post #17 of Old 10-04-2007, 08:01 AM
NovaResource
NovaResource's Avatar
Quoted: 0 Post(s)
NovaResource will become famous soon enough
Re: DIY: BCM Turn Signal Fix
Originally Posted by 2fives View Post
If you just do this mod there will be no need to do any reprogramming??
I just ordered mine ($4) after inquiring at my dealer how much a new BCM would be. About $760.
Originally Posted by TIB16 View Post
i did mine and no reprogramming was needed!
anyway,i tried and repaired the oem relay,because the new one would'nt come here before a month passed from the order. so i said why not .i cut the case of it open and i cleaned the inner contacts with a razor blade.(it had something beetween the contacts that forced them to remain closed so the current would go through all the time).then i checked that they work properly,i glued the case back and put everything together.i got the new relay now,but i am not changing it cause the repaired one still works fine.(3 months now)!!!!
There is no reason to do this mod if your car is still under warranty. The delership will replace the entire BCM for FREE. The only reason to do this mod is if the warranty has expired.
NovaResource is offline
