Lowering Springs - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Appearance / Audio (03+) > Exterior
View Poll Results: How Low?
1 in 7 15.22%
1.5 in 19 41.30%
2 in 21 45.65%
Multiple Choice Poll. Voters: 46. You may not vote on this poll
User Tag List
Reply
Thread Tools Display Modes
#1
Weeees5
NewTiburon.com Newbie
Weeees5 is offline
Weeees5's Avatar
Sex: Male
Weeees5 is an unknown quantity at this point
Old How low should I go? 04-05-2011 , 08:37 PM
How low should i go on my Tib?
Please use the poll if you want.
Sponsored Links
Advertisement
#2
mvpcougar07
NewTiburon.com God
mvpcougar07 is offline
mvpcougar07's Avatar
Sex: Male
mvpcougar07 is a glorious beacon of lightmvpcougar07 is a glorious beacon of lightmvpcougar07 is a glorious beacon of lightmvpcougar07 is a glorious beacon of lightmvpcougar07 is a glorious beacon of lightmvpcougar07 is a glorious beacon of light
Old Re: Lowering Springs 04-05-2011 , 08:38 PM
Low is not low enough......
That is all.
#3
SLO6 Tibby SE
NewTiburon.com Novice
SLO6 Tibby SE is offline
SLO6 Tibby SE's Avatar
Sex: Male
SLO6 Tibby SE has a little shameless behaviour in the past
Old Re: Lowering Springs 04-05-2011 , 08:39 PM
You can never be to low.
But let me help you a little bit here..
Some people will say just skip springs and go straight to coilovers. Now we all can not afford coilovers so a lot of people will also give you their setup. Alot of people just just run a spring and shock set up. People have their preferences. I am running Eibach Sportlines on stock struts. Alot will say you will blow them out that way. I personally have not blown them out at all and I am happy with my drop at the moment. But I am making the purchase of coilovers in the near future for multiple purposes. Best bet is to do a little research on each and every spring drop as well as coilover if you have the money for them..
Or if you want we have GI thread hoping that Raceland can make some coils for our cars at a good price so go check that out as well. http://www.newtiburon.com/forums/sho...d.php?t=198962
So check that out and hope you find everything you are looking for and good luck and happy modding.
I never venture on this site.
Last edited by SLO6 Tibby SE; 04-05-2011 at 08:53 PM. Reason: Being helpful and spelling.
#4
Montmont
NewTiburon.com God
Montmont is offline
Montmont's Avatar
Sex: Male
Montmont has a spectacular aura aboutMontmont has a spectacular aura aboutMontmont has a spectacular aura about
Old Re: Lowering Springs 04-05-2011 , 08:52 PM
What it really depends on is, how much work do you want to put into it? Typically the lower you go the more work required, i.e. wheel spacers or adapters, fender rolling, etc. It also depends on your wheels, their offset, what size tires you have on them, and so on.
#5
SLO6 Tibby SE
Sex: Male
Old Re: Lowering Springs 04-05-2011 , 08:55 PM
Quote:
As well as all of this. i knew I was missing some stuff in my rant and all that. Thanks. Again it just takes some research and paying attention to threads up here you can learn a lot as well.
#6
lukeman
PlastiDip Mod
lukeman is offline
lukeman's Avatar
Sex: Male
lukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud oflukeman has much to be proud of
Old Re: Lowering Springs 04-05-2011 , 08:59 PM
The only reason stock struts with lowring springs is considered bad is:
if you have a car with lets say 50k on it with stock shocks and springs the shocks have "broken in" and worn to suit that ride height, the piston is used to only moving a certain amount and living at a certain point in the shock housing. if you change that you change the position the piston sits inside the shock and this can cause a leak in the seal because now its a worn in seal rubbing on new metal. sometimes shocks will fail and other times it will be completely fine. its a gable.
personally if i were to do that "because i have the tools" i would lower on stock shocks and drive it till they pop while saving for koni adjustables and when i have enough strip everything and put the konis in on the already seated springs.
but thats just me lol
to each is own
Canada = Awesomeness eh!
Isnt it amazing how quickly everyone can turn against you
#7
Shadow Blue
Moonlighting Master
Shadow Blue is offline
Shadow Blue's Avatar
Sex: Male
Shadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another levelShadow Blue is on another level
Old Re: Lowering Springs 04-05-2011 , 09:06 PM
I call it "Limbo"
...how low can you go? Haha
WFC #722
Do it right the first time or don't do it at all...
To see the Tib -
Quote:
yes that's correct.... i'm not gonna hold shadow's wing back because will is a flake....
#8
Weeees5
Weeees5 is offline
Weeees5's Avatar
Sex: Male
Old Re: Lowering Springs 04-05-2011 , 09:12 PM
i want to go as low as possible without rubbing anything. I know it looks as if my rims are bigger than stock but they are on the same size tire as the origninal and are 17's. i already cant pull up to a parking spot stoper so thats not a big deal but i still want to be able to pull into parking lots...
#9
SLO6 Tibby SE
Sex: Male
Old Re: Lowering Springs 04-05-2011 , 09:58 PM
to each is own
Very true I think that when I got my car, the first thing that I said even at the dealer was that it needed to be lowered. That night after I got her home I just said the hell with it and I bought the springs figured if struts went out then I would get new ones. Yet to go so I am happy with how it is set up right now. Maybe I was just a lucky one then? haha
#10
Weeees5
Weeees5 is offline
Weeees5's Avatar
Sex: Male
Old Re: Lowering Springs 04-09-2011 , 04:57 PM
Quote:
That is all.
how low is yours?
#11
Ottoelite
Ottoelite is offline
Sex: Male
Ottoelite is an unknown quantity at this point
Old Re: Lowering Springs 04-09-2011 , 07:59 PM
For those who lower their cars a fair amount, how do you deal with speed humps or any kind of incline for that matter, like a driveway that rises up a bit from the road?
I'm riding at stock height and I can almost slam my front bumper into the road (if I don't slow down to a crawl) going into the parking lot at my work because of the incline coming off the road.
ARK DT-S V2 Exhaust | 18" XXR 525 (225/40/18 Hankook Ventus EVO v12 tires) | Injen CAI | Seibon TS Hood
#12
Vanga
NewTiburon.com Professional
Vanga is offline
Vanga's Avatar
Sex: Male
Vanga
Old Re: Lowering Springs 04-09-2011 , 08:03 PM
I lowered mine 1.4 inches, and I've only scraped once, but you really have to take inclines slow and know your limits, going up inclines on a diagonal usually works too
PREPARE TO WANT 1
#13
lukeman
PlastiDip Mod
lukeman is offline
lukeman's Avatar
Sex: Male
they do just that.. slow down to a crawl and approach hills at angles. its the only way unless you put in air bags for adjustable ride height lol
#14
poundit
NewTiburon.com God
poundit is offline
poundit's Avatar
Sex: Male
poundit will become famous soon enoughpoundit will become famous soon enough
Old Re: Lowering Springs 04-09-2011 , 09:05 PM
Well I'm lowered prolly bout 2.5- 3 inches so when it comes to speedbumps and inclines I watch myself and know what I can and can't do. I have D2 coilovers and I used to have dropzone springs on stock struts and they road fine.
Now I still have my springs I could sell you for the cheap if you are interested. Pm me if you want
#15
P.I.M.P
P.I.M.P is offline
P.I.M.P's Avatar
Sex: Male
P.I.M.P is an unknown quantity at this point
Old Re: Lowering Springs 04-09-2011 , 09:21 PM
That is all.
+1
save, get coils, slam it
i have tein springs...its FAR from low enought and they are almost a 2 inch drop
when i say i understand, it dosnt mean i agree, it dosnt mean i understand, it dosnt even mean im listening.....but it seems to make people happy, and thats what im all about
#16
special_fx
NewTiburon.com God
special_fx is offline
special_fx's Avatar
Sex: Male
special_fx has a spectacular aura aboutspecial_fx has a spectacular aura about
Old Re: Lowering Springs 04-09-2011 , 10:14 PM
The lower the car the less practical it becomes. I have a friend with a very low Tiburon and he is always scrapping going up driveways, etc. My recommendation will be just to keep lowering to a minimun 1.0 - 1.5 inch....unless you live in a perfect city
2006 Hyundai Coupe FX V6 6 Speed
2011 Toyota Fortuner 3.0 turbo diesel 5 Speed manual
#17
dj_lujan
NewTiburon.com God
dj_lujan is offline
dj_lujan's Avatar
Sex: Male
dj_lujan will become famous soon enoughdj_lujan will become famous soon enough
Old Re: Lowering Springs 04-09-2011 , 10:56 PM
I am Lowered 1.6 all around. The area I live in is not the smoothess. However, just like a few people mentioned bring your speed down when approaching speed bumps and slopes. With that being said, I've had my springs on for almost a month and have not rubbed.
Wrong Fitment crew #1671
#18
Ottoelite
Sex: Male
Old Re: Lowering Springs 04-10-2011 , 04:35 AM
Well living where I do (Manitoba, Canada) our roads are always complete **** because of the cold winters. As soon as spring hits and it starts warming up we get potholes and frost boils everywhere.
So if I do end up lowering i'll probably be going with the minimum 1.1-1.5"
#19
Weeees5
Weeees5 is offline
Weeees5's Avatar
Sex: Male
Old Re: Lowering Springs 04-17-2011 , 11:51 AM
I have desided to go with 2". Hope to get them soon. Mabe in a week.
#20
Weeees5
Weeees5 is offline
Weeees5's Avatar
Sex: Male
Old Re: Lowering Springs 04-17-2011 , 11:57 AM
Might get the D2 Springs.
2006 Tiburon GT
#21
poundit
NewTiburon.com God
poundit is offline
poundit's Avatar
Sex: Male
Old Re: Lowering Springs 04-17-2011 , 12:12 PM
Do it man. It will look sick
#22
A Lamb
A Lamb is offline
Sex: Male
A Lamb is an unknown quantity at this point
Old Re: Lowering Springs 03-02-2014 , 12:38 AM
Need help . I don't know what to do? I bought 19 inch wheels with low pro file tires 215 35 19. For my 04 tibby. Problem is, I bought them not thinking about lowering it like an idiot. But I want to. How low can I lower it if I can without rubbing . The wheels are 8 inches wide with an offset of 35 mm. I don't mind rolling the fenders if need be. Any help is appreciated.
#23
WTBaTibby
NewTiburon.com God
WTBaTibby is offline
WTBaTibby's Avatar
Sex: Male
WTBaTibby has a spectacular aura aboutWTBaTibby has a spectacular aura aboutWTBaTibby has a spectacular aura about
Old Re: Lowering Springs 03-02-2014 , 10:23 AM
You should be able to get a solid 1.5" drop with those wheels and tires, possibly even close to 2". Rolling the fenders may prove useful, but may not be needed unless you go lower than that.
Also: Don't bump threads older than say...90 days. Make a new one and link back to the old one if it has something useful in it that you'd like to reference.
Plans: NGM Stage 4+ Sniper (400whp)
Currently: Stage 1.8 Sniper (mediocre whp)
SOLD as of 10/11/12
Sponsored Links
Advertisement
Reply
Tags
coils, height, lowering springs, ride, springs
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
