Check engine light came on after cold air intake was put on - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > V6 - Naturally Aspirated
User Tag List
Reply
Thread Tools Display Modes
#1
Bones247
NewTiburon.com Rookie
Bones247 is offline
Sex: Male
Bones247 is an unknown quantity at this point
Old Check engine light came on after cold air intake was put on 01-24-2012 , 12:36 PM
I put a spectre cold air intake that was made for my car the other day and I reset my ecu and already went 100miles. As soon as that happened the check engine light came ok and now I'm worried. What happened?! I need to get this problem fixed ASAP.
Soon to be Racing cat into a Borla muffler exhaust - Drag DR-35 with 215/45 17R Venzia Crusader Tires - 10" Striker 900w sub powered by a 1000w amp - LED blue footwell lights. Ebay racing headers. LED underglow kit with a flip switch. Iphone docking station. More to come and up for suggestions.
Sponsored Links
Advertisement
#2
Lessaj
NewTiburon.com Post Master
Lessaj is offline
Lessaj's Avatar
Sex: Male
Lessaj is a name known to allLessaj is a name known to allLessaj is a name known to allLessaj is a name known to allLessaj is a name known to allLessaj is a name known to all
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 12:42 PM
Pull the code, it's probably just a lean code.
2012 Nov - COTM - Best Regional Tiburon (Canada)
2003 Hyundai Tiburon Rally Red Injen IS Cold Air Intake ;; Jun BL catback ;; DC headers ;; TWM STS ;; FL Headlights ;; 4300k HID Low//3000K HID Fogs ;; Shorty Antenna ;; 18x8 Tenzo DC-6 ;; Switchback Turn Signals ;; Lightweight Crank/Power Steering Pullies ;; Oil Catch Can ;; Seibon TS CF Hood ;; SMD Angel Eyes ;; HSD Coilovers
Canada OWNS NT
#3
peachferrari
NewTiburon.com God
peachferrari is offline
peachferrari's Avatar
Sex: Male
peachferrari is just really nicepeachferrari is just really nicepeachferrari is just really nice
You never know until you pull the codes, but my guess is one or both banks are running lean. This happens a lot with intakes. Happened to me once with my Injen SRI, but I reset the ECU and it has never come back.
2005 SE V6 6sp Injen SRI; SSA Cat-back; Basstib STS; Mussa Front Strut Bar; Eibach Rear Sway Bar; VIS Cyber CF Hood SOLD
2006 Pontiac GTO LS2 6-speed Stock for now...
#4
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 12:50 PM
How do I properly reset the ecu?
#5
Lessaj
Lessaj is offline
Lessaj's Avatar
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 12:55 PM
Unplug the battery and step on the brakes.
Canada OWNS NT
#6
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 01:03 PM
The first time I tried to reset the ecu I unplugged the battery for 15min then I tried to start it with the battery unplugged, and then waited 10 more minutes. It ran a bit better then the light came on after 100miles :/ I'll try doin that one in a lil bit
#7
diamondstar6892
NewTiburon.com Professional
diamondstar6892 is offline
diamondstar6892's Avatar
Sex: Male
diamondstar6892 will become famous soon enoughdiamondstar6892 will become famous soon enough
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 01:06 PM
its not driving different is it? stalling or anything?
#8
Lessaj
Lessaj is offline
Lessaj's Avatar
Sex: Male
Take it easy when you reset the ECU or it will throw the code.
Canada OWNS NT
#9
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 01:11 PM
I was taking it somewhat easy...until I raced my ex gf's element last night....probably why it threw that code :/ damn I'll reset it lol hopefully it will go away. After the first 100miles then I don't have to take it easy?
#10
matt99
matt99 is offline
Sex: Male
matt99 is an unknown quantity at this point
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 01:26 PM
Check your maf, you can reset your ecu all you want but the code will keep appearing if you dont fix the problem.
#11
peachferrari
NewTiburon.com God
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 02:40 PM
Quote:
Not necessarily. The time mine came on I was in CA on a trip, reset it there and it came back on, but once I got back home I reset it again and it has never come back since.
But yes check your MAF and connections on the tube pieces etc just to make sure.
#12
Lessaj
Lessaj is offline
Lessaj's Avatar
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:06 PM
Cleaning the MAF could help too.
Canada OWNS NT
#13
matt99
matt99 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:13 PM
Yea I had to do that with mine, used an electronics parts cleaner.
#14
speedy
speedy is offline
speedy's Avatar
Sex: Male
speedy is a name known to allspeedy is a name known to allspeedy is a name known to allspeedy is a name known to allspeedy is a name known to allspeedy is a name known to all
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:14 PM
Is your MAF backwards?
"People should not be afraid of their government. The government should be afraid of their people."
-V-
#15
matt99
matt99 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:26 PM
If that was the case it would sputter and pretty much be undriveable (I did that once) lol
#16
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:32 PM
Okay guys I have figured it out. I took my Tib to a Advance auto parts store and they ran a diagnostic on it. It was showing a p1166 and p1167 codes, and both pertain to the MAF. So I popped the hood to discover that I incidentally put the MAF on backwards when I put the intake on, and that was not the only problem. The supplied "claps" I use that lightly only because it didnt do **** towards holding the piping together. SO I bought some new pipe clamps that get a whole hell of a lot tighter than the other one, reset the ecu again, and test fired it. Runs like new. Now just need to get a new fuel pump cause the old one is being gay -_-" anyone know where I can get a new one for cheapish?
#17
Lessaj
Lessaj is offline
Lessaj's Avatar
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 03:37 PM
Rock Auto sir.
Canada OWNS NT
#18
speedy
speedy is offline
speedy's Avatar
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 05:04 PM
Quote:
Originally Posted by Lessaj View Post
Rock Auto sir.
Bingo. Rock Auto is the ****! lol.
-V-
#19
matt99
matt99 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 05:15 PM
remember they have 5% coupons all over the web.
#20
spitfiredan
NewTiburon.com Expert
spitfiredan is offline
spitfiredan's Avatar
Sex: Male
spitfiredan
Old Re: Check engine light came on after cold air intake was put on 01-24-2012 , 08:13 PM
dont do anything mentioned above if you have an 07-08.....thats just how it is theres nothing wrong with your car other than the fact they decided to put a touchy ECU in them
run it and a month before you have safety and emissions but your CAI filter on the end of your stock little 8 inch rubber pipe and the CEL will go away....then after put it back on.
--------------------Murk'd-------------------
#21
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-25-2012 , 12:30 AM
Well it was a bit odd when I started it up after I left work tonight (rpms surging up and down between 1500-2300) but after it was warmed up it was okay....had to dodge water puddles omw home hahaha
#22
spitfiredan
Sex: Male
spitfiredan
Old Re: Check engine light came on after cold air intake was put on 01-25-2012 , 01:21 AM
ya get a hydro shield.....i just took mine off cuz snow in utah but your engine needs to get use to the new air flow cel "might" go away after a few hundred miles but dont count on it....the CEL isnt a horrible thing but its a concern because if a different code pops up you wouldnt know so if you have a code reader i would try erasing the code/ checking it weekly or monthly to be on the safe side
#23
05iontib
NewTiburon.com God
05iontib is offline
05iontib's Avatar
Sex: Male
05iontib will become famous soon enough
Old Re: Check engine light came on after cold air intake was put on 01-25-2012 , 01:30 AM
Did u beat ur X's element?
05 GT V6 Silver
#24
Bones247
Bones247 is offline
Sex: Male
Old Re: Check engine light came on after cold air intake was put on 01-26-2012 , 12:31 AM
Hell yea I dd. without even getting completely on the gas to xD
#25
redlights bro
NewTiburon.com Newbie
redlights bro is offline
redlights bro's Avatar
Sex: Male
redlights bro can only hope to improve
Old Re: Check engine light came on after cold air intake was put on 03-03-2012 , 02:42 AM
im having the same problem with my tib i read and did everything you guys were saying and my code is still on. I have an 08 tiburon spitfiredan said thats just how those tibs are. But im wondering if there is anything i can do to get rid of it. And if its a problem becuase i dont want my engine to be slowly dying lol, any help please?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
