Go Back   NewTiburon.com > Information > Do It Yourself > DIY Exterior
Reply
Thread Tools Display Modes
#1
cringe
NewTiburon.com Professional
cringe is offline
cringe's Avatar
Sex: Male
cringe is an unknown quantity at this point
Old DIY: Emblem Removal 04-13-2004 , 11:34 PM
I'm sure most people can figure out one way or another to do this, I just thought I'd share mine since it was quick, easy, scratchless, and I saved my old emblems.
Tools Needs
2 Cable Ties
Windex or other glass cleaner
Hyundai Protection Plan or other similiar membership/credit card
1 rag
Instructions
Getting the Emblem Off
Push the cable ties under the sides of the emblem then tie them off
Then move them around the the circle as far as possible around the top and bottom to get as much glue apart as possible. ending up in the red circles below.
Be gentle with the next step if you want to keep your emblems.
Slowly wiggle each side individually, pulling very lightly on the cable ties. Pull on the left lightly, then pull on the right, back and forth until it slowly separates form the glue. With much patience (although it should take you less than a minute), You'll end up with your emblem fully intact off of your car. You'll end up something like this.
Grab yoursle fsome sort of credit card or other plastic scraper and carefully scrape off a little, spraying periodicly with the windex, or rubbing vigorously with something like this.
Afterwards (hopefully), it looks like this.
Then its just a matter of removing the backing off of the new emblem, and securing into the provided holes. In the end, it should look like this.
#2
JoshGTV6
NewTiburon.com God
JoshGTV6 is offline
JoshGTV6's Avatar
Sex: Male
JoshGTV6 is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-13-2004 , 11:37 PM
hey, nice DIY, but the zip ties are kind of, "harsh". you can use fishing line which will cut right throught adhesive and you can twist it as needed to cut all the adhesive and just lift the emblems off.
#3
cringe
cringe is offline
cringe's Avatar
Sex: Male
Old Re: DIY Emblem Removal 04-13-2004 , 11:38 PM
excellent suggestion
#4
djdub
NewTiburon.com Expert
djdub is offline
djdub's Avatar
Sex: Male
djdub is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-14-2004 , 01:30 AM
Quote:
or dental floss
#5
cringe
cringe is offline
cringe's Avatar
Sex: Male
Old Re: DIY Emblem Removal 04-14-2004 , 08:31 AM
Quote:
Originally Posted by djdub
or dental floss
Outdoorsmen: use fishing line
Computer nerds: use cable ties
Those with good dental hygene: use dental floss
#6
Mcofield
NewTiburon.com Novice
Mcofield is offline
Sex: Male
Mcofield is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-14-2004 , 12:33 PM
My dental floss kept breaking so I switched to thin white string that I found in my garage. Worked much better than the dental floss!
#7
djdub
djdub is offline
djdub's Avatar
Sex: Male
Old Re: DIY Emblem Removal 04-14-2004 , 01:19 PM
Dental floss worked fine for me, maybe you should practice using dental floss on your teeth some time, and then it wouldn't break. Just kidding, It broke on me once or twice but left the car with a fresh minty clean feeling.
#8
`sl!m2k4T!b
NewTiburon.com God
`sl!m2k4T!b is offline
`sl!m2k4T!b's Avatar
Sex: Male
`sl!m2k4T!b is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-14-2004 , 06:14 PM
how did you get the lettering off (tiburon, gtv6)
blowdryer and fingers?
#9
JoshGTV6
NewTiburon.com God
JoshGTV6 is offline
JoshGTV6's Avatar
Sex: Male
Old Re: DIY Emblem Removal 04-14-2004 , 06:22 PM
googone, and precision work with a razor blade. Comes off real quick.
#10
badboyaqua
badboyaqua is offline
badboyaqua's Avatar
Sex: Male
badboyaqua is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-14-2004 , 07:43 PM
i used a paint remover heat gun ... a credit card (the free plastic ones you get in the junk mail) and came right off ... I do recomomed windex to help smooth it and clean the glue.
#11
Jameson
Jameson is offline
Jameson's Avatar
Sex: Male
Jameson is an unknown quantity at this point
Old Re: DIY Emblem Removal 04-15-2004 , 03:30 PM
I would recommend after using something to get the glue off such as googone, wd40, bug n tar remover, windex, etc. that you wash the area well with some kind of car wash soap, dry it really well, and then use a good cleaner wax.
#12
djdub
djdub is offline
djdub's Avatar
Sex: Male
Old Re: DIY Emblem Removal 04-15-2004 , 10:53 PM
Hot sun and some dental floss, sprayed it with some water, came right off including the adhesive.
#13
YoYo
EL NINJA MODERADOR
YoYo is offline
YoYo's Avatar
Sex: Male
YoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud ofYoYo has much to be proud of
Old Re: DIY Emblem Removal 06-11-2004 , 12:32 PM
Are you sure that the Tuscani / 2.7ELISA are in the right place, and where i can order the emblems
#14
niubob21
NewTiburon.com God
niubob21 is offline
niubob21's Avatar
Sex: Male
niubob21 is an unknown quantity at this point
Old Re: DIY Emblem Removal 06-19-2004 , 01:18 AM
Make sure you use Automotive Goo Gone... the regular stuff might harm your paint!
#15
Jameson
Jameson is offline
Jameson's Avatar
Sex: Male
Old Re: DIY Emblem Removal 06-19-2004 , 02:09 AM
Quote:
Is there really a diference? I don't think so. Just make sure to wash the area very well immediately after.
#16
ondrovic
ondrovic is offline
ondrovic's Avatar
Sex: Male
ondrovic is an unknown quantity at this point
Old Re: DIY Emblem Removal 06-23-2004 , 12:23 AM
do the wheel caps just pop off or is there a special trick to getting them off?
Current Mods:
Pioneer 8600 MP, CAI, Memphis 15", Clarion Mono Amp, RRM Front & Rear Strut Bars, Tuscani Emblems, 5% tinit, New Shift Knob, B&M STS, Shift Boot & E-brake Boot, Viper 791 XV Alarm System
Mods Comming:
Angel Eyes, Borla Cat Back Exhaust, Tein Coilover kit, Tuscani Kick Plates, LED Gills, New Pedals, Custom Fiberglass enclouse with 2x 12" Memphis& 1 x 15" Memohis, 2x Memphis Amps, Poineer AVIC-N1, new clutch and flywheel, nitrous, custom interior.....]
#17
03Tib4
03Tib4 is offline
03Tib4's Avatar
Sex: Male
03Tib4 is an unknown quantity at this point
Old Re: DIY Emblem Removal 06-23-2004 , 12:30 AM
Is it the same with the front hood emblem as well?
#18
yg17
NewTiburon.com Post Master
yg17 is offline
yg17's Avatar
Sex: Male
yg17 is an unknown quantity at this point
Old Re: DIY Emblem Removal 06-24-2004 , 01:42 AM
stupid question:
Do the T emblems have pegs or something that go in the holes to get them aligned perfectley? I want to do the T conversion but don't want crooked emblems
2008 Volkswagen GTI 6-speed. Completely stock. Yeah....that's about it.
#19
NoSloppy
NoSloppy is offline
NoSloppy's Avatar
Sex: Male
NoSloppy is an unknown quantity at this point
Old Re: DIY Emblem Removal 06-25-2004 , 12:56 PM
Nice job, looks good.
I just find it interesting that you blacked out your license plate, but your Protection plan card is announcing your full name , VIN number, etc...oh well.
Sure got a nice finish though!...practically a mirror shot of your camera on the Tuscani word shot.
#20
yg17
yg17 is offline
yg17's Avatar
Sex: Male
Old Re: DIY Emblem Removal 07-09-2004 , 02:53 PM
I just put on my T badges, and I pretty much followed the DIY.
First I tried dental floss which got the Tiburon lettering off (i just had to scrape a bit with my fingers) but I couldn't get it to cut through the adhesive on the H and I didnt have any fishing line. So I got a few zip ties and they came right off and I used my fingernails (why didnt I think of using a credit card...lol) and the armor all wipes (they were 4 bucks at WalMart so go get some, great for cleaning windows too) to clean off the rest of the adhesive, then I put the T badges on...looks great
I didn't see any scratches as a result of using zip ties, however, if it does scratch, it will either be covered up by the T badge or buff right out.
#21
blazewan
NewTiburon.com Newbie
blazewan is offline
blazewan's Avatar
Sex: Male
blazewan is an unknown quantity at this point
Old Re: DIY Emblem Removal 07-18-2004 , 04:54 AM
I learned how to remove the emblems off my wheels today. I've heard that you can pop off the 16" wheels emblems, but you have to take the wheels off for the 17"s to get the emblems off. No. You don't. I used the pry bar (that comes with the car)., carefully slid it under the Hyundai emblems (which wasn't hard at all) and it popped right off. The Tuscan i emblems went right in. After I figured that out, it was about two minutes a wheel. I would have taken pictures, but by the time I remembered, I was done!
#22
Elixar
NewTiburon.com God
Elixar is offline
Elixar's Avatar
Sex: Male
Elixar is an unknown quantity at this point
Old Re: DIY Emblem Removal 07-20-2004 , 09:20 AM
I used a spoon, drivers licences, came off easy.
#23
ClintGT
ClintGT is offline
ClintGT's Avatar
Sex: Male
ClintGT is an unknown quantity at this point
Old Re: DIY Emblem Removal 07-20-2004 , 10:49 AM
I tried doing that yesterday, but the sticker came off..... so i just used the air gun and took of the tires... it took 10 minutes to do em..... and about 5 to do the other emblems, using dental floss and a hot Texas day
~Clint
#24
Tabbacchi
Tabbacchi is offline
Tabbacchi's Avatar
Sex: Male
Tabbacchi is an unknown quantity at this point
Old Re: DIY Emblem Removal 07-25-2004 , 08:01 PM
I don't know if anyone else has run into it, but if you're going to remove the lettering, you might find that the paint underneath the lettering is a shade different from the rest of the car. It may just be that my car is yellow, and it stands out more, but if you look close enough you can actually see it spells out "Hyundai".. =( I'll see if I can still see it after a good wash and wax, but I might have to put the lettering back on.
Where did you get the word Tuscani lettering? I have a Tuscani, but it just says Hyundai where you have Tuscani.
#25
theMDkyle
theMDkyle is offline
Sex: Male
theMDkyle is an unknown quantity at this point
Old Re: DIY Emblem Removal 07-26-2004 , 10:17 PM
how did you get your dealership emblems off? just dental floss?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Designed by XG3
