Go Back   NewTiburon.com > Information > Do It Yourself > DIY Interior
Reply
Thread Tools Display Modes
#1
TuscaniFX
NewTiburon.com Post Master
TuscaniFX is offline
TuscaniFX's Avatar
Sex: Male
TuscaniFX is an unknown quantity at this point
Old DIY Door Handles - by Cheori 01-25-2004 , 07:48 AM
Installed!
Remove 3 bolts
Remove the cover, then remove 4 bolts indicated
Remove Tweeter (Pull it out), remove another 2 bolts.
If you removed all the bolts up to this point, pull the door cover from bottom toward you. It will be taken off pretty easily. Let one hold the door while other pull out the covering. Remove all the plugs that are in between them.
Remove White vinyl that are covering the doors.
Use 10mm hexagon? Thing to remove the bolts.
Then push the stock handles out. Requires a bit of force
Remove the yellow (on driver side) / white (on passenger side) plastic. Then install the chrome door handles (just tap it in to the where handles were used to be. Then proceed backward to finish the DIY.
FYI, check your keylocks before you assemble your door trims. You will need to adjust that keylcok properly otherwise you will end up opening the trims again..
#2
Magister
NewTiburon.com God
Magister is offline
Magister's Avatar
Sex: Male
Magister is an unknown quantity at this point
Old 01-31-2004 , 10:43 PM
has anyone done this DIY and afterwards had a bad rattle on the door when bass hits from the stereo? or was it happening before the diy too? i can't remember
#3
cheori
GarageGK Owner
cheori is offline
cheori's Avatar
Sex: Male
cheori is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 02-07-2004 , 03:39 PM
Mine's ok
#4
GSilveR
NewTiburon.com Rookie
GSilveR is offline
GSilveR's Avatar
Sex: Male
GSilveR is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 02-07-2004 , 07:16 PM
mine rattles at times, but i didn't install mine myself, autoshop did it for me while repainting the entire doors
#5
silentbob
NewTiburon.com Professional
silentbob is offline
Sex: Male
silentbob is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 02-08-2004 , 02:06 AM
mine rattled BEFORE this mod.. now, it's real quiet.. go figure..
on a side note, I'd like to point out that the "Then push the stock handles out. Requires a bit of force" doesn't really need that much force. if you look up in the door panel, the door lock swivels out of place for a nice easy removal of the handle from the door. Took me a while to figure it out when I was pushing on it and saw the door lock locked into place. Just a little hint for people doing this now.
#6
sick shift
NewTiburon.com God
sick shift is offline
sick shift's Avatar
Sex: Male
sick shift is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 02-08-2004 , 02:18 AM
It's all about how you put them back together, if the handles are a bit loose they will rattle.... I've not only installed the whole assembly but also swapped handles from different color tibs.... it's just a matter of experience, before you get it right...
#7
Magister
NewTiburon.com God
Magister is offline
Magister's Avatar
Sex: Male
Old Re: Door Handles DIY - by Cheori 02-08-2004 , 08:33 PM
its not the handles that rattle its like the arm rest on the door. when my hand is off of it and bass hits it does a quick rattle but when my arm is laying on it then it doesn't rattle at all, meh its prob just something I can't prevent.
Best 1/4: 10.095, Best R/T: .027
#8
nisco
NewTiburon.com Unemployed
nisco is offline
nisco's Avatar
Sex: Male
nisco is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 02-09-2004 , 06:35 PM
ohh thank god i found this!
thanks cheori and tfx!
#9
tusslewiththistuscani83
NewTiburon.com Newbie
tusslewiththistuscani83 is offline
tusslewiththistuscani83's Avatar
Sex: Female
tusslewiththistuscani83 is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 03-08-2004 , 08:36 AM
I don't want to scare or piss anybody off but I also just want to help. Changing the door handles and/or the gas cap voids your bumper to bumper warranty... unless you find a dealership to do it for you.
I found this out through a couple of sources... 2 dealerships and a guy who is making a turbo for a buddy of mines Tib.
I found a dealership that is about to start putting them on because they are working on a contract with Shark racing to start selling the aftermarket parts right out of the parts and service dept.
Just a heads up guys. BE CAREFUL!!!
E
"...you wanted to tussle...So we tussled."
#10
silentbob
Sex: Male
Old Re: Door Handles DIY - by Cheori 03-08-2004 , 02:25 PM
don't think so...
http://www.newtiburon.com/forums/showthread.php?t=78 <-- read this
#11
cademad
NewTiburon.com Novice
cademad is offline
Sex: Male
cademad is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 03-17-2004 , 02:16 PM
"FYI, check your keylocks before you assemble your door trims. You will need to adjust that keylcok properly otherwise you will end up opening the trims again.."
what do you mean by "check the key locks and adjust"??
#12
Jeff5886
Jeff5886 is offline
Jeff5886's Avatar
Sex: Male
Jeff5886 is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 03-21-2004 , 07:48 PM
just did this mod, best 45 bucks ive ever spent
#13
SlightlyModified
SlightlyModified is offline
SlightlyModified's Avatar
Sex: Male
SlightlyModified is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 03-21-2004 , 09:04 PM
E
Sorry, but thats ridiculous. I think you should check with a few more dealerships, ones that might actually know what they are talking about. Thanks though.
B&G 1.6" Springs - Tuscani Emblems
Clear Corners - Chrome Door Handles
Billet Antennae - Blue LED conversion
PAI passenger cupholder - *custom LED conversions
"Other EBAY intake" CAI - Billet Dash vents
#14
SilverSharkGT
NewTiburon.com God
SilverSharkGT is offline
SilverSharkGT's Avatar
Sex: Male
SilverSharkGT is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 04-25-2004 , 04:38 PM
Is there a trick to removing the bar that slides to open the door from the latch on the door panel?? I'm about to tackle this job but don't want to have problems with anything. Thanks.
<----Click to see the pics.
Current car: 2005 Porsche 911S
#15
mordwinn
mordwinn is offline
mordwinn's Avatar
Sex: Male
mordwinn is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 05-11-2004 , 10:02 AM
FYI - I asked 3 Hyundai dealerships in my area (Fort Lauderdale), and they all said replacing the gas covers and/or handles WILL NOT void any part of the warranty.
Black 2003 GT V6
Mods: Tuscani emblems and seatbelt pads, metallic gas door cover, chrome door handles, XM satellite radio, Shark Racing strut bars and hood spacers, AEM cold air intake, Next Generation Motorsports full stainless header kit, Borla catback exhaust, Eibach Pro-Kit springs, RevPM widebody kit, KSpec GT spoiler, Ground Dynamics carbon fiber hood, Vertical Doors kit, Gills Car Grills front grill, Auto Meter dual gauge pod with carbon fiber gauges
#16
silentbob
Sex: Male
Old Re: Door Handles DIY - by Cheori 05-11-2004 , 02:11 PM
Quote:
#17
MattTiburon
MattTiburon is offline
MattTiburon's Avatar
Sex: Male
MattTiburon is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 05-11-2004 , 04:12 PM
just did my handles and this DIy really helps
wasnt hard at all
took me 45 min
30 min for the first door (took me 15 min to get the inside handle off )
and 10min to take everything apart
and 5 min to put everything back together
and the 2nd door took 15 min to do
1 thing i noticed was that there was no clear/white cover to peel back on the driver side
it was only on the passenger side
#18
Tuscani13
Tuscani13 is offline
Sex: Male
Tuscani13 is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 05-26-2004 , 10:38 AM
Do you guys have a DIY I know their is one for when you just swap the chrome handle parts? I have a hydro blue tib, but not a hydro blue door handle, I plan to just take the chrome parts, thanks
#19
TibDave
TibDave is offline
Sex: Male
TibDave is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 06-04-2004 , 05:47 PM
Quote:
http://www.newtiburon.com/forums/showthread.php?t=60
Did you ever find this one?
#20
TibShark
TibShark is offline
TibShark's Avatar
Sex: Female
TibShark is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 08-28-2004 , 05:30 PM
"Remove the yellow (on driver side) / white (on passenger side) plastic. Then install the chrome door handles (just tap it in to the where handles were used to be. Then proceed backward to finish the DIY. "
Do you have to install the yellow / white plastic back on the chrome door handles, and how do you do that I will be installing these, had them for a while never got around to do them, just want to make sure I do it right. Thanks!!!
#21
rock37
NewTiburon.com Expert
rock37 is offline
rock37's Avatar
Sex: Male
rock37 is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 12-16-2004 , 10:16 PM
all the pics are XXX's
#22
TT04
TT04 is offline
TT04's Avatar
Sex: Male
TT04 is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 12-16-2004 , 11:36 PM
Quote:
Same as above
#23
hammerhead
NewTiburon.com God
hammerhead is offline
hammerhead's Avatar
Sex: Male
hammerhead is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 01-14-2005 , 07:18 AM
Quote:
Originally Posted by TT04
Same as above
I can see the pics! but pls post more of them...I just ordered the chrome handles at sharkracing.com...
http://www.cardomain.com/memberpage/448422/1
#24
hammerhead
NewTiburon.com God
hammerhead's Avatar
Sex: Male
Old Re: Door Handles DIY - by Cheori 01-26-2005 , 09:39 AM
maybe that helps too
http://www.hmaservice.com/webtech/ii...860#_394892860
#25
03'tiburonz
NewTiburon.com God
03'tiburonz is offline
03'tiburonz's Avatar
Sex: Male
03'tiburonz is an unknown quantity at this point
Old Re: Door Handles DIY - by Cheori 03-20-2005 , 03:30 PM
How The ****~!!!!!! Do You Line Up The Key Locks!!! They Will Not Go Thru Like They Need To!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2003 Tiburon V6 Automatic , Hotshot Headers/Cat, SRI. Wanted! - Borla Exhaust ...If your runnin rice you better think twice
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
