How to Fix a Faulty Throttle Position Sensor (TPS) - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#1
NavyGuy91
NewTiburon.com Rookie
NavyGuy91 is offline
Sex: Male
NavyGuy91 is an unknown quantity at this point
Old How to Fix a Faulty Throttle Position Sensor (TPS) 06-02-2010 , 10:11 AM
So I think the issue I have been having with my car is due to a problem with my TPS.
First: is the TPS the piece located on the oppsite side of the throttle? Is there only one sensor in the TPS?
How can I try to fix the TPS? Should I buy a new one?
Any help would be much appreciated.
Sponsored Links
Advertisement
#2
dmdicks
dmdicks is offline
dmdicks's Avatar
Sex: Male
dmdicks is just really nicedmdicks is just really nicedmdicks is just really nicedmdicks is just really nice
Old Re: How to Fix a Faulty Throttle Position Sensor (TPS) 06-02-2010 , 11:36 AM
Are you getting any malfunction codes? The TPS is on the part of the throttle body that faces the ground.
#3
kcantread
kcantread is offline
kcantread's Avatar
Sex: Male
kcantread is an unknown quantity at this point
Old Re: How to Fix a Faulty Throttle Position Sensor (TPS) 06-17-2010 , 08:08 PM
mine melted, cost me about $70 installed as I recall, at around 65,000 miles, wish I'd done it myself but was busy so had the dealer do it. better to get it done
#4
dlanes
NewTiburon.com Post Master
dlanes is offline
dlanes's Avatar
Sex: Male
dlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to alldlanes is a name known to all
Old Re: How to Fix a Faulty Throttle Position Sensor (TPS) 06-17-2010 , 11:51 PM
I bought one at the dealer a 2 years ago and it was $70+tax. Just replace it.
03 Tiburon GT 6 speed Assassin supercharged, NGM race shortblock, Stage 2 heads, NGM stage 1 cams, NGM 90mm throttle body, Hydra 2.6 EMS, 460cc inejectors, Bosch 190lph fuel pump, SSA headers/cat-back, 3.5" SRI, NGM twin disc clutch, Phantom grip LSD conversion, KJB delrin cable bushings, Mishimoto radiator, Ark 22mm rear sway bar, Vogtland springs, Koni adjustable shocks, MOOG endlinks & tie-rods, XG350 brake conversion.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
