canister purge valve - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#1
liquidnyquiz
NewTiburon.com Novice
liquidnyquiz is offline
Sex: Male
liquidnyquiz
Old canister purge valve 11-17-2010 , 01:58 AM
I have two codes:
P0102 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – low input Wiring short to ground, MAF/VAF sensor, ECM
P0444 Evaporative emission (EVAP) canister purge valve – open circuit Wiring open circuit, EVAP canister purge valve, ECM
Where is the canister purge valve located? (2003 Tiburon GT). The picture is not very clear in the manual and can not make out the location.
Sponsored Links
Advertisement
#2
Takahashi240
Hater With No Friends
Takahashi240 is online now
Takahashi240's Avatar
Sex: Male
Takahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another levelTakahashi240 is on another level
Old Re: canister purge valve 11-17-2010 , 02:48 AM
That will give you an idea of roughly where it is in the fuel system. I don't know exactly where it is on the Tiburon, though.
Mr Köppen is so like the fat woman full of vitality. ! !
#3
UnHolyTib
NT's Death Knight
UnHolyTib is offline
UnHolyTib's Avatar
Sex: Male
UnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond reputeUnHolyTib has a reputation beyond repute
Old Re: canister purge valve 11-17-2010 , 07:14 AM
Purge valve is located directly under the throttle body on the V6 - it hangs from a bracket bolted to the head below the rear valve cover - that code is normally thrown when the gas cap is not tight or has failed.
You Are Only As Good As Your Last Idea! /
#4
liquidnyquiz
Sex: Male
liquidnyquiz
Old Re: canister purge valve 11-17-2010 , 12:44 PM
Thank you all.
#5
Takahashi240
Sex: Male
Old Re: canister purge valve 11-17-2010 , 01:42 PM
Quote:
That's what I thought, but I wasn't 100% sure.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
