Go Back   NewTiburon.com > Information > Do It Yourself > DIY Exterior
Reply
Thread Tools Display Modes
#1
DoubleD
NewTiburon.com God
DoubleD is offline
DoubleD's Avatar
Sex: Male
DoubleD is an unknown quantity at this point
Old DIY Door Handle Disassembly - swap just handles 01-25-2004 , 09:42 AM
Some people may want to swap just the handles(part you pull on to open the door) with other members to make for some cool mods. So if you want a black door handle on a silver tib heres the DIY. Its pretty easy if you can use a phillips screwdriver and put a puzzle together.
1.) If you flip the handles over once you have them out of the door you will see a large brass pin(2" long). This pin holds one side of the handle in and also holds the spring that retracts the handle. I used a pair of pliers and pulled the pin out. Its kinda tight in there so give it a good pull.
2.) There is also another brass pin on the opposite side of the handle a short one about an inch long. Punch this one out with the end of a screwdriver, this one comes out much easier.
3.) There are 2 screws on the back that hold on the lock cylinder cover(small piece to the left of the handle where you put the key in)just unscrew these and it comes off.
4. The handle should come out easily if you pull the side out where the big pin was in first and then the other side comes out.
Now just put in the other colored handle and reinstall the pins. The most difficult part is getting the big pin back in and getting the spring back to its original position. I used a pair of needle nose pliers to twist the spring back into position and put the pin back in. All in all it was an easy task and took no longer than 10 mins to disassemble.
Always remember you're unique......just like everyone else.
Member since June 19, 2002
05 Bumper Conversion
#2
nisco
NewTiburon.com Unemployed
nisco is offline
nisco's Avatar
Sex: Male
nisco is an unknown quantity at this point
Old Re: Door Handles Disassembly DIY - swap just handles 02-13-2004 , 10:35 AM
THANK YOU DD!
i was trying to figure this out... and you came through
thanks for takin teh time out to do this!
#3
fishinking86
NewTiburon.com Newbie
fishinking86 is offline
Sex: Male
fishinking86 is an unknown quantity at this point
Old Re: Door Handles Disassembly DIY - swap just handles 09-08-2005 , 11:55 AM
dude i have tried to pull that big brass pin out and it is a *****. i was afraid i would break the handle. did you have much trouble?
#4
xpence
NewTiburon.com Rookie
xpence is offline
xpence's Avatar
Sex: Male
xpence is an unknown quantity at this point
Old Re: Door Handles Disassembly DIY - swap just handles 10-06-2005 , 04:08 PM
I am also having trouble with this pin. If there's more to this than brute force it would be nice to know
Xpence 04 V6GT
#5
xpence
xpence is offline
xpence's Avatar
Sex: Male
Old Re: Door Handles Disassembly DIY - swap just handles 10-09-2005 , 12:22 AM
I feel like a tool,this pin ownes me. Im afraid I'm going to do irreparable damage trying to get this thing out. Really burns me up to hear people say they did this in 30 min. I got mine from SR and the pins seemed a little bent to begin with but damn,I'm givin it all I got wit vise grips & sh*t. I noticed some notches on the end of the pin. Is there a specific way to twist those things out or what? Screw it I'll get em out 1 way or another. Just hope it's not as hard to get my OEM handles apart.
Xpence 04 V6GT
#6
TibDave
NewTiburon.com Professional
TibDave is offline
Sex: Male
TibDave is an unknown quantity at this point
Old Re: Door Handles Disassembly DIY - swap just handles 10-09-2005 , 04:47 PM
Quote:
Those pins took me forever to get out. The OEM ones are going to be just as bad too. What worked best for me was to get a really good grip on the end of the pin with some vice grips and rotate the pin back and forth as I was pulling it out. I had to make sure the pin was actually turning though...not just the vice grips spinning on the end. Even doing that, it seemed like those things would never come out but eventually they came free. Good luck with them. Make sure you have a REALLY good idea of how that spring is sitting in there while it's all together. Once you take that pin off, the spring untwists a little bit and it can be a little confusing putting back together if you don't remember how it was.
#7
xpence
xpence is offline
xpence's Avatar
Sex: Male
Old Re: Door Handles Disassembly DIY - swap just handles 10-10-2005 , 12:43 AM
Thanks I really appreciate the response. I'll keep working on those b@stards.
Xpence 04 V6GT
#8
pinktuscani03
NewTiburon.com God
pinktuscani03 is offline
pinktuscani03's Avatar
Sex: Female
pinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud ofpinktuscani03 has much to be proud of
Old Re: Door Handles Disassembly DIY - swap just handles 03-26-2006 , 11:56 AM
if anyone has any trouble or something i am going to sell my BLACK background. It is OEM black paint and I got them from kdm guy. You can pm me....i know ...i know...i am putting this in the parts for sell section too...
Bye Bye 7! Hello...'09 Camaro!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
