post #15 of Old 10-04-2007, 04:48 AM
TIB16
NewTiburon.com Rookie
TIB16's Avatar
Quoted: 0 Post(s)
TIB16 is an unknown quantity at this point
Re: DIY: BCM Turn Signal Fix
Originally Posted by 2fives View Post
If you just do this mod there will be no need to do any reprogramming??
I just ordered mine ($4) after inquiring at my dealer how much a new BCM would be. About $760.
i did mine and no reprogramming was needed!
anyway,i tried and repaired the oem relay,because the new one would'nt come here before a month passed from the order. so i said why not .i cut the case of it open and i cleaned the inner contacts with a razor blade.(it had something beetween the contacts that forced them to remain closed so the current would go through all the time).then i checked that they work properly,i glued the case back and put everything together.i got the new relay now,but i am not changing it cause the repaired one still works fine.(3 months now)!!!!
TIB16 is offline
