Sticky Gas Pedal! - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#1
GreatLakesTuscani
NewTiburon.com Professional
GreatLakesTuscani is offline
GreatLakesTuscani's Avatar
Sex: Male
GreatLakesTuscani will become famous soon enoughGreatLakesTuscani will become famous soon enough
Old Sticky Gas Pedal! 08-25-2011 , 06:52 PM
this is a problem to me, my gas pedal, as you push it in, is tuff to push in like its sticking during a certain point. but if u push it hard it budges but it instantly kicks my rpms. i replaced my flywheel, pressure plate, and timing belt and it got aloootttt better but its still semi there and not the smoothest touch. now when u push it, it has little resistance but its still there. my friend suggested cleaning my air intake (i dont know how so any guides will be nice). what should i do to fix this? thanks for the help!
Not Built For Your Approval
Sponsored Links
Advertisement
#2
macsta187
NewTiburon.com God
macsta187 is offline
macsta187's Avatar
Sex: Male
macsta187
Old Re: Sticky Gas Petal! 08-30-2011 , 02:24 AM
Make sure the throttle cable ends or the trottlebody isn't sticking.
百パーセントStock...
お金がない。ない! くっそ。
#3
ViCiouS_TiBuroN
NewTiburon.com God
ViCiouS_TiBuroN is offline
ViCiouS_TiBuroN's Avatar
Sex: Male
ViCiouS_TiBuroN is a glorious beacon of lightViCiouS_TiBuroN is a glorious beacon of lightViCiouS_TiBuroN is a glorious beacon of lightViCiouS_TiBuroN is a glorious beacon of lightViCiouS_TiBuroN is a glorious beacon of lightViCiouS_TiBuroN is a glorious beacon of light
Old Re: Sticky Gas Pedal! 08-30-2011 , 03:32 AM
throttle cable or the bolt/whatever the pedal pivots on could be sticking
2005 GT Tiburon - SOLD
2010 370z Sport - Daily Driver
2005 ZX6R - Weekend Warrior
I'm not a mod, but I'm awesome. Ask me anything.
#4
ontariotibv6
NewTiburon.com God
ontariotibv6 is offline
ontariotibv6's Avatar
Sex: Male
ontariotibv6 will become famous soon enough
Old Re: Sticky Gas Pedal! 08-30-2011 , 07:03 AM
My pedal got that way. Like it would hang up and release so throttle control was not smooth. I sprayed some down the end of the throttle cable at the end by the tb. It smoothed out the pedal movement and the sticking never returned. The cable itself gets so it doesn't slide freely inside the black casing/tube. Try that and see if it helps.
05 Tib Tuscani: AEM CAI, Injen SES, Megan SS coils, Poly MM, B&M STS, TWM bushings, RRM strutbar, Clutch Slave Mod, Black RR eyelines, 6K HID, Pioneer->MTX->JL10".
#5
Jtib40
NewTiburon.com Novice
Jtib40 is offline
Jtib40's Avatar
Sex: Male
Jtib40
Old Re: Sticky Gas Pedal! 08-30-2011 , 10:05 AM
Mine was like that too, i sprayed it down and no more squeak
#6
TibbyTurnedTuscani
Always Here To Help
TibbyTurnedTuscani is offline
TibbyTurnedTuscani's Avatar
Location: Westlake, OHIO... Ten min outside of Cleveland.
Sex: Male
TibbyTurnedTuscani is a glorious beacon of lightTibbyTurnedTuscani is a glorious beacon of lightTibbyTurnedTuscani is a glorious beacon of lightTibbyTurnedTuscani is a glorious beacon of lightTibbyTurnedTuscani is a glorious beacon of light
Old Re: Sticky Gas Pedal! 08-30-2011 , 10:18 AM
Yea... your intake will have nothing to do with the pedal sticking... you need to lube the cable at the TB. you can use a dry teflon lube, as it works SOOOO much better than WD-40. it will cling to the cable and you'll be all set.
*** The Helper-Mod of The People ***
Current Modded Toys List: GSXR-650, IceBear 150cc Scooter, Manco 6.5hp Go-Kart, 4x4 Ranger 4.0L
#7
saikoi
NewTiburon.com God
saikoi is offline
saikoi's Avatar
Sex: Male
saikoi
Old Re: Sticky Gas Pedal! 08-30-2011 , 11:19 AM
I've Ben having this issue off and on...completely random times. It kind day feels like when air is caught in a brake line. Glad to know the solution is to just spray a cable.
FOR SALE / PART OUT : 2003 TIBURON GT V6 w/ 6-SPD : 88k miles : PM for more info!!! Located in Lancaster/Lititz, PA (17543)
#8
harmonicbliss
NewTiburon.com Newbie
harmonicbliss is offline
Sex: Male
harmonicbliss is an unknown quantity at this point
Old Re: Sticky Gas Pedal! 05-19-2013 , 03:57 PM
I never would have thought of teflon spray! For me, what worked best was to bend the cable clips a little farther open, since they were apparently pinching the cable too hard. I also used some throttle body cleaner to clear out all the gunk that made the valve stick a little.
#9
Charlie-III
NewTiburon.com God
Charlie-III is online now
Charlie-III's Avatar
Sex: Male
Charlie-III is just really niceCharlie-III is just really niceCharlie-III is just really niceCharlie-III is just really nice
Old Re: Sticky Gas Pedal! 05-19-2013 , 05:14 PM
Quote:
I use Lock-Eze (graphite) down the cable & spray on white lithium lube or silicone spray at the TB pivot.
BTW, unless it's a "stickie", don't bump threads over ~2 months old since the last post.
Wifes car: 2004 Tib GT, 2.7L, 5MT, 148K miles, medium blue, basically stock.
My car: 1998 Legacy GT wagon, 2.5L, 5MT, 176K miles, "Quicksilver", not stock and not slow...
"life is lived, one corner at a time".
Like my help/advice? "rep points" keeps me going.
Best NT.com '13 New-Comer, NT.com '13 Technical Advise & Info (runner-up), NT.com '13 Non-Tib (3rd) .
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
