Go Back   NewTiburon.com > Information > Do It Yourself > DIY Lighting
Reply
Thread Tools Display Modes
#1
TuscaniFX
NewTiburon.com Post Master
TuscaniFX is offline
TuscaniFX's Avatar
Sex: Male
TuscaniFX is an unknown quantity at this point
Old DIY: Clear Door Light Lens by Xyloft 01-25-2004 , 07:15 AM
This DIY has been carried over from the old forum!
Time required:
If you have all the parts, and all your tools charged I would say less than 45 min, less than 30 if you don’t have to re-cut a lens
Tools:
Flat head screwdriver
Hobby knife or soldering Iron
(-OR-)
Dremel or Drill and a high speed cutting tool
Razor knife
Materials:
194’s, color of choice.
2ft x 4ft fluorescent light cover – found at home depot or light stores
Silicone sealant
Uninstall the OEM door light lenses using the flat head by prying around the edges. There are only a coupe pops and it should come off.
Trace the lens onto paper, or paperboard for a pattern. I found that making a pattern was easier than tracing the original lense
To cut the light cover I found this works best: since it is so large, if you take the razor knife and score it all the way across the 2 feet you can bend it there and I should break along the score. Dry wall and glass work the same way. I would give yourself about 8 in for the first break. You can use scissors for this cut, but it is messy as seen above.
Once you have it in a workable size. Take the pattern and a sharpe and trace the pattern. Flip the pattern for the other door. They are exact same size I did it both ways.
I found that if you put a notebook under the plastic and gently tighten the clamps it will keep it from moving pretty well.
If you have a dremel you’ll need a high speed cutting tool bit (I have no dremel and used a drill… was harder, but do-able)
You don’t have to cut all the way through the plastic, but you’ll find it easiest if you cut about halfway through. At this point you can bend it slightly around the edges and you new lens will pop out.
I took the razor knife around the edges to kind of smooth them out a little.
If you have a soldering iron or a hobby knife (soldering iron with different tips)
You can melt the edge and follow the same steps as above. You don’t have to melt all the way through, just about half way.
Go out and make sure they fit and look right. If not try again. I am estimating I can make about 20 or more lenses from the one sheet.
Place two silicone beads at either end, just enough to get it to stick. Probably bathroom silicone will work best since it is easy to remove. I used clear GE silicone3 from HomeDepot
If everything turns our right you should get this:
Thanks to Xyloft for a well presented DIY!
#2
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Xyloft is an unknown quantity at this point
Old 01-25-2004 , 12:53 PM
One additional point I found that GE silicone 2 clear is pretty awesome for attaching the lights, I removed my lenses once to change light bulbs and to make sure that the new ones i am making fit, it was really easy to clean up and reapply and you cannot see it. unless you are up on the lights.
if anyone is interested, I have been making these lenses for people for 12$ shipped. PM me or email me, it should be in my profile. I have posted these up in the for sale forum as well.
off topic: the new look for this site is awesome. other car forums dont even come close.
BMW 128i
2008 Triumph Daytona 675
#3
Pyridan
NewTiburon.com Professional
Pyridan is offline
Pyridan's Avatar
Sex: Male
Pyridan is an unknown quantity at this point
Old 01-25-2004 , 07:25 PM
great idea. I have been wondering what to do about them for a while. I might try your idea or something slightly different.
#4
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Old 01-25-2004 , 09:53 PM
Quote:
wish i could take credit for this as my original Idea, but another member in an old forum told me he used that material for his odler tib. I just took the materials that he recommended and put this together for everyone.
i'd be interested to see what you come up with.
BMW 128i
#5
Pyridan
Pyridan is offline
Pyridan's Avatar
Sex: Male
Old 01-26-2004 , 11:46 PM
yeah I would like to say I'll show soon, but until the weather clears up I have sort of a hold on all my Tibby work.
#6
TuscaniFX
TuscaniFX's Avatar
Sex: Male
Old 01-27-2004 , 05:47 PM
Xlyoft, have you advertised what you are selling in the For Sale forum...if not, you should...what you are selling is a nice touch as a cheap price.
I am interested in buying a set of these!
#7
Pyridan
Pyridan is offline
Pyridan's Avatar
Sex: Male
Old 01-27-2004 , 08:10 PM
Guys dumb question but my car is buried under snow right now so I can't just go look, but how are the stock lenses held on? and is there a way you think to get these to stay on that doesn't use glue. Also do you think maybe buying some clear lenses for some other vehicle or something might look a little more OEM?
#8
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Old 01-27-2004 , 08:24 PM
the stock lense are attached using little tabs.
i have removed and reinstalled mine a couple times. the Silicone i mentioned above leaves no trace when you remove them. it pretty much acts like rubber cement. you pull off the lens and you have these to rubbery pieces that pull out. the stock lenses will pop back on if you change your mind.
here is a pic of the removed lenses. dont think any other lenses will fit unless you have one molded professionally. which i can't afford really and have no idea who would be able to mold it.
sorry about the cat hair and quality of pics. kind of rushed it.
I also played with puting tabs on the side of the clear lenses and was going to cut little slots into the door... but i didnt want to put my baby under the knife. the way that I posted is totaly reversable and does no damage.
BMW 128i
#9
Pyridan
Pyridan is offline
Pyridan's Avatar
Sex: Male
Old 01-27-2004 , 11:01 PM
cool thanks for all the info
#10
Lyricalcriminal
NewTiburon.com Newbie
Lyricalcriminal is offline
Sex: Male
Lyricalcriminal is an unknown quantity at this point
Old 01-27-2004 , 11:31 PM
Sweet good ideas!
#11
sick shift
NewTiburon.com God
sick shift is offline
sick shift's Avatar
Sex: Male
sick shift is an unknown quantity at this point
Old 01-28-2004 , 08:04 PM
Where can I pick up some GE silicone 2? Home Depot?
#12
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Old 01-29-2004 , 09:14 PM
Quote:
yea home depot is where i got it. its like $14 for a tube if you have an silicone/caulk gun.
or you can buy a smaller tube (like i did because I dont have a gun) for like 5ish. i am thinking it was either 7.99 or 3.99 cant remember
this is the stuff you can use to seal an MDF speaker box too. thats actually why i had it around. and i also used it on my clear corners to reseal it.
BMW 128i
#13
SRX_Racing
SRX_Racing is offline
SRX_Racing's Avatar
Sex: Male
SRX_Racing is an unknown quantity at this point
Old 02-02-2004 , 08:49 AM
You know the white plastic piece behind the lense, well im going to paint that black then put a clear lense on it.. just an idea, and i might do a diff color bulb. Ill post pics when im done
SRX Racing
you feel bad you just got beat by a Hyundai!"
#14
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Old 02-02-2004 , 10:41 AM
i had thought about doing that as well. since the plastic is a grey color, i thought painting it super gloss white would make the light brighter and cleaner looking durring the day.
but i am no good at painting, and didnt want to mess with pulling the door apart. looking forward to seeing how it looks
BMW 128i
#15
TuscaniFX
TuscaniFX's Avatar
Sex: Male
Old 02-03-2004 , 07:41 AM
recieved my lenses today...thanx...very professional finish!
#16
ondrovic
NewTiburon.com Novice
ondrovic is offline
ondrovic's Avatar
Sex: Male
ondrovic is an unknown quantity at this point
Old Re: Clear Door Light Lense DIY - By Xyloft 01-05-2005 , 10:51 PM
guys i got a question about these. If you want to change the color from clear to blue what would be the best way to do it? Get a blue blud or get a blue candy type paint ( because what i understand that this type of paint is transparent ) and paint the lenses? Thanks for the help
Current Mods:
Pioneer 8600 MP, CAI, Memphis 15", Clarion Mono Amp, RRM Front & Rear Strut Bars, Tuscani Emblems, 5% tinit, New Shift Knob, B&M STS, Shift Boot & E-brake Boot, Viper 791 XV Alarm System
Mods Comming:
Angel Eyes, Borla Cat Back Exhaust, Tein Coilover kit, Tuscani Kick Plates, LED Gills, New Pedals, Custom Fiberglass enclouse with 2x 12" Memphis& 1 x 15" Memohis, 2x Memphis Amps, Poineer AVIC-N1, new clutch and flywheel, nitrous, custom interior.....]
#17
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Old Re: Clear Door Light Lense DIY - By Xyloft 01-05-2005 , 11:14 PM
Quote:
i think someone painted theirs with. mettalix? lumnicolor? crap....i cant remember what the name of the paint is. its on the tip of my tongue. but yea, thats how other people have done it.
my advice would be to paint the inside where the ridges are.
BMW 128i
#18
gunslinger
gunslinger is offline
Sex: Male
gunslinger is an unknown quantity at this point
Old Re: Clear Door Light Lense DIY - By Xyloft 07-30-2005 , 07:17 PM
use a candy color, i candied my map light and it looks great! It wil dim the light some tho.
#19
CRUSHKID06
NewTiburon.com Expert
CRUSHKID06 is offline
CRUSHKID06's Avatar
Sex: Male
CRUSHKID06 is an unknown quantity at this point
Old Re: Clear Door Light Lense DIY - By Xyloft 10-23-2006 , 11:48 PM
not too shabby! im givin this a shot
[06 ORANGE CRUSH SE] FIRST WINGLESS OC TIB//17" FLAT BLACK 5ZIGEN FN01R-C'S//OBX HEADERS//OBX CATLESS MID-PIPE//ARK N2 DUAL CATBACK//AEM CAI//APEXI NEO//B&M STS//SFR SMILEY AND GRAFF DECAL//S2K ANTENNA//TINTED TAILS//FLAT BLACK REAR DIFF
[NEXT UP]OEM CF HOOD...TEIN S-TECH SPRINGS
#20
TiburonGTfan
TiburonGTfan is offline
TiburonGTfan's Avatar
Sex: Male
TiburonGTfan is an unknown quantity at this point
Old Re: Clear Door Light Lense DIY - By Xyloft 09-28-2007 , 10:19 AM
Great DIY !!
#21
AnthonyASU
AnthonyASU is offline
AnthonyASU's Avatar
Sex: Male
AnthonyASU is an unknown quantity at this point
Old Re: DIY: Clear Door Light Lens- By Xyloft 05-27-2008 , 07:54 PM
Love this diy. Thanks!
#22
Exposed
Exposed is offline
Exposed's Avatar
Sex: Male
Exposed can only hope to improve
Old Re: DIY: Clear Door Light Lens- By Xyloft 07-07-2008 , 07:08 PM
great DIY thanks alot
Quote:
it could be much worse like your hobbies could be hookers, drugz, and breaking and entering!
^ best quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
