Remove hub from axle to get off ball joint? - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Wheel, Tire, & Suspension
User Tag List
Reply
Thread Tools Display Modes
#1
Hurdler5280
NewTiburon.com God
Hurdler5280 is offline
Hurdler5280's Avatar
Sex: Male
Hurdler5280
Old Remove hub from axle to get off ball joint? 02-08-2011 , 11:14 PM
I'm going to replace my ball joints. When I checked out the clearance to get to the nut holding the ball joint to the hub there is minimal room because of the axle. It appears like Im going to have to remove the hub from the axle. Is this what others have done or am I missing something?
Going back to stock
Someone buy my Stage IV, Ark Exhaust, mafterburner, new SFR headers with Jet hot coat and more!!.
Sponsored Links
Advertisement
#2
lukeman
PlastiDip Mod
lukeman is offline
lukeman's Avatar
Sex: Male
lukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud of
Old Re: Remove hub from axle to get off ball joint? 02-08-2011 , 11:34 PM
nope i remove mine with a wrench or a pair of adjustable's, once it starts lowering you will have more and more room, if you want to use an impact or socket wrench then yes you will have to remove it. now if the ball joint starts turning then you will have to get some vice grips in there to hold the ball joint while you remove the nut. heat may be necessary.
also just so you know the ball joint is pressed in so you will have to get it pressed out, and the new one pressed in. i tried to find a bolt in one but had no luck, there is a retaining ring under the dust boot that will need to be removed before you press it out
good luck hope it works out well
Canada = Awesomeness eh!
Isnt it amazing how quickly everyone can turn against you
#3
dmdicks
dmdicks is offline
dmdicks's Avatar
Sex: Male
dmdicks is just really nicedmdicks is just really nicedmdicks is just really nicedmdicks is just really nice
Old Re: Remove hub from axle to get off ball joint? 02-09-2011 , 11:29 AM
You only have to unbolt the strut from the hub. That will allow the hub to rotate down and give you enough clearance to get a wrench on there. To remove the ball joint get a ball joint removal tool and it will pop the joint right out. The new ones just slip right in and will get snugged down when you tighten the nut.
#4
Shark2005
NewTiburon.com God
Shark2005 is offline
Shark2005's Avatar
Sex: Male
Shark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of light
Old Re: Remove hub from axle to get off ball joint? 02-09-2011 , 11:57 AM
If you have an air compressor with air compressor tools (air chisel), then this tool is a wonderful attachment for your air chisel. A definate part of my air tool collection.
Amazon.com: Old Forge Tools (OLD1996) Ball joint Separater Air Chisel: Home Improvement Amazon.com: Old Forge Tools (OLD1996) Ball joint Separater Air Chisel: Home Improvement
#5
Hurdler5280
NewTiburon.com God
Sex: Male
Hurdler5280
Old Re: Remove hub from axle to get off ball joint? 02-10-2011 , 06:41 PM
Thanks for the info. Glad to know I don't need to remove the axle from the hub.
Going back to stock
#6
03_tibby_CT
NewTiburon.com God
03_tibby_CT is offline
Sex: Male
03_tibby_CT has a spectacular aura about03_tibby_CT has a spectacular aura about03_tibby_CT has a spectacular aura about
Old Re: Remove hub from axle to get off ball joint? 03-04-2011 , 09:33 PM
if you remove the strut from the knuckle (what you've been calling a hub), you will need to realign the vehicle.
#7
lukeman
PlastiDip Mod
lukeman is offline
lukeman's Avatar
Sex: Male
Old Re: Remove hub from axle to get off ball joint? 03-04-2011 , 09:36 PM
^ only is he has a camber kit, if its stock then he wont need to realign it
#8
vrod1123
NewTiburon.com Rookie
vrod1123 is offline
vrod1123's Avatar
Sex: Male
vrod1123 is an unknown quantity at this point
Old Re: Remove hub from axle to get off ball joint? 03-05-2011 , 10:30 AM
Quote:
Did you remove the ball joint directly below the steering knuckle? If so, how? I'm having a tough time trying to get it out. I don't see slip ring or anything I need to remove to make it easier. Although someone did mention a "slip ring".
Every time I try the removal kit (big C-clamp looking), it slips off because the threaded (top) portion of the ball joint keeps pivoting away from the pressure. I also tried a 5lb ledge with no affect.
Any advice is appreciated.
Thanks,
Vic
#9
BramptonTib
NewTiburon.com God
BramptonTib is offline
BramptonTib's Avatar
Sex: Male
BramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of light
Old Re: Remove hub from axle to get off ball joint? 03-05-2011 , 10:37 AM
Take a look at this video. Might give you some ideas.
#10
vrod1123
vrod1123 is offline
vrod1123's Avatar
Sex: Male
Old Re: Remove hub from axle to get off ball joint? 03-06-2011 , 12:06 PM
Thanks,
Vic
Ok, I figured this out yesterday...
1 - The ball joint removal kit/press I was using did not have the right adapter to clear the threaded bolt just below the steering knuckle. Kit part# is EverTough 67045. Don't use that one, instead find something with more adapters etc... That's why I had such a hard time with it. There are other kits with the correct parts that would work, but Oreilly's (where I went) did not have it available to rent out. I improvised by using a deep socket to make up the space between the ball joint bolt and kit I had. The ball joint eventually popped out as intended. (NOTE: The ball joint directly below the steering knuckle is pressed down for removal and up for install,...unlike some domestic vehicles)
2 - The OEM ball joint did not have a slip ring on it, I checked it thoroughly when I removed it. Just press it through with the kit. You may need a breaker bar to completely get it out the first time.
3 - The replacement non-oem ball joint ($14 at O'reilly's) did come with a slip ring and was very easy to install. You provide your own grease though. (NOTE: go find a good set of slip ring pliers BEFORE you need them!!). The parts stores usually carry cheapos or very little inventory of the good stuff. I bought cheapos ...but they worked, kinda : /
Hope this helps someone.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
