DIY: Refurbishing Rims - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > Information > Do It Yourself > DIY Exterior
User Tag List
Reply
Thread Tools Display Modes
#1
bogie
NewTiburon.com Professional
bogie is offline
bogie's Avatar
Sex: Male
bogie is an unknown quantity at this point
Old Refurbishing Rims 02-22-2004 , 05:05 AM
*Do at your own risk, this is for informative purposes only*
Materials
-2 packs 3m wet or dry assorted sand paper packs with assorted grades. 220, 320, 400 grit.
-1 pack of super fine steel wool
-1 tub of running compound or rouge.
-1 can of mothers aluminum mag polish.
-if you have a dremel use the sand paper bands or the flap wheel (120 grit for either ).
-if you don't have a dremel use 120 grit sand paper.
-Windex
-some clean cotton rags.
Procedures:
1. Using the windex clean the wheel of any excess dirt and brake dust.
2. Now use the dremel or the 120 grit sand paper and start to sand off any oxidation and the remaining clear coat.
3. Once you have a dull but clean looking wheel, move on to the 220 grit paper, I would not wet sand just yet(this is optional however). Now sand until your wheel is smooth and you cannot see the previous scratches from the last grit you used.
4. Now I would suggest you go ahead and wet sand with the 320 grit paper, use quit a bit of water. Again sand until you get an even more refined look.
5. Now finally wet sand with the 400 grit paper, same procedure applies as before.
6. Now clean the wheel with the windex and wipe it down with a clean rag.
7. Use the superfine steel wool and buff the surfaces that you sanded down. The harder you buff the better the shine.
8. Use the rubbing compound or rouge and apply it sparingly, a little goes a long way. Once the compound has cured or dried go ahead and use a clean towel to buff the the areas you applied the compound to.
9. Use the mothers aluminum polish, and repeat step 8.(you will know when to start buffing the aluminum polish when if forms a black colored residue.)
NOTES:
-It took me almost 2 hours a wheel to do this, and I only did the lip of my wheels since that was the only part that was chipped and oxidized.
-Bare aluminum will oxidize easier than clear coated aluminum, so you have to keep them polished and protected. "Mothers" make some of the best metal polishes out there.
-You can obviously use a progressivly finer grit sand paper/steel wool. The only reason I used what I used is because that was the only thing available to me at the time I did this. I will post pics soon of before and after.
Good luck and strong arms.
Before
After
Sponsored Links
Advertisement
#2
Freon
NewTiburon.com God
Freon is offline
Freon's Avatar
Sex: Male
Freon is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 02-22-2004 , 01:28 PM
Image station does not allow remote linking, so unless your browser has already cached thoose images, you get an red X. You have to copy and paste the links to get your browser to cache them.
Looks neato, though. Not sure I'd recommend someone take the clearcoat off their rims unless they really had to. The aluminum will weather poorly in the open. Oxidation starts immediately once you expose aluminum to the air. It will be an ongoing battle keeping them in good shape. Granted maybe that is preferrable to that first picture.
'04 STi, GT3076R .82, FMIC, 3" catless exhaust, self-tuned Openecu.org reflash
#3
TNT
and his new kimchi coupe
TNT is offline
TNT's Avatar
Sex: Male
TNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another levelTNT is on another level
Old Re: Refurbish them old nasty chipped aluminum rims 02-22-2004 , 01:49 PM
Would this work the same with road rash on the rim lip?
Gone, but not forgotten: 2003 GT V6 6MT in Jet Black @ 102,000 mi
Traded: Early 2003 GT V6 Auto in Super Silver @ 194,869 mi
Current: 2011 Genesis Coupe 3.8 6MT in Silverstone
#4
bogie
bogie is offline
bogie's Avatar
Sex: Male
Old Re: Refurbish them old nasty chipped aluminum rims 02-23-2004 , 02:04 AM
What is road rash? Freon is right, I only recommend this as a last resort, and as you can tell from the first pic my rims were pretty jackt. The aluminum polish is probably the most important step since it provides a barrier for the aluminum against the elements of the road.
#5
KspecTibby
NewTiburon.com Expert
KspecTibby is offline
KspecTibby's Avatar
Sex: Male
KspecTibby is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 02-28-2004 , 11:03 PM
Road rash is like getting rock chips in ur rim or when you curb real bad. am i right?
#6
tiburondriver47
NewTiburon.com God
tiburondriver47 is offline
tiburondriver47's Avatar
Sex: Male
tiburondriver47 is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 03-16-2004 , 01:01 AM
What about for a minor curbing scrape?
#7
bogie
bogie is offline
bogie's Avatar
Sex: Male
Old Re: Refurbish them old nasty chipped aluminum rims 03-16-2004 , 04:52 AM
Quote:
Depends on how severe it is, you would probably have to file it down first then sand it down uses the steps above.
#8
Pyridan
Pyridan is offline
Pyridan's Avatar
Sex: Male
Pyridan is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 03-16-2004 , 10:28 AM
yeah I gotta do something for my stock rims...they came f*cked up from the dealer, but I didn't notice for about a week and a half...then they wouldn't fix it.
I have a few mods, but until I can figure out how to do a good sig I won't waste space listing them
#9
T17RNH
NewTiburon.com Newbie
T17RNH is offline
Sex: Male
T17RNH is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 10-03-2004 , 09:32 PM
undefinedundefinedundefinedOkay guys, how far away are your nearest Hyundai dealerships? I had the same problem you all are having and I did the PAINLESS process of taking my car in... WE HAVE A FREAKING 100k MILE WARRANTY, USE IT... Hyundai of North America put four NEW rims on my car... They will only have one question... "Do you use an abrasive cleaner on the wheels?" Your answer should be... "only soap and water"
2003 Mystic Teal GTV6
Custom Exhaust w/ Resignator Removal
DIY Clear Corners
DIY Sub Wiring
20% tint
235/45/17 zr tires
#10
Tiburon09
Tiburon09 is offline
Tiburon09's Avatar
Sex: Male
Tiburon09 is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 10-10-2004 , 10:22 PM
So if I got scratches on my rims from the previous driver, could I take my car to the dealership and get new ones? I got my car from a chevrolet dealership though. So would I have to go to a hyundai dealership?
You can't touch me with a six foot stick!
#11
saywhat037
saywhat037 is offline
Sex: Male
saywhat037 is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 10-11-2004 , 12:59 AM
I guess a good idea would be to "reseal" stratches with the compound and polish it over even without sanding down the rest of the wheel right? Wouldn't it work just as well to protect the scratches from further damage?
#12
Joe19825
NewTiburon.com Rookie
Joe19825 is offline
Sex: Male
Joe19825 is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 01-20-2006 , 09:40 AM
I was reading this and does anyone have before and after pics?
Thanks
#13
Joe19825
Joe19825 is offline
Sex: Male
Old Re: Refurbish them old nasty chipped aluminum rims 01-24-2006 , 12:05 PM
Ok, i did the procedure above and the rims turned out great.
What do you think if I clear coted them next? Whould it turn out good or look like crap?
#14
naturalkiller
naturalkiller is offline
naturalkiller's Avatar
Sex: Male
naturalkiller is an unknown quantity at this point
Old Re: Refurbish them old nasty chipped aluminum rims 01-24-2006 , 06:32 PM
My warranty covers rims and tires,cracked or chip windshield,door dings and free oil change /service for 5 years.
#15
Joe19825
Joe19825 is offline
Sex: Male
Old Re: Refurbish them old nasty chipped aluminum rims 01-24-2006 , 07:38 PM
Anyone at all?
#16
Kuroi
NewTiburon.com God
Kuroi is offline
Kuroi's Avatar
Sex: Male
Kuroi is a glorious beacon of lightKuroi is a glorious beacon of lightKuroi is a glorious beacon of lightKuroi is a glorious beacon of lightKuroi is a glorious beacon of light
Old Re: Refurbish them old nasty chipped aluminum rims 01-24-2006 , 08:12 PM
Quote:
So you are saying that Hyundai's 100k warranty covers cosmetic damage caused by either normal wear and tear or owner neglegence yet it only covers 12k for a clutch which can either be damaged by normal wear and tear or owner neglegence... why does this make absolutely no sense
Quote:
Donít misunderstand me. Iím not saying that the RX-8 R3 handles well for a $32k car. Iím saying it handles better than a $320k car... or, more importantly, whatever youíre driving.-
2005 Shinka Edition RX8 #1098 out of 1357 produced.
#17
suprakidd
NewTiburon.com Novice
suprakidd is offline
suprakidd's Avatar
Sex: Male
suprakidd has a little shameless behaviour in the past
Old Re: Refurbish them old nasty chipped aluminum rims 10-28-2007 , 03:27 AM
Quote:
Agreed. mine has a small rust spot on the roof, happened a few months ago on the highway, my car was like 7 months old and they told me that id have to go to a body shop and have it repaired, repainted and blended in.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
