03-05 Tiburon Wiring Diagrams Reference Thread - New Tiburon Forum : Hyundai Tiburon Forums
Go Back   New Tiburon Forum : Hyundai Tiburon Forums > GK Appearance / Audio (03+) > Audio & Security
User Tag List
Reply
Thread Tools Display Modes
#1
playtilithrtz
NewTiburon.com God
playtilithrtz is offline
playtilithrtz's Avatar
Sex: Male
playtilithrtz is an unknown quantity at this point
Old 03-05 Tiburon Wiring Diagrams & Box-Fiberglassing Reference Thread 08-16-2005 , 06:46 PM
These are diagrams for the 03-05 Tiburon stereos and alarm/ remote start systems.
This will help out new members when trying to connect a new stereo, speakers, alarms/remote start systems.
03-05 Tiburon GT w/ Amp (Amp located on rear driverís side quarter panel)
This is for those who install new headunits with the Infinity System. If you have no sound when coming from your speakers, and you know that you connected everything correct, well you didnt. You have to relocate the AMP REMOTE wire on your harness on the aftermarket harness. On the stock harness the AMP REMOTE wire is pin # 12 and it should be White/ Orange. Just move the wire on the new harness and it should work.
Viper 791xv car alarm/remote start wiring diagram is now available.
VIPER 791 Manual
There seems to be some differences in wiring from 02-03 and 04-05 and from auto's to manual. Now the wiring that I have for the alarm system is for the 04-05 manual models.
Here is a site that Rickna found (thanx Rick), the wiring IS different, so please take a look at this, please choose the correct year for your car because the wiring maybe different. 2002 + Wiring Diagrams
BOX Building Websites - Speaker Enclosures - Materials - Types of wood - MDF - Fiberglassing
http://www.lalena.com/Audio/FAQ/Build/
http://www.diysubwoofers.org/
http://www.ajdesigner.com/speaker/index.php
http://www.mp3car.com/vbulletin/arch....php/f-46.html
http://www.the12volt.com/
File Type: doc Viper 791 XV Installation Guide for Tiburon.doc (27.0 KB, 983 views)
RIP Nick Stoliarov (EliteWarMachine) 1/20/87 - 7/11/08
Sponsored Links
Advertisement
#2
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 08-24-2005 , 10:55 PM
BOTH INFORMATION ON POST 1 IN MICROSOFT WORD AND ON POST SHOULD BE THE SAME
Other Useful Wires
Ignition:
12 volts (+) Red
Starter (+) White
Ignition (+) Red
1st Acc. (+) Pink
2nd Acc. (+) Orange
Keysence (-) Blue/Orange
Door Locks
Power Locks Blue or Yellow (BCM) 12 Pin Connector (used to lock and unlock)
Lock Motor Green (BCM) 22 Pin Connector
Unlock Motor Green/Black (BCM) 22 Pin Connector
Lights
Left Parking Light (+) Pink/Black (BCM) 22 Pin Connector
Right Parking Light (+) Green/Orange (BCM) 22 Pin Connector
Parking Lights Blue/Orange (Headlight Switch)
Hazards White (Hazard Switch)
Turn Signal L Yellow/Black (Steering Column)
Turn Signal R Blue/Black (Steering Column)
Reverse Light Gray (BCM) 22 Pin Connector
Door Trigger Yellow (BCM) 22 Pin Connector
Trunk Pin Green/Black (BCM) 12 Pin Connector
Hood Pin Green/Orange (BCM) 23 Pin Connector
Trunk Release (+) Blue (Drivers Side Kick Panel)
Tachometer White (Passender Side Kick Panel) 23 Pin Connector
SPS (Speed Pulse Sensor (Speed Sence)) Brown Wires Data link Connector 3
Brake Wire (+) White Brake Pedal Switch (Behind Brake Pedal)
Parking Brake (E- Brake) (-) Blue/Black (Drivers Side Kick Panel) 15 Pin Connector
Horn Trigger (-) Green/Black Steering Column
Aftermarket Alarms:
In order to make aftermarket Alarm System work with the Anti-theft alarm the vehicle has, disable the stock alarm by unlocking the car with your remote. Make sure this is the last function.
Important Information about Immobilzer in Hyundai's (Remote Start Purposes Only):
USA Hyundai does not have an immobilizer.
Canadian/European Hyundai have an immobilizer. You need to bypass the immobilizer if you want to connect a remote start to your vehicle.
You need to order this part:
Transponder
Part # 556U or 555U
#3
SPLaudio
NewTiburon.com Novice
SPLaudio is offline
Sex: Male
SPLaudio is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 08-25-2005 , 06:25 AM
good post ,sticky...
#4
Spider563
Spider563 is offline
Sex: Male
Spider563 is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 08-25-2005 , 08:57 AM
(Reposted) Dude...... Funny thing is I was just talking to you about this tonight..... and you posted this yesterday...lol. I'm browsing around and I found this thread. I could have used this today!!!!! Cool shiznit......
#5
InkTheFlesh
NewTiburon.com God
InkTheFlesh is offline
InkTheFlesh's Avatar
Sex: Male
InkTheFlesh will become famous soon enough
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-07-2005 , 02:12 PM
Quick question on these diagrams, I can't find anywhere on there that says what the + and what the - wire is on the speakers. I need to get around to putting my speakers in my doors, but I'm unsure what wire is + and what wire is - for the woofers and tweeters.
'09 Silverado Crew Cab
#6
uneakbreed
NewTiburon.com Expert
uneakbreed is offline
uneakbreed's Avatar
Sex: Male
uneakbreed is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-07-2005 , 03:22 PM
great thread man. i suck at electrical stuff and usually defer to my friend. thanks for the post.
#7
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-13-2005 , 11:00 PM
Quote:
from where i was able to take these diagrams they didnt display witch is + and -... sorry man... hopefully I will get around and start figuring more things out.
#8
InkTheFlesh
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-14-2005 , 12:35 AM
Actually, I found my answer through another user, and it was real helpful. The original poster was Viper.
Quote:
Username: Secure
Pass: viper
http://mywebpages.comcast.net/stang...ereo_Wiring.htm
#9
monkman33
NewTiburon.com God
monkman33 is offline
monkman33's Avatar
Sex: Male
monkman33 is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-19-2005 , 01:53 PM
or search for alarm wiring diagram:
http://www.newtiburon.com/forums/sho...wiring+diagram
Haven't been here in a LONG time........
#10
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-19-2005 , 06:23 PM
yea i know thats where i got some of my information, but this is more detailed and in a better format than what you had origianll posted.
#11
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 11-28-2005 , 10:01 PM
All Information On First Post Has Been Updated. Enjoy!!!
#12
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 12-27-2005 , 08:55 PM
#13
Rickna
NewTiburon.com Post Master
Rickna is offline
Rickna's Avatar
Sex: Male
Rickna will become famous soon enough
Old Re: 03-05 Tiburon Wiring Diagrams.. 12-27-2005 , 09:40 PM
Very good job. Easy to understand/follow. I will be needing this soon. Thank you-mucho!
This is how Democracy will die, and with a thunderous applause
#14
Rickna
Rickna is offline
Rickna's Avatar
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 01-01-2006 , 07:54 AM
Here is the Viper 791XV manual for those who might need it-
http://rickna.com/docs/viper_791xv.pdf
#15
SoCalChris
SoCalChris is offline
SoCalChris's Avatar
Sex: Male
SoCalChris is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 01-12-2006 , 02:03 AM
Thanks for these, i been collecting all the electrical diagrams i can for my project.
#16
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 01-22-2006 , 11:34 AM
UPDATE ON VIPER 791XV WIRING FOR TRUNK AND DOOR LOCKS. SORRY FOR THE MISTAKE
#17
junani80
NewTiburon.com Newbie
junani80 is offline
Sex: Male
junani80 is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 01-25-2006 , 10:10 PM
nice thread!! thxs very much!!
#18
bms231
Former CIO
bms231 is offline
bms231's Avatar
Sex: Male
bms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another levelbms231 is on another level
Old Re: 03-05 Tiburon Wiring Diagrams.. 01-28-2006 , 10:24 PM
Thought this would help too..
I am no longer an admin. Please do not PM me with site issues. Use the report post button.
#19
playtilithrtz
NewTiburon.com God
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-01-2006 , 09:58 PM
okay people are going to kill me, but it seems like there are differences in wiring from 02-03 and 04-05. now the wiring that i have for the alarm system is for the 04-05 models.
Here is a site that Rickna found (thanx Rick), the wiring IS different, so please take a look at this.
2002-2003 Tiburons
2004-2005 Tiburons
#20
mikes1979
mikes1979 is offline
mikes1979's Avatar
Sex: Male
mikes1979 is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-04-2006 , 02:30 PM
FYI :
18 Pin Connector Amp (M63-2)
Wire Color Pin #
Woofer Black/Orange 1
Woofer Green 2
Woofer Green/Orange 9
Woofer Black 10
L. Tweeter White 3
L. Tweeter Brown 11
R. Tweeter Black 4
R. Tweeter Yellow 12
FR Speaker Yellow 5
FR Speaker Black 15
FL Speaker White 13
FL Speaker Brown 14
RR Speaker Orange 6
RR Speaker Gray 16
RL Speaker Red 7
RL Speaker Blue 17
I've got a 2003 GT with the amp. The above is what I pulled out of the Speaker Diagram for GT.doc, and it's not matching up to what I've got in my car. Different years? Maybe the speaker and numbers are right, but the colors are wrong? I pulled the 18 pin wiring harness out of the back of the amp and pin 1 is White/Orange not Black/Orange.
#21
Rickna
Rickna is offline
Rickna's Avatar
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-05-2006 , 09:02 AM
There are many differences between 03 and 04/05. Seems that they changed stuff after 03. 04/05 seem to mostly the same. 06 I have no idea. My advice is to get a BCM manual for your year. Matt check your PM's.
#22
mikes1979
mikes1979's Avatar
Sex: Male
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-05-2006 , 09:09 AM
It didn't matter, the colors of the wires were correct even though the pin numbers were wrong. So just remember people, 03 Tib GT's you can USE the document, just disregard the pin numbers and pay attention to the color of the wires.
#23
KillaDan
KillaDan is offline
Sex: Male
KillaDan is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-05-2006 , 04:15 PM
Hey thanks for those wiring diagrams!! Helped out tremendously. I do have a question that maybe you can help me answer. Is there a certain voltage that some of these cd/dvd/mp3 players are looking for when they have you connect a wire to the parking brake?
#24
ohyaa69
NewTiburon.com God
ohyaa69 is offline
ohyaa69's Avatar
Sex: Male
ohyaa69
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-08-2006 , 06:08 PM
Man you know what would be great, if someone wrote up a DIY for the remote start install. The wiring diagram helps a bunch, but some pics would be GREAT!! Just an idea.
#25
Gwang-Ghetto
NewTiburon.com Professional
Gwang-Ghetto is offline
Gwang-Ghetto's Avatar
Sex: Male
Gwang-Ghetto is an unknown quantity at this point
Old Re: 03-05 Tiburon Wiring Diagrams.. 02-11-2006 , 01:07 AM
do i need to purchase a relay for the door locks? i have viper 791
Frnt Motor Mount,RRM Frnt&R strutbars,Progressive Swaybar,Quest coilover,Yaya bushingset,camber kit,SpdFrk LSD insert,Ripp Fly&Clutch,Hotshot headers,Ark Exht,Nology Hotwire,SAFC2,STS
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
