Go Back   NewTiburon.com > Information > Do It Yourself > DIY Engine
Reply
Thread Tools Display Modes
#1
adam_hunsicker
NewTiburon.com Newbie
adam_hunsicker is offline
Sex: Male
adam_hunsicker is an unknown quantity at this point
Old DIY: Home Made CAI 02-17-2004 , 12:59 AM
Home Made Cold Air Intake DIY
Materials needed:
2 – 18” long pieces of 2˝” inner diameter exhaust flex tubing
2 – U-bolts with nuts (should come with exhaust flex tubing)
1 – 2˝” outer diameter to 2˝” outer diameter exhaust adapter
1 – Cone air filter
1 – 2˝ inner diameter to 2˝ inner diameter Rubber grommet
1 – Breather filter (preferably with a male end but if you can’t find one you’ll need a male to male adapter)
3 – 2” to 3” hose clamps
Instructions:
1. Remove all stock intake components
- snorkel located between driver’s headlamp and battery
- silencer box located underneath battery
- intake transport tube #1 (2 pieces) comes up from silencer box to filter box
- filter box
- intake transport tube #2 goes from filter box to throttle body
2. Insert Exhaust Adapter into one end of both pieces of flex tubing to create one long piece of flex tubing.
3. Secure with U-bolts.
4. Insert one end of the now 36” flex tubing into the rubber grommet (note: it will be a very tight fit, I intentionally noted a smaller size than needed to ensure a good seal.)
5. Secure with hose clamp
6. Insert the end without the rubber grommet into the hole that you removed intake transport tube #1 from
7. Attach rubber grommet to throttle body
8. Attach cone air filter to bottom end of flex tubing (should hang behind drivers fog light)
9. Secure with hose clamp
10. Attach breather filter to valve breather line (the "vacuum line" that went from your engine to your stock intake tube) using male to male adapter if needed. (you may want to secure this with a hose clamp but because the line is not pressurized it really isn't needed)
11. Enjoy your improved HP, Torque, Throttle response and awesome sound!
Please note that due to the location of the air filter you run the risk of causing severe damage to (i.e. hydro-locking) your engine in wet weather. This is why I use 2 pieces of flex tubing instead of just buying one long one. In the event of rain I recommend that you disconnect the exhaust adapter from the piece of flex tubing closest to your throttle body and attach your air filter in it’s place. I have a second air filter that stays in my trunk just for this reason. YOU CAN BLOW UP YOUR MOTOR IF YOU DO NOT DO THIS!
Also, if you’d like you can also wrap your new intake tube with exhaust heat wrap to shield it from engine heat but I do not recommend this as it is unneeded, messy and an overall pain in the ***.
#2
Ryloth
Richard : I can haz NT?
Ryloth is offline
Ryloth's Avatar
Sex: Male
Ryloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud ofRyloth has much to be proud of
Old Re: Home Made CAI 02-17-2004 , 02:27 PM
have you done this yourself? if so, pics?
Site Hownministrator Syndicate
I Make This Look Good
#3
BestRedRide
NewTiburon.com God
BestRedRide is offline
BestRedRide's Avatar
Sex: Male
BestRedRide will become famous soon enoughBestRedRide will become famous soon enough
Old Re: Home Made CAI 02-18-2004 , 09:26 AM
Decent DIY for the extremely budget-minded guy, Adam.....ghetto DIY, but decent...
-BRR
- Alpine Developments(18psi) - Amsoil - AOS - APE - AutoMeter - Bros - BSE - ClutchNet - Compact Divisions - DEI - DuPont - EBC - Eibach - Exos - Fast - Fidanza - GarageGK - GReddy - GT Wing - Halo - IFMAR - Innovate Motorsports - JSpeed - JSP America - KSpec - Magnaflow - M&S Carart - Momo - Optima - Pioneer - Rockford Fosgate - Rota - RRM - SCAD - Sparco - Tomato A&P - Triangle - TurboXS - TWM - Walbro - XO2 Racing - YaYa -
#4
JoshGTV6
NewTiburon.com God
JoshGTV6 is offline
JoshGTV6's Avatar
Sex: Male
JoshGTV6 is an unknown quantity at this point
Old Re: Home Made CAI 02-18-2004 , 05:45 PM
the exhaust flex tubing, if it's the one i'm thinking of, is ribbed on both the outside and inside. I would imagine that this would create turbulent airflow through the intake. This isn't always bad, but in the case of the intake tube itself i don't think you would get much more than sound out of it.
#5
adam_hunsicker
Sex: Male
Old Re: Home Made CAI 02-23-2004 , 12:57 PM
Ok, I know this DIY is "ghetto" but when you're looking at spending over $3000.00 on building your motor and turbo charging why in the hell are you going to spend $230+ on an intake that isn't going to work with the turbo set up. As for it not giving me anything more than sound... I've gained 1/2 second in the 1/4 by doing this.... the ribbing isn't nearly as big a deal as you might think. As soon as I get my digital camera in I'll take pics and show you what it looks like when completed. I'll be the first to admit, it's not the prettiest thing in the world, but it IS very efficient. Both for HP and for $$$.... The only reason I even posted this here is because I've had about 20 people email me off of this forum and a few of the others I go to asking me how I made my CAI.
#6
adam_hunsicker
Sex: Male
Old Re: Home Made CAI 02-26-2004 , 09:32 PM
save $5 bucks or so using the DIY and you don't have to wait.... main reason I made my own wasn't the price though... it was the simple fact that it gets pretty friggin rainy out here in So.Cal and you generally can't relocate the filter in a system that you buy to convert it to short ram during bad weather... That and I'm impatient.
#7
huck
NewTiburon.com Novice
huck is offline
huck's Avatar
Sex: Male
huck is an unknown quantity at this point
Old Re: Home Made CAI 03-03-2004 , 08:42 PM
Looks good, but what did you do with the sensor that was in the stk intake?
#8
phlash
NewTiburon.com God
phlash is offline
phlash's Avatar
Sex: Male
phlash is an unknown quantity at this point
Old Re: Home Made CAI 03-15-2004 , 02:29 PM
Quote:
That car is a 4 cyl. they dont have a sensor there. They have a MAP not a MAF, and the MAP isnt located in the intake line.(I think thats right)
Its a Jeep thing....and Im still trying to understand
My Cherokee is faster than your Tiburon. And it handles better in the snow.
#9
Imidazole
Imidazole is offline
Imidazole's Avatar
Sex: Male
Imidazole is an unknown quantity at this point
Old Re: Home Made CAI 09-02-2004 , 08:34 PM
Last time I used exhaust tubing, I was making a custom CAI for a 3.8l Ford Taurus. What a disaster. It ran worse, and after a bit of driving, the tubing got so damn hot it was heating up the air, and making it run even ****tier!
-Imidazole (Chesapeake, Virginia)
2004 Hyundai Tiburon GT [M6] / Completely Stock
1969 Pontiac GTO [455ci - Hurst M4]
#10
zkdawg
NewTiburon.com Rookie
zkdawg is offline
zkdawg's Avatar
Sex: Male
zkdawg is an unknown quantity at this point
Old Re: Home Made CAI 04-21-2009 , 06:25 PM
Quote:
by the way, the i4 does have a MAF. some have the MAF and some have the MAP
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
