P0441 Hard to Start After Filling Tank - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > Information > Hyundai Tech
User Tag List
Reply
Thread Tools Display Modes
#1
marshracing
NewTiburon.com Newbie
marshracing is offline
marshracing's Avatar
Sex: Male
marshracing is an unknown quantity at this point
Old P0441 Hard to Start After Filling Tank 07-06-2012 , 12:03 AM
Check engine light code P0441 and I have to crank the hell out of the car to get it to start right after I fill the gas tank (a good 10 seconds of cranking at least) after it fires it runs fine I do not need rev it to keep it going or anything. I am assuming I have a bad evaporative emission purge control solenoid valve, from the similar problems that others were having; however correct me if I'm wrong!
I know that on the V6 tibs the valve is located under the throttle body, is it in the same place on the i4? I seem to be having some trouble finding it. Also, I just replaced the canister air filter because the car was throwing a P0449, don't know if these incidents are isolated or if I'm looking at some bigger EVAP control system issues. Any help or insight will be much appreciated!!
Sponsored Links
Advertisement
#2
BramptonTib
NewTiburon.com God
BramptonTib is offline
BramptonTib's Avatar
Sex: Male
BramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of lightBramptonTib is a glorious beacon of light
Old Re: P0441 Hard to Start After Filling Tank 07-06-2012 , 09:47 AM
On the I4 it is located here:
#3
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-06-2012 , 12:53 PM
Ahh, found it! thank you very much... right under the throttle body lol looks like i just had do dig down past some tubes a little further. Took it off, poured some alcohol in it and blew air through it multiple times. How easily is air supposed to flow through the thing if anyone has tried it before? Placed it back on the car and cleared the codes, hopefully this keeps the CEL from coming back!
#4
beester
beester is offline
Sex: Male
beester
Old Re: P0441 Hard to Start After Filling Tank 07-06-2012 , 01:56 PM
their is a filter for your fuel tank vapors that may be plugged also. when your filling the tank the fuel vapors are leaking threw your PCV valve and causeing a unburnable air fuel mixure in the intake manifold, this is causing a long crank problem. change the pcv for now, see if it goes away.
#5
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-07-2012 , 05:37 PM
No luck with cleaning the valve the CEL is back on. Is the PCV the same thing as the PCSV?
#6
BramptonTib
NewTiburon.com God
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-07-2012 , 05:55 PM
Pcv is not the same as Pcsv. You'll need to replace the purge valve.
#7
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-07-2012 , 07:46 PM
okay, where is the purge valve located? and does anyone happen to have a pic of it?
#8
BramptonTib
NewTiburon.com God
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-08-2012 , 12:35 AM
It's the pic i posted. I'm saying you should replace it. Based on your post you said you just blew air through it and put it back on the car.
PCV stands for positive crankcase ventilation, that valve is on the valve cover, but has nothing to do with your issue. You want to replace the PCSV (purge control solenoid valve) which is the one in the pic
#9
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-08-2012 , 04:57 PM
okay! understood, thank you!
#10
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-12-2012 , 10:46 PM
Changed the valve under the throttle body, no luck! Car is still hard to start after filling the tank and the CEL is back on, same code P0441, any ideas?
#11
peachferrari
NewTiburon.com God
peachferrari is offline
peachferrari's Avatar
Sex: Male
peachferrari is just really nicepeachferrari is just really nicepeachferrari is just really nice
Old Re: P0441 Hard to Start After Filling Tank 07-13-2012 , 09:38 AM
Change this filter:
http://www.newtiburon.com/forums/sho...d.php?t=169076
And check all the lines around the box to make sure they're not plugged with charcoal. Should solve your problem.
2005 SE V6 6sp Injen SRI; SSA Cat-back; Basstib STS; Mussa Front Strut Bar; Eibach Rear Sway Bar; VIS Cyber CF Hood SOLD
2006 Pontiac GTO LS2 6-speed Stock for now...
#12
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-15-2012 , 03:19 PM
I changed that filter a couple of weeks ago for a P0449, btw I used the DIY, great work Ill be sure to check those tubes though, maybe left one lose while changing the filter.
#13
BramptonTib
NewTiburon.com God
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-15-2012 , 04:49 PM
according to hmaservice.com, the possible causes of P0441 are
● Leakage on hose to PCSV
● DefectivAe PCSV
Since you've already replaced the PCSV, next thing to check would be a leak in the hose from the tank to the PCSV
#14
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-16-2012 , 11:00 PM
dropped the charcoal canister and checked the hose to the PCSV for leakage, no leaks! however when I ran air through the hose (disconnected at the PCSV and at the charcoal canister) a bunch of rusty-red colored dust blew out the other end. I put everything back together and filled the car up, still hard to start, and the CEL is back on again, same code, P0441. what was that red dust from? that could have easily been clogging the hose but I'm sure a blew it out and its gone! air flows very freely through the tube now. what could be causing this?
#15
marshracing
Sex: Male
Old Re: P0441 Hard to Start After Filling Tank 07-18-2012 , 03:00 PM
Bump! come on guys! prod those brains! my mechanic has no idea and im in resistance of the stealership!
#16
SewZz
NewTiburon.com Rookie
SewZz is offline
SewZz's Avatar
Sex: Male
SewZz is an unknown quantity at this point
Old Re: P0441 Hard to Start After Filling Tank 07-18-2012 , 04:22 PM
When you changed the valve, did you also changed the electrical connector for it too? If there is no power, it may be staying closed. Thats all i can think of lol
Sponsored Links
Advertisement
Reply
Tags
epcsv, evap, p0449, valve
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
