Go Back   NewTiburon.com > Information > Do It Yourself > DIY Engine
Reply
Thread Tools Display Modes
#1
AdRock
More insane by the minute
AdRock is offline
AdRock's Avatar
Sex: Male
AdRock is an unknown quantity at this point
Old DIY: Grounding Cable Install 03-06-2004 , 09:28 PM
This is the way I hooked mine up. Seemed to work pretty well.
The pic below.
1. This is a short one that goes from the NEG terminal(1) to the 10mm bolt that is used for the elbow from the stock airbox(2).
2. From the NEG terminal(2) to the bolt that holds on the the engine hoist bracket(3).
3. The wire from point 2 connects here. Then from here to the intake(4). There's also one from here that goes down to a bolt on the bottom of the tranny( I don't have a pic of that location, I'll try to find one ).
4. The wire from (3) connects here and goes to (5), the 10mm bolt on the pass side fender.
5. Last connection at the 10mm bolt.
'02 Mustang GT w/ a few goodies
one of the slow ones
#2
sadman813
NewTiburon.com Expert
sadman813 is offline
sadman813's Avatar
Sex: Male
sadman813 is an unknown quantity at this point
Old Re: Grounding Cable Install 03-16-2004 , 10:06 AM
I wanted to tag on another option for DIY ground wires. I ordered these parts today and I should be able to install it later this week. I'm basically trying to copy the Shark Racing Ground Wire Kit, but for a lot cheaper.
Here are the links to purchase the wires, distribution block, and ring terminals. Should be able to build the same kit for under $40 compared to Shark Racing's $85 and still look nice.
Distribution Block - 1x4gauge input, 4x8gauge output
http://www.partsexpress.com/pe/showd...number=265-800
4 and 8 gauge wire
http://www.partsexpress.com/pe/showd...number=100-196
http://www.partsexpress.com/pe/showd...number=100-174
4 and 8 gauge Ring Terminals
http://www.partsexpress.com/pe/pshow...95-662&scqty=3
http://www.partsexpress.com/pe/showd...number=095-655
I'm kind of guessing on the ring terminal post size. you can see all the sizes here:
http://www.partsexpress.com/webpage....10534&desc=ASC
I order a lot of parts from this company which is why all my parts are from them. If you can find them cheaper elsewhere, go for it. I'm already using one of their distribution blocks for my stereo system, so the two together should look good.
Heres the finished pics:
http://www.cardomain.com/ride/547050/6
#3
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 03-19-2004 , 08:22 AM
Well I started my grounding wire install last night, but 9:00 came around and that's time to go to the bar on Thursdays. So, I still have two more wires to run, one to the transmission and the other to the valve covers. Here's a pic of what it looks like so far. I mounted the distribution block on the firewall. I also went nuts and decided to use aluminum flex conduit to dress it up and keep it neat.
(1) This 4 gauge wire connects to the negative battery terminal
(2) This 8 gauge wire connects to the front of the engine block which you can see.
(3) Connects to the same screw that holds the grounding strap from the IM to the firewall.
(4) Runs from (3) to the strut
I also left the wire from the negative battery terminal in place for added grounding.
#4
ponack
NewTiburon.com Rookie
ponack is offline
ponack's Avatar
Sex: Male
ponack is an unknown quantity at this point
Old Re: Grounding Cable Install 03-19-2004 , 08:43 AM
sadman813, where'd you get your ground wire kit from? That looks pretty pimp.
#5
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 03-19-2004 , 08:48 AM
Quote:
Everything is listed in my first post on this page, except the conduit which I got at Lowes for about $0.25 per foot. Also, I bought #10 size ring terminals which are too small, go for 1/4". I ended up using my dremel to enlarge them for use with existing bolts. And for anyone that thinks 8 gague is too small, keep in mind it's an addition to existing grounding(nothing replaced) and 8 gauge is good up to over 70 amps when using 4 feet or less.
#6
Flcarbon
Flcarbon is offline
Flcarbon's Avatar
Sex: Male
Flcarbon is an unknown quantity at this point
Old Re: Grounding Cable Install 03-27-2004 , 04:36 PM
Anyone have any better pics of the connection points please?
2003 Tiburon-6 speed-1/4-14.9-Intake an Exhaust
#7
Ruphos
Ruphos is offline
Ruphos's Avatar
Sex: Male
Ruphos is an unknown quantity at this point
Old Re: Grounding Cable Install 04-04-2004 , 02:36 PM
Sadman, in total how much 8ga wire would you say you used? I just bought 20 feet, which i'm hoping will give me some left overs.
2003 Silver Tib GTV6 5 speed
Current: Injen CAI, Custom Grounding Wires, Clear Corners, Red Tails, Red Calipers, AOS Reverse Indiglo Gauges, Stainless Guage Surround, Brushed Alum. Racing Pedals and Dead Pedal, Billet Grille, Chrome Fogs, Silver dash trim, Tuscani Conversion, Kenwood DNX7100, RF Amp, 2 12" Eclipse
#8
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 04-04-2004 , 02:57 PM
I think i bought 20-25ft and lots left over.
#9
Xyloft
NewTiburon.com God
Xyloft is offline
Xyloft's Avatar
Sex: Male
Xyloft is an unknown quantity at this point
Old Re: Grounding Cable Install 04-04-2004 , 03:56 PM
Thanks for posting this, i have been looking for a cheap place to get these terminals for like 2 months. the cheapest i have found so far is $1 each and these are .50 cents
BMW 128i
2008 Triumph Daytona 675
#10
tibboy2003
NewTiburon.com Unemployed
tibboy2003 is offline
tibboy2003's Avatar
Sex: Male
tibboy2003
Old Re: Grounding Cable Install 05-20-2004 , 11:28 PM
okay my question is why would you ground with 8awg wire it's not enough current. If you 4awg wire it would be alot better.
#11
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 05-22-2004 , 10:42 AM
Quote:
Originally Posted by tibboy2003
okay my question is why would you ground with 8awg wire it's not enough current. If you 4awg wire it would me alot better.
Like I said above, 8 gauge is good up to or over 70 amps when using 4 feet or less wire. The shorter the wire, the more current you can pull through it.
#12
eze078
eze078 is offline
eze078's Avatar
Sex: Male
eze078 is an unknown quantity at this point
Old Re: Grounding Cable Install 06-04-2004 , 02:17 AM
Hey, what about DIY Grounding kit for 2.0 4Cylinder Tiburon?
Are the locations pretty much the same with V6 like in the pictures?
#13
JimEDaKid
NewTiburon.com Novice
JimEDaKid is offline
JimEDaKid's Avatar
Sex: Male
JimEDaKid is an unknown quantity at this point
Old Re: Grounding Cable Install 08-03-2004 , 03:15 PM
hey for the i4 ppl, i installed my groundwire kit a few weeks ago, and im gonna b putting the pics up on my cardomain site, www.cardomain.com/id/jimedakid sometime this week, so just check it out sometime and the pics should b up there
(Check out my car at the bottom of the page)
03 I4 Tiburon
Injen CAI
Custom Ground Wires
Neons
Tints
Mesh Grill
2 x 450 Watt Kenwood 12's
Tuscani Badges
Flick Artic 17's
#14
TNT
DD'n..but you can't tell.
TNT is offline
TNT's Avatar
Sex: Male
TNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud ofTNT has much to be proud of
Old Re: Grounding Cable Install 08-12-2004 , 03:25 PM
Damn adrock, your install is confusing as hell. I've stared at it for half an hour now and still can't figure it out. I mean, the wrong numbers go to the wrong grouding points.
Early 2003 GT V6 Auto in Silver
Dare I say....over nine thousand?
#15
AdRock
AdRock is offline
AdRock's Avatar
Sex: Male
Old Re: Grounding Cable Install 08-12-2004 , 11:01 PM
Quote:
Originally Posted by TNT
Btw, random bolt on the bottom of the tranny?? wtf, m8...
Sorry for *****ing .
Sorry man, I wish I had taken pics of the install but the pic above was taken when we were stripping my friends Tib after it was wrecked. And I traded in my tib before Iremembered to take more detailed pics.
#16
ChickenShark
NewTiburon.com Newbie
ChickenShark is offline
Sex: Male
ChickenShark is an unknown quantity at this point
Old Re: Grounding Cable Install 10-04-2004 , 07:06 PM
Not to sound like a retard...but what exactly do grounding wires do
#17
nightv
NewTiburon.com Professional
nightv is offline
nightv's Avatar
Sex: Male
nightv is an unknown quantity at this point
Old Re: Grounding Cable Install 10-05-2004 , 12:50 AM
it frees up the flow of power by disbersing the negative current in to more then one off-set alowing better over all proformance in the sterio sound and HP areas
CAI,catback,STS,2x20# race seats,ark rear and front struts, ps2, dvd 6.5" tv and alot of other ark stuff.
#18
ChickenShark
Sex: Male
Old Re: Grounding Cable Install 10-14-2004 , 12:25 PM
So I am to assume that custom wires function much better than stock wires? Or do the Tibs come without grounding wires and you have to add them? Thanx for the info!
#19
redtib
redtib is offline
redtib's Avatar
Sex: Male
redtib is an unknown quantity at this point
Old Re: Grounding Cable Install 10-14-2004 , 09:19 PM
these wires seems like a big advantage for such an easy mod. it just seems that nobody really is positive of the connecting spots. where would be the best to connect these grounders
#20
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 10-15-2004 , 08:11 AM
Don't expect a noticeable difference from ground wires. I think anyone who claims more power or smoother idling is only imagining it. They add a nice look and that's about it.
#21
TiburnU
TiburnU is offline
TiburnU's Avatar
Sex: Male
TiburnU is an unknown quantity at this point
Old Re: Grounding Cable Install 10-15-2004 , 08:41 AM
No not really, thats not it. They make the entire electrical system work much more smoothly. Imagine this, you have a stereo and amp. The amp needs to be grounded, but its not grounded properly - what happens.
what happens is you get road noise, static and a volt meter that jumps around. Its the same for the car - everything is electrical so why not make a stronger electrical current run through your car?
Oh and there have been cars (Acura RSX i think) that have pulled 7 h.p. out of a set of grounding wires. Thats what this craze is all about. Someone did it, got like 5 more h.p. and now everybody is doing it! So in reality your just stating your opinion which was probably made because your just to lazy to do it yourself!
Just my 2 cents!
#22
sadman813
sadman813's Avatar
Sex: Male
Old Re: Grounding Cable Install 10-15-2004 , 09:12 AM
Just my 2 cents!
I did do the mod. you should have read the entire thread. I even gave some instructions how to do it. Until someone takes a DMM and measures the resistances before and after installing ground wires I'm a skeptic. The stock grounding is aluminum wire which has almost the same resistivity as copper, and the gauge is a bit smaller, but over such short distances it should be negligible. Maybe those who got gains had aftermarket ignition parts which actually do need better grounding.
#23
4ndream
NewTiburon.com God
4ndream is offline
4ndream's Avatar
Sex: Male
4ndream is an unknown quantity at this point
Old Re: Grounding Cable Install 10-15-2004 , 10:46 PM
When I did my grounds I didn't notice any power difference but I did notice a big difference in the idle.
American Beauty...
#24
FunkNasty777
NewTiburon.com God
FunkNasty777 is offline
FunkNasty777's Avatar
Sex: Male
FunkNasty777 is an unknown quantity at this point
Old Re: Grounding Cable Install 10-16-2004 , 03:03 PM
For those with larger audio systems it is worth while. It eliminates static at higher ranges and also helps idle run smoothly. As for this DIY. We should probably move the debate to another topic in the General Discussion forum. Instead of cluttering up the DIY.
06 Honda Civic SI
#25
redtib
redtib is offline
redtib's Avatar
Sex: Male
Old Re: Grounding Cable Install 10-16-2004 , 11:24 PM
still i have no answer....where would be the best grounding points whether or not it gives HP or not?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
