For those of you who've wondered what in the hell that huge jumble of numbers actually meant, here it is. For this we'll use the fictional Vin number of :
KMHCF35GXYU000001
The first three digits are the WMI or World Manufacturer Index - KMHCF35GXYU000001
KMH = Hyundai Korea (passenger vehicle)
2HM = Hyundai Canada
KM8 = Hyundai Koera (multi-purpose vehicle)
5NP = Hyundai USA (passenger vehicle)
The next 7 digits represent the Vechicle Description Section - KMHCF35GXYU000001
The first digit of the VDS denotes the model line and drive type - KMHCF35GXYU000001
Model line
B = Sonata 1989-1994
C = Sonata 1995-1998, Accent 2000-
D = Elantra 2001-
E = Sonata 2006-
F = XG300 2001, XG350 2002-
H = Tiburon 2003-
J = Elantra 1992-2000, Tiburon 1997-2001, Tucson 2005-
L = Excel 1986-1989
S = Santa Fe 2001-
V = Excel 1990-1994, Scoupe 1991-1995, Accent 1995-1999
W = Sonata 1999-2005
The second digit of the VDS denotes the body type - KMHCF35GXYU000001
Body Type (86-2000 models except 00 Accent but including 01-05 Sonata and 01 tiburon)
A = 5-door hatchback
D = 3-door hatchback
E = 2-door sedan
F = 4-door sedan
G = 2-door coupe
W = 5-door wagon
Trim Level (All 01-06 models except for 01-05 Sonata and 01 Tiburon, but including 00 Accent)
B = GL Santa Fe 2001-2004
C = GLS or LX Santa Fe 2001-
F = Base or L Accent 2000-2004
G = GL or GS Accent 2000-2004
G = GT Accent 2003-2005, GLS Accent 2005
M = GL (base) Tiburon 2003-2004, GS Tiburon 2005-
M = GL Tucson 2005-
N = GLS or GT Elantra 2001-, GLS Accent 2006-
N = GLS or LX Tucson 2005-
N = GT Tiburon 2003-, SE Tiburon 2005-
T = GL Sonata 2006-
U = GLS (Base or L) XG300 2001, XG350 2002-
U = GLS or LX Sonata 2006
The third digit of the VDS denotes the trim level or ody type as well - KMHCF35GXYU000001
Trim Level (86-00 models except 00 Accent, but including 01-05 Sonata and 01 Tiburon)
1 = base
2 = GL
3 = GLS, LS, LX, GS
Body Type (all 01-06 models except 01-05 Sonata and 01 Tiburon, but including 00 Accent)
1 = Wagon FWD
3 = 3-door hatchback
4 = 4-door sedan
5 = 5-door hatchback
6 = coupe
7 = wagon AWD
8 = wagon
The fourth digit of the VDS denotes the restraint system or GVWR - KMHCF35GXYU000001
Restraint System (passenger vehicles)
1 = active 3 point
2 = passive
3 = driver's side airbag (manual belt) passenger side passive
4 = dual airbags (manual belts)
5 = depowered airbags
6 = advanced airbags or depowered airbags with supression
GVWR (multi-purpose vehicle)
2 = GVWR Class C (> 1,814-2,268kg. / 4,001-5000lbs)
3 = GVWR Class D (> 2,268-2,722kg. / 5,001-6000lbs)
The fifth digit of the VDS denotes the Engine Type - KMHCF35GXYU000001
B = 1975cc DOHC 4cyl Tucson 2005-
B = 2351cc DOHC 4cyl Santa Fe 2001-2004
C = 1599cc DOHC 4cyl Accent 2001-
C = 2359cc DOHC 4cyl Sonata 2006-
D = 1975cc DOHC 4cyl Elantra 2001-, Tiburon 2003-
D = 2656cc DOHC V6 Santa Fe 2001-, Tucson 2005-
D = 2972cc DOHC V6 XG300 2001
E = 3497cc DOHC V6 XG350 2002-, Santa Fe 2003-
F = 1997cc DOHC 4cyl Sonata 1992-1998
F = 1975cc DOHC 4cyl Tiburon 1997-2001, Elantra 1999-2000
F = 2656cc DHOC V6 Tiburon 2003-
F = 3342cc DOHC V6 Sonata 2006-
G = 1495cc SOHC 4cyl Accent 2000-2002
H = 2656cc DOHC V6 Sonata 2002-2005
J = 1468cc Sohc 4cyl Accent Excel 1989-1994, Scoupe 1991-1992
M = 1836cc DOHC 4cyl Elantra 1993-1995
M = 1795cc DOHC 4cyl Elantra 1996-1998, Tiburon 1997-1998
N = 1495cc DOHC 4cyl Accent 1996-1997
N = 1495cc SOHC 4cyl Scoupe "alha" 1993-1995, Accent 1995-1999
R = 1596cc DOHC 4cyl Elantra 1992-1997
S = 2351cc SOHC V6 Sonata 1989-1991, Sonata 1999-2005
T = 2972cc SOHC V6 Sonata 1990-1998
V = 2493cc DOHC V6 Sonata 1999-2001
The sixth digit of the VDS is a check digit - KMHCF35GXYU000001
0-9 or x, this has no significant meaning.
The seventh digit of the VDS denotes the model year of the vehicle - KMHCF35GXYU000001
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
3 = 2003
4 = 2004
5 = 2005
6 = 2006
7 = 2007
8 = 2008
The next seven digits of the Vin are the Vehicle Indicator Section - KMHCF35GXYU000001
The first digit of the VIS denotes the Manufacturing plant.
U = Ulsan Plant, Korea
B = Bromont Plant, Canada
A = Asan Plant, Korea
H = Alabama Plant, USA
The next six digits of the VIS represent the car's serial number.
By learning to read this we find out the vehicle vin we've been working on belongs to a 2000 Accent base model 3-door hatchback with depowered airbags, 1.5 liter SOHC 4 cylinder engine, and was produced in the Ulsan plant in South Korea.
