Stick shift question - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Performance (03+) > Transmissions
User Tag List
Reply
Thread Tools Display Modes
#1
ThatguyRay
NewTiburon.com Rookie
ThatguyRay is offline
Sex: Male
ThatguyRay is an unknown quantity at this point
Old Stick shift question 09-16-2012 , 05:13 AM
im fairly new to stick shift and i have a question, i have an 03 gt 6 speed and i was wondering is there a certain time when you're not supposed to put your foot in the clutch....i do this in every stick i drive...when going slow and shifting the clutch feels fine but when going fast and shifting the clutch almost has a vibration to it...i dont know if im shifting too late and over revving or if im putting my foot in the clutch too slow...can someone explain this? hope i explained right so you guys can help me understand.
Sponsored Links
Advertisement
#2
MVN
NewTiburon.com Professional
MVN is offline
MVN's Avatar
Sex: Male
MVN will become famous soon enough
Old Re: Stick shift question 09-16-2012 , 09:04 AM
not sure what ur asking but after u step on the clutch, then shift gears, you should not be on the clutch at all......
so are u driving with both gas pedal and left foot on the clutch?? you dont want to do that
OPERATION IRAQI FREEDOM - 2010
OPERATION NEW DAWN 2011
228TH ENG CO
UNITED STATES ARMY
#3
RichTiburon908
RichTiburon908 is offline
Sex: Male
RichTiburon908 is an unknown quantity at this point
Old Re: Stick shift question 09-16-2012 , 11:30 AM
When im at standstill traffic I kind of leave my foot on the clutch because we're pretty much only going 5-10 mph ... How bad s this on my clutch? It's pretty much unavoidable though ... i just got my new spec stage 2+ .....Still in the break in period..... traveled on like 60 mile trips already (in the guard going to my base)... Just dont want to detroy my ish lol... kind of like thatguyray...newbie to stick..... Good at riding it just wanna know the unwritten rules i guess lol......
#4
Jazzville
NewTiburon.com Expert
Jazzville is offline
Jazzville's Avatar
Sex: Male
Jazzville will become famous soon enough
Old Re: Stick shift question 09-16-2012 , 01:26 PM
The clutch can be pressed whenever as it really just pops it into neutral. When you're going slow, like in traffic, you can keep the clutch down if you feel the rpm is going to low like the car will stall. Thats fine.
As for the OP, when you're shifting at high rpms, I've never had the vibration feel so perhaps you're keeping the clutch depressed too long? If i shift at high rpms, I'm in and out of the clutch pretty quickly.
#5
ThatguyRay
Sex: Male
Old Re: Stick shift question 09-16-2012 , 06:05 PM
i think you're right jazzville...just have to get used to the car, also....is there a way to adjust where my clutch engages? it comes almost all the way up before it engages
#6
Doomsday Postcard
Doomsday Postcard is offline
Sex: Male
Doomsday Postcard is an unknown quantity at this point
Old Re: Stick shift question 09-16-2012 , 06:42 PM
another thing to ponder as well...have you done the slave cylinder mod yet?
#7
ThatguyRay
Sex: Male
Old Re: Stick shift question 09-16-2012 , 07:50 PM
i bought the car and i was told that the clutch was bad because it was acting up after a few hours, i took it back and they told me the clutch was fine and that they replaced the slave cylinder, so if there is an aftermarket slave cylinder i dont need to do the mod right?
#8
Doomsday Postcard
Sex: Male
Old Re: Stick shift question 09-16-2012 , 08:19 PM
Quote:
you need to do this...
http://www.newtiburon.com/forums/showthread.php?t=1962
#9
ThatguyRay
Sex: Male
Old Re: Stick shift question 09-16-2012 , 09:24 PM
its not a hyundai slave cylinder though so it still has the pieces that needs to be removed?
#10
Spartacus
NewTiburon.com God
Spartacus is offline
Spartacus's Avatar
Sex: Male
Spartacus is a glorious beacon of lightSpartacus is a glorious beacon of lightSpartacus is a glorious beacon of lightSpartacus is a glorious beacon of lightSpartacus is a glorious beacon of light
Old Re: Stick shift question 09-16-2012 , 09:40 PM
Almost definitely. Aftermarket slave cylinders are just meant to be equivalent to but cheaper than OEM.
___________________________________________________________
2001 Impreza 2.5RS Aspen White - I/E, springs, WRX brakes, OZ Prodrive P1
2003 Tiburon GT Carbon Blue - RIP
#11
Doomsday Postcard
Sex: Male
Old Re: Stick shift question 09-16-2012 , 09:44 PM
Quote:
^ this! Open it up, if it has a check valve spring...remove it before it destroys another clutch...
#12
ThatguyRay
Sex: Male
Old Re: Stick shift question 09-19-2012 , 01:00 AM
hey if the problem went away when they replaced the slave cylinder then came back two days later does that mean it really was the clutch?
#13
diamondstar6892
diamondstar6892 is offline
diamondstar6892's Avatar
Sex: Male
diamondstar6892 will become famous soon enoughdiamondstar6892 will become famous soon enough
Old Re: Stick shift question 09-19-2012 , 09:09 AM
You don't want to "ride" the clutch. Like have it half pressed down, that's bad cuz you are slipping it. You want to either have it pressed down all the way or not pressed at all. I see a lot of people holding their foot on the clutch while they drive to rest their foot and that will burn out your clutch very fast. That's what the dead pedal is for. You want to be in the "in between (having the clutch half way down to all the way down)" as little as possible.
Quote:
If you having clutch problems I feel bad for you son,
but I got 99 problems and a clutch aint one...
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
