OFE,Ralco STS, Kart Boy shifter bushings, Weapon R Dampner,Sun Hyper Ground, Amsoil dual-remote bypass filter . 277 HP 243 TQ 7.5 psi, Mustang Dyno
"I don't mind if she whines, it means I'm getting blown!"
#10
iwb
NewTiburon.com God
iwb is offline
iwb's Avatar
Sex: Male
Old Re: stock injectors 04-14-2010 , 12:43 AM
Quote:
Heh, yeppo, the smaller the pulley the faster the blower spins producing more boost. 3.5" = 2-3 PSI VS. 2.8" = 7-9 PSI
Simple physics like gearing on a bike, a smaller pulley/gear means the shaft spins faster.
#11
breeechan
breeechan's Avatar
Sex: Male
Old Re: stock injectors 04-14-2010 , 12:53 AM
Quote:
you can get a 3.2 (some say 3.1) inch pulley without tuning. You need a piggyback tuner to tune, or a reflashed ECU. The stock injectors are 190cc, most people get 290cc once they up the boost on the supercharger, those will deliver enough fuel to take you to the limits of the stock block.
#12
dlanes
NewTiburon.com Post Master
dlanes is offline
dlanes's Avatar
Sex: Male
dlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to all
Old Re: stock injectors 04-14-2010 , 03:17 AM
I thought the stage 1 pulley was 3.4? Only my assassin came with 3.5. Anyways with the alpine stage 1 setup no tuning was need the afr was very acceptable. Pulley drop the afr was a little leaner than I like with a slightly smaller pulley so I went back to the 3.4 then 290s and 2.75 / 6.5 crank and now moving up to a bigger s/c.
03 Tiburon GT 6 speed Assassin supercharged, NGM race shortblock, Stage 2 heads, NGM stage 1 cams, NGM 90mm throttle body, Hydra 2.6 EMS, 460cc inejectors, Bosch 190lph fuel pump, SSA headers/cat-back, 3.5" SRI, NGM twin disc clutch, Phantom grip LSD conversion, KJB delrin cable bushings, Mishimoto radiator, Ark 22mm rear sway bar, Vogtland springs, Koni adjustable shocks, MOOG endlinks & tie-rods, XG350 brake conversion.
#13
kdsalas
NewTiburon.com Expert
kdsalas is offline
kdsalas's Avatar
Sex: Male
kdsalas
Old Re: stock injectors 05-12-2010 , 11:01 PM
lol I will tell you my firsts and last set up's on my Tib 2007 2.7l V6........first set up was a NGM Stage 1 with a 3.5" with the stock injectors running OK but with 2lb of boost, next I change to a 3.1" with the stock injectors running 5.5lb of boost but my engine going to blow with a result of 18 on the fuel graphics on the Dyno on 5500 rpm, next I install a 290cc Santa Fe injectors (w/o Piggyback, stock ecu) and on the first months I need to push the gas when the car was in normal temperature when I star the car only, next the car run perfect but in the last month I do not need to push the gas anymore in normal temperature when I star the car what happen I do not know but is perfect , I drive my car daily and work perfect with the 3.1" and the 290cc Injectors making 5.5lb of boost without a piggy back & stock ecu, now I will look for a 2.8" to see how my car run on 7lb of boost with the 290cc injectors if I get a good result on the fuel graphics I stop there for the mean time......................
Good luck....
KS
K&N CAI, Headers, Tsudo Catback, ARK Pullys,TWM Short Shifter, Weapon-R Damper, Ground Wire Kit, Voltage Stabilizer, Konig Zero Wheels, Stop Tech Brake line Kit, Rotors Drill/Slotted & Painted Calipers, Eibach Springs, Sniper Kit Stage 1 w/ 3.1" 290cc Injectors w/ Stock ECU . !
#14
bxny1984
NewTiburon.com Professional
bxny1984 is offline
Sex: Male
bxny1984
Old Re: stock injectors 05-13-2010 , 12:46 AM
Yo if you go on NGM you can tell what pulley gives you more power. This dude needs to search more
#15
dmdicks
dmdicks is offline
dmdicks's Avatar
Sex: Male
Old Re: stock injectors 05-13-2010 , 08:12 AM
Quote:
Originally Posted by kdsalas View Post
lol I will tell you my firsts and last set up's on my Tib 2007 2.7l V6........first set up was a NGM Stage 1 with a 3.5" with the stock injectors running OK but with 2lb of boost, next I change to a 3.1" with the stock injectors running 5.5lb of boost but my engine going to blow with a result of 18 on the fuel graphics on the Dyno on 5500 rpm, next I install a 290cc Santa Fe injectors (w/o Piggyback, stock ecu) and on the first months I need to push the gas when the car was in normal temperature when I star the car only, next the car run perfect but in the last month I do not need to push the gas anymore in normal temperature when I star the car what happen I do not know but is perfect , I drive my car daily and work perfect with the 3.1" and the 290cc Injectors making 5.5lb of boost without a piggy back & stock ecu, now I will look for a 2.8" to see how my car run on 7lb of boost with the 290cc injectors if I get a good result on the fuel graphics......................
Good luck....
KS
Why do you think you can safely run your car on the stock ECU and 290cc injectors? Your engine is a ticking timebomb so I hope you have money for a new one when this one blows up. Your fuel trims have got to be so whacked out its not even funny.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
