Installed!
Remove 3 bolts
Remove the cover, then remove 4 bolts indicated
Remove Tweeter (Pull it out), remove another 2 bolts.
If you removed all the bolts up to this point, pull the door cover from bottom toward you. It will be taken off pretty easily. Let one hold the door while other pull out the covering. Remove all the plugs that are in between them.
Remove White vinyl that are covering the doors.
Use 10mm hexagon? Thing to remove the bolts.
Then push the stock handles out. Requires a bit of force
Remove the yellow (on driver side) / white (on passenger side) plastic. Then install the chrome door handles (just tap it in to the where handles were used to be. Then proceed backward to finish the DIY.
FYI, check your keylocks before you assemble your door trims. You will need to adjust that keylcok properly otherwise you will end up opening the trims again..
