*full* braided clutch line - New Tiburon Forum : Hyundai Tiburon Forums
User Tag List
Reply
Thread Tools Display Modes
#1
rabies
NewTiburon.com Novice
rabies is offline
Sex: Male
rabies is an unknown quantity at this point
Old *full* braided clutch line 11-21-2013 , 02:58 PM
anyone ever install one?
not the little short one from the hardline to the clutch slave cylinder.
but a complete line from clutch MC to SC.
would make it cleaner, easier motor pullouts, etc.
if so whats the clutch MC AN size? and the banjo SC size?
i belive one can buy universal lines granted same size on both ends.
does away with this. makes it a 1 piece line..not 2 peices...
Sponsored Links
Advertisement
#2
KelConquer
NewTiburon.com Expert
KelConquer is online now
KelConquer's Avatar
Sex: Male
KelConquer
Old Re: *full* braided clutch line 11-21-2013 , 08:58 PM
Interested as well...
#3
Johncrxsi
NewTiburon.com God
Johncrxsi is offline
Johncrxsi's Avatar
Sex: Male
Johncrxsi will become famous soon enoughJohncrxsi will become famous soon enough
Old Re: *full* braided clutch line 11-21-2013 , 09:17 PM
What could be cleaner than a hard line ? A loose ss line will not look cleaner.ive never pulled a engine but how would this make it easier?
#4
rabies
rabies is offline
Sex: Male
Old Re: *full* braided clutch line 11-22-2013 , 12:04 AM
google ticked and shaved bays... u wont see a stock clutch line. when u do motor swaps less mess and QDs make stuff easy
#5
KelConquer
KelConquer's Avatar
Sex: Male
KelConquer
Old Re: *full* braided clutch line 11-22-2013 , 08:16 AM
I've heard the "rubber" lines can expand under pressure especially when worn, also a stainless line would last much longer and Rabies' idea would even get rid of a joint/potential weak spot
#6
Shark2005
NewTiburon.com God
Shark2005 is offline
Shark2005's Avatar
Sex: Male
Shark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of lightShark2005 is a glorious beacon of light
Old Re: *full* braided clutch line 11-22-2013 , 11:53 AM
I can see you wanting to remove the connector from the hard line to the master cylinder, but you are very wrong thinking that this would be a viable solution. What you are actually doing is weakening the clutch line by decreasing the pressure and allowing more line to expand. Hard line does not expand, braided line, while expanding very little, still expands. If you increase the length of the braided line you have more line to expand. And the connection where the hard line meets the hose to the slave cylinder is not a potential weak spot.
#7
Charlie-III
NewTiburon.com God
Charlie-III is online now
Charlie-III's Avatar
Sex: Male
Charlie-III is just really niceCharlie-III is just really niceCharlie-III is just really niceCharlie-III is just really nice
Old Re: *full* braided clutch line 11-24-2013 , 11:33 AM
Quote:
Correct, even a new rubber hose expands with pressure, old hoses expand more. All rubber lines should be replaced once in a while, it's a time as well as mileage thing.
As to removing a "weak spot" due to the connection, I wouldn't worry about it. Properly connected, they last the lifetime of the vehicle with no issues.
I agree with most of Shark2005's comments. Not sure you could really tell the difference between a SS line/hardline mix vs. a full SS line.
Wifes car: 2004 Tib GT, 2.7L, 5MT, 148K miles, medium blue, basically stock.
My car: 1998 Legacy GT wagon, 2.5L, 5MT, 176K miles, "Quicksilver", not stock and not slow...
"life is lived, one corner at a time".
Like my help/advice? "rep points" keeps me going.
Best NT.com '13 New-Comer, NT.com '13 Technical Advise & Info (runner-up), NT.com '13 Non-Tib (3rd) .
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
