car will start but wont stay running??? - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > Information > Hyundai Tech
User Tag List
Reply
Thread Tools Display Modes
#1
drknight24
NewTiburon.com Newbie
drknight24 is offline
Sex: Male
drknight24 is an unknown quantity at this point
Old car will start but wont stay running??? 01-23-2011 , 10:35 AM
ok i have a 2004 tiburon gt v6, i just painted the valve covers, intake manifold and throttle body and did new sparkplugs along with pulled my a/c and went to the non ac serpentine belt. also i put new gaskets for valve covers and intake manifold and throttle body along with idle air control valve. now labeled everything so its all back in correct places. and now my car wont stay running. its been two months on this project. it will start and you can rev it up to like 3k then it will just fall on its face and die. does anyone have any suggestions?
thanks shane
Sponsored Links
Advertisement
#2
mayom15
NewTiburon.com God
mayom15 is offline
mayom15's Avatar
Sex: Male
mayom15 has a spectacular aura aboutmayom15 has a spectacular aura about
Old Re: car will start but wont stay running??? 01-23-2011 , 10:50 AM
you have a vacuum leak somewhere. just need to go over and check all hose connections and any spot where you bolt on parts that air can get into. most likely its probably the throttle body as a lot of people seem to put it on wrong after they have it off
#3
ref1590
NewTiburon.com Novice
ref1590 is offline
Sex: Male
ref1590 is an unknown quantity at this point
Old Re: car will start but wont stay running??? 01-23-2011 , 11:16 AM
yea it def sounds like a vaccum leak man like he said ^, check the vac lines for sure, thats the only thing that sounds like it would do that
#4
drknight24
Sex: Male
Quote:
ok i will check all of my hoses and the trottle body over. if i find anything or i dont. i will repost. thanks for the suggestion i really appreciate it.
shane
#5
drknight24
Sex: Male
Old Re: car will start but wont stay running??? 04-13-2011 , 10:55 PM
so problem was gasket between plenums was not tight seems some left over in plenum had gotten onto the gasket. also had a short to power on my crankshaft signal wire. all set now. thanks everyone
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
