Noises coming from front end (bearing?) - New Tiburon Forum : Hyundai Tiburon Forums
User Tag List
Reply
Thread Tools Display Modes
#1
ccogburn
NewTiburon.com Newbie
ccogburn is offline
Sex: Male
ccogburn is an unknown quantity at this point
Old Noises coming from front end (bearing?) 02-03-2013 , 06:19 PM
Hey guys I'm new to this forum, although I have seen it multiple times, and I'm having some problems out of my 05 Tib GT. When i bought it, it pulled really hard to the right so I had the front passenger bearing replaced then later wheels and tires both replaced. I had it realigned after getting the tires but it still pulls (not as hard) to the right. When i put on the brakes it makes it pull slightly less but it still wants to go right. Later on when i turned sharp to the left i think i could hear a popping noise coming from what i thought was the left wheel area, although I couldn't find anything wrong. Just yesterday i noticed a grinding kind of noise, almost sounded like a metal ring being spun on something or even two rifle shells vibrating into each other, its hard to explain. It doesn't really effect the driving but since i drive 30 miles to and from work I'm a little worried. I've been told bearing go bad on these cars around 100k and im almost at 120k. I love the car and this is the first problem i've had out of it. Could it be the bearing(s) going bad? again? or maybe brakes? I'm at a loss.
Sponsored Links
Advertisement
#2
deermjd
NewTiburon.com Novice
deermjd is offline
deermjd's Avatar
Sex: Male
deermjd is an unknown quantity at this point
Old Re: Noises coming from front end (bearing?) 02-04-2013 , 08:38 AM
That popping noise could be a bad cv shaft. Does it make the noise while turning sharply at low speeds?
'03 GT V6
K&N drop-in filter, Rockford Fosgate sub and amp
#3
jp2039
NewTiburon.com Professional
jp2039 is offline
jp2039's Avatar
Sex: Male
jp2039 will become famous soon enoughjp2039 will become famous soon enough
Old Re: Noises coming from front end (bearing?) 02-04-2013 , 10:07 AM
mine pops when i accelerate and when i am sitting at a red light with my foot on the brake it goes like (pop pop pop pop then squeak when i accelerate lol) it doesn't do it when its in park or neutral though so i think its the cv shaft too its been doing in for over a year but nothing has happened yet (knock on wood). :/ i know. i need to have it looked at just haven't had the time the previous owner hit something because when i bought it i had to replace a rim because the rim was cracked on the side that it squeaks on.
Injen SRI, FL/2 rear conversion, FL/2 gauges, Blue DiodeDynamics Door lights, Pioneer HU, eBay exhaust, shaved oem antenna, KDM cup holder, FL/2 red and black seats, led cup holders and LOTS of other interior replacements
#4
ccogburn
ccogburn is offline
Sex: Male
Old Re: Noises coming from front end (bearing?) 02-05-2013 , 07:01 PM
Quote:
yea, it would only make the popping noise turning sharp left just taking off. If i would go at idle speed in a circle it would do it. granted i couldn't tell if it did it at higher speeds because it was not loud enough to hear with wind. I did fix the ringing noise though my brakes were in awful shape but once i had the pads replaced and rotors turned the ringing stopped
Sponsored Links
Advertisement
Reply
Tags
bearing, brakes, front, noise, steering
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
