Go Back   NewTiburon.com > Information > Do It Yourself > DIY Interior
Reply
Thread Tools Display Modes
#1
TuscaniFX
NewTiburon.com Post Master
TuscaniFX is offline
TuscaniFX's Avatar
Sex: Male
TuscaniFX is an unknown quantity at this point
Old DIY: OEM 8" SubWoofer Modification by sick shift 01-25-2004 , 08:53 AM
Info: This is a quick DIY for fixing the problem with the stock sub...since the factory wired it up out of phase (backwards). This mod gives u better sound and better bass.
Total Time: 5-15 mins...but it really depends on how long it takes you to remove the wires and swap them...
Warning: Your bass will slap the crap outta your ear drums...proceed at your own risk.
Technical Explanation: by 03silvergt
Quote:
From the factory, the way the sub is wired... when the bass hits, the speaker(sub) actually moves towards the inside of the box. This causes the bass to seem as it is "pulling" away from your ears as opposed to the other speakers which are moving outwards and "pushing" the sound towards your ear. As long as all speakers are moving in the same direction, it will sound ok.
Note: (this mod did not work on one tib made in April 2003, we're still trying to figure out why)
Testimony: by BrandNew03Problem
Quote: ...I printed out the diy for rewiring my stock sub on tuesday morning and rewired my sub. Cruised around Tuesday with the astonishingly different bass that was being produced from my stock sub. Tuesday night at 3 a.m. someone busted the drivers side window on my tiburon and popped the latch for my trunk looking for an amp and subs, however the car alarm stopped them before they could get a look inside the trunk to actually see if there was anything back there... So in conclusion, if this doesn't change ur mind about the difference you will here if you rewire ur stock sub, then i don't know what will........
Required Tools:
- socket wrench
- very small flat head screwdriver (1.2 mm bit)
<like the one from an eye glass kit>
Procedure:
* There are 4 bolts that need to be removed...start by removing the top 2 bolts. One is located on the strut tower cover and one is located just behind the tailight.
* Carefully lift the trunk cover and remove the bottom 2 bolts.
* Once all bolts are removed, fold-down your rear seats, then gently lift the trunk cover just enough to remove the sub...if u do it too rough, u can force the trunk cover to snap...
* Once u have the sub out, just disconnect the connector by pressing the release mechanism...
Next, remove the l_l_l shaped thingy from one side of the connector using the screwdriver.
* Then use a flat head screwdriver to get inside the clip between the metal wire connector and the white plastic tab. Then lift the tab and have a friend tug on the wire. Then pull out the right set wires (1 black & 1 green) and swap them. Next, pull out the left set wires and swap them as well. The sound should then fall into place and the bass should start kicking once u install everything back inside your Tiburon. (don't forget to put the "E" thingy back in)
More on How to Remove the Wires
Quote:
....Look into the hole in the lower right hand corner where the metal clip is located. You should see a little plastic tab holding the metal plug in. If u pull on the cord u should observe plastic tab acting upon the metal plug....
- paraphrased from SuperWhiteTib's text
* Use a 1.2-1.3 mm bit screw driver or other sharp pointy metal object... Place this tool in the opening right under the metal plug.
* Once u place the tiny screw driver about half way into that opening, lift or push in the small white plastic tab that sticks out in there and presses up on the metal plug and prevents it from leaving the connector.
* As soon as the tab is lifted or "pushed in", have a friend try and slowly pull that particular wire out.
acknowledgements:
quitlife - the guy w/ the original idea that started the sub woofer fix craze!!
adrock2003 - technical stuff
Mr. Tibb - technical stuff
03silvergt - technical stuff
mines better - technical stuff
SuperWhiteTib - technical stuff
bri2003 - technical stuff
BrandNew03Problem - testimony
stevegel - DIY
ruthnj - DIY
the_tibulator - DIY
jcrm21 - DIY
Original topic:
http://www.newtiburon.com/yabbse/ind...=24082;start=0
Thanks to the original author: sick shift, brilliant DIY!
#2
lowballer
NewTiburon.com Newbie
lowballer is offline
lowballer's Avatar
Sex: Male
lowballer is an unknown quantity at this point
Old 01-26-2004 , 04:48 AM
nice thread, did mine in 15 mins, my car's manu. date may 19/2002 worked.
Speeding
Through the road.
The engine happily revs to six thousand.
But...
As the fourth gear runs out,
The fifth kicks in.
The road will no longer be shared,
It'll be all mine...
**No more street racing! Let's keep the roads safe!
#3
PewpMaster
NewTiburon.com God
PewpMaster is offline
PewpMaster's Avatar
Sex: Male
PewpMaster is an unknown quantity at this point
Old 01-26-2004 , 10:03 AM
worked on my tib, not sure of the date though
#4
03'tiburonz
NewTiburon.com God
03'tiburonz is offline
03'tiburonz's Avatar
Sex: Male
03'tiburonz is an unknown quantity at this point
Old 01-26-2004 , 06:13 PM
I did it! Turns out daylight and a smaller screw driver worked! This mod is highly reccomened!
2003 Tiburon V6 Automatic , Hotshot Headers/Cat, SRI. Wanted! - Borla Exhaust ...If your runnin rice you better think twice
#5
Hawk
Hawk is offline
Sex: Male
Hawk is an unknown quantity at this point
Old 01-30-2004 , 03:29 AM
What a difference! Thanks for the info. I just got my tib Saturday and this was the first thing I've done.
FYI: I didn't have a small enough screwdriver, so I used a safety pin and it worked great.
#6
Pyridan
NewTiburon.com Professional
Pyridan is offline
Pyridan's Avatar
Sex: Male
Pyridan is an unknown quantity at this point
Old 01-30-2004 , 09:17 PM
Just a little more info. The socket needed is a 10mm and I used a large needle when the screwdriver trick didn't work.
I have a few mods, but until I can figure out how to do a good sig I won't waste space listing them
#7
cringe
cringe is offline
cringe's Avatar
Sex: Male
cringe is an unknown quantity at this point
Old 02-01-2004 , 01:19 PM
Couldn't get the wires out so I just spliced and soldered. Worked like a charm!
UPDATE: so played a few songs and whoa! What a differance!
#8
GSilveR
NewTiburon.com Rookie
GSilveR is offline
GSilveR's Avatar
Sex: Male
GSilveR is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-05-2004 , 08:20 PM
did mine last night, made a significant improvement! thanx for the info guys
#9
Carb0n03
NewTiburon.com God
Carb0n03 is offline
Carb0n03's Avatar
Sex: Male
Carb0n03 is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-10-2004 , 07:36 PM
Did mine about 2 hours ago, its so easy. I didn't have a screwdriver handy so i used a throwing dart, worked well. If i ever hear anyone say this is to hard im gonna shoot them lol. Thanks for the DIY btw
gone but not forgotten
#10
sick shift
NewTiburon.com God
sick shift is offline
sick shift's Avatar
Sex: Male
sick shift is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-10-2004 , 10:00 PM
Imagestation probablly took a crap, so I'm gonna see if I can host the pics again with a different provider...
#11
monkman33
NewTiburon.com God
monkman33 is offline
monkman33's Avatar
Sex: Male
monkman33 is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-11-2004 , 05:31 AM
I thought both rear channels were backwards. If that is the case, then the 6x9's are wired out of phase too. It would be easier to remove the dash, remove radio, switch the 4 wires in the actual harness coming off the deck and then put everything back together. This would put all the speakers in phase, instead of the 6x9's fighting the bass still.
Haven't been here in a LONG time........
#12
snapin2ajimkim
snapin2ajimkim is offline
Sex: Male
snapin2ajimkim is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-11-2004 , 09:42 AM
hahahahahaha this is an awesome post! I'm at school and I'm surfing this site and I read about it and I wanna go home, skip all three of the classes (total of 7 hours of class) I have today and just go rewire my sub and sit in my car and listen...
I'm pretty retarded so I think this might be hard for me...hehehehehe
Thanks for the post!
Wish I had all the money in the world to upgrade and modify my Tibby...
#13
snapin2ajimkim
Sex: Male
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-11-2004 , 06:07 PM
hahahaha i rewired the sub...took me about 15 minutes cuz i couldnt find the freakin plastic thingies inside the connector...also took me a couple to realize where the |_|_| shaped thingy was...but all in all it is done...
sounds a little better...i cant say it blew me away, but it sounds better...i think people blew it out of proportion when they listened cuz maybe it was psychological...they knew it would accentuate the bass more so they were specifically listening for it...
anyways i am a happy man even though the difference isnt as great as everyone said it would be...
#14
TuscanGTSpeed
NewTiburon.com Novice
TuscanGTSpeed is offline
TuscanGTSpeed's Avatar
Sex: Male
TuscanGTSpeed is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-11-2004 , 07:39 PM
Thanks for the post, I did this after I got off work today and the sub sounds a hell of alot better!!!
#15
andrew davidoff
andrew davidoff is offline
Sex: Male
andrew davidoff is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-11-2004 , 08:26 PM
just did it myself - bass is noticeably more punchy.
one suggestion as far as taking out the wires, maybe this will help guide other people who run into problems.
if you are looking at the end of the white plug with the clip facing the bottom, you want to put the screwdriver (or whatever you use) on the top of the metal clip and then angle down while pulling on the wire. i'm not advoacting forcing anything, but it it does take a good tug to pull it out. did for me at least.
also, i couldn't find anything suitable so i ended up using a stick pin (like a thumb tack but with a handle) and it worked perfectly.
andrew davidofff
#16
johnanthony311
johnanthony311 is offline
Sex: Male
johnanthony311 is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-12-2004 , 12:24 AM
when doin this should u remove teh subwoofer completly or just the covering or neither
#17
sick shift
NewTiburon.com God
sick shift's Avatar
Sex: Male
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-12-2004 , 12:32 AM
yeah, take the whole sub out, it'll make it a lot easier!
#18
ChosunTiburon
ChosunTiburon is offline
ChosunTiburon's Avatar
Sex: Male
ChosunTiburon is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-12-2004 , 12:36 AM
I just did this mod tonight and I have to say I love it! There's noticable thump in the car and it sounds much more expensive. Thanks for the DIY post. It took me about twenty minutes tops. It just took a while to get the bolts off because I didn't have a socket wrench. It still turned out well and it was worth it. Thanks again. I love it when the car thumps.....
#19
snapin2ajimkim
Sex: Male
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-12-2004 , 11:37 AM
well...this is interesting...cuz i actually used a flathead screwdriver...
looked into the end of the connector and saw the plastic piece...i wedged my screwdriver (it fit perfectly) between the metal wire part and the plastic clamp and used the driver like a lever to lift the plastic thing...after i did that once the wire just slid out...NO TUGGING AT ALL
as i was using the screwdriver as a lever it naturally pushed the metal piece out...maybe cuz the screwdriver has that little slant on it...
my mom won this awesome tool set as a door prize and everything is in that set so i had the screwdriver
#20
Fallout
Fallout is offline
Fallout's Avatar
Sex: Male
Fallout is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-13-2004 , 09:29 PM
good post, I give it an "A"
#21
gsxtuner
NewTiburon.com God
gsxtuner is offline
gsxtuner's Avatar
Sex: Male
gsxtuner is just really nicegsxtuner is just really nicegsxtuner is just really nicegsxtuner is just really nice
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-14-2004 , 03:47 AM
i just changed my two wires to try it and it does make a difference in sound thanks for the info. took me only like 10-15mins to do. and in the end sounds a lot better. even tho i did end up breaking off the very top screw. lmao i was soo mad. owell...DEMBOYZRACING COMING TO THE TRACK SOON ...Reppin' Fredericksburg, VA 22401 JPICK
#22
`sl!m2k4T!b
NewTiburon.com God
`sl!m2k4T!b is offline
`sl!m2k4T!b's Avatar
Sex: Male
`sl!m2k4T!b is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-16-2004 , 03:15 PM
I went out and did this mod today with this post printed in hand and got it done (took me a little longer then I would like to admit) I can't really tell by how much better it sounds - but it does sound better
Anyway the hardest part for me was getting the wires out to swap them - my advice: you have to push pretty hard the plastic bit lies on top of the wire to keep it from moving so you have to wedge your screwdriver (i used a 1.4 mm from one of those precision screwdriver sets) in between the plastic bit and the metal end of the wire pretty hard and lift - it wont be hard to lift it up but it is kinda tricky getting it in there.
All-in-all a mod that is easy to do (first thing I've done to the tib that actually involved a little thinking) and I think the end result is depending on your car.
I have a 2004 GT-V6 and I got a little improvement - your car might get you a lot more.
#23
lowballer
lowballer's Avatar
Sex: Male
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-21-2004 , 10:38 AM
has anyone tried to address hyundai usa/canada about this issue?
Speeding
Through the road.
But...
The fifth kicks in.
#24
STATIC
STATIC is offline
STATIC's Avatar
Sex: Male
STATIC is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-22-2004 , 10:08 AM
I used a tool set that I got for taking a celica GTS for a third test drive. In fact it was the same day I bought my Tib. It was a noticable diffierence but I don't think the warning was necessary.
If you can stay calm, while all around you is chaos...then you probably haven't completely understood the seriousness of the situation.
Never put off until tomorrow what you can avoid altogether.
#25
BACracer
NewTiburon.com Expert
BACracer is offline
BACracer's Avatar
Sex: Male
BACracer is an unknown quantity at this point
Old Re: OEM 8" SubWoofer Modification DIY - by sick shift 02-22-2004 , 04:18 PM
Thanks for the INFO! Just finished working on mine. I immediately noticed the difference, since I had the 'Evenescence' CD in the player. Play the song 'Bring Me To Life', it has some really LOW BASS at the beginning of the song......
.......................................... Bob
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2009 www.newtiburon.com. All rights reserved.
Designed by XG3
