CEL throwing P0105,P1505,P1507 - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Engine Management
User Tag List
Reply
Thread Tools Display Modes
#1
doitt
NewTiburon.com Newbie
doitt is offline
Sex: Male
doitt is an unknown quantity at this point
Old CEL throwing P0105,P1505,P1507 01-26-2012 , 10:26 AM
After reading ECU i replaced both the maf and the idle air control valve yet codes still being thrown. also in my quest to get rid of the CEL replaced tps, knock sensors, upper and lower manifold gaskets, and checked for all other possible vacuum leaks.
What can be causing the input to be low when both components are brand new. purchases maf 1/24/2012 and IACV on 1/25/2012. knock/manifold gaskets 1/17/2012. Is a 2003 GT. 6Speed with 47725 miles.
Sponsored Links
Advertisement
#2
BramptonTib
NewTiburon.com God
BramptonTib is offline
BramptonTib's Avatar
Sex: Male
BramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of light
Old Re: CEL throwing P0105,P1505,P1507 01-26-2012 , 11:37 AM
are you sure the first code is P0105? This is a MAP sensor code, but you have a MAF sensor.
Did you clear the codes after replacing the parts, and then they came back? Did they come back immediately?
What other symptoms does the car have? How is it running?
#3
doitt
doitt is offline
Sex: Male
Old Re: CEL throwing P0105,P1505,P1507 01-26-2012 , 12:09 PM
U are correct the code is p0102. The car is running idle between 475 and 525. Upper rpm limits of 3500 and running rich.
Codes have been cleared twice and appear after car is turned on for a second time
#4
doitt
doitt is offline
Sex: Male
Old Re: CEL throwing P0105,P1505,P1507 01-26-2012 , 07:08 PM
Also since these problems started the abs light has been on. can that indicate something with the wheel speed sensor. Or should I be looking for a vacuum leak again
Last edited by doitt; 01-26-2012 at 07:10 PM. Reason: stupid phone auto correction
#5
bmxer
NewTiburon.com God
bmxer is offline
Sex: Male
bmxer has a spectacular aura aboutbmxer has a spectacular aura about
Old Re: CEL throwing P0105,P1505,P1507 01-26-2012 , 09:20 PM
Try cleaning your MAF sensor ... get some cleaner made to do that, and follow the instructions to a T
Don't ever take a fence down until you know the reason it was put up
#6
doitt
doitt is offline
Sex: Male
Old Re: CEL throwing P0105,P1505,P1507 01-26-2012 , 10:51 PM
Quote:
understandable thing to do but the maf was replaced 2 days ago. unless i went mudding in my tibby i doubt it would be dirty already. also logically if ur gonna replace maf would also atleast clean or replace air filter incase that was causing a problem
#7
bmxer
NewTiburon.com God
bmxer is offline
Sex: Male
Old Re: CEL throwing P0105,P1505,P1507 01-27-2012 , 03:52 PM
Does not mean it was clean ... but whatever, easy to rule out. All these errors are suggesting a bad reading somewhere ...
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
