in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Information
Hyundai Tech
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
2 of 62
Go to page
Go
62
Combustion falling out, misfire? Check engine light on
Dorian
May 29, 2022
2
797
Jun 1, 2022
by
Dorian
Power window not working
03tibgts
May 22, 2022
1
577
May 29, 2022
by
DamagE
Sourcing a new Driver Front Steering Knuckle 05 2.7L
brileyshugh
May 6, 2022
1
347
May 13, 2022
by
Clarkdl19
Low voltage at mass air sensor
whiteboypattymelt6973
Apr 29, 2022
19
1K
May 2, 2022
by
Yet Another Idle Issue
TGB41
Jun 2, 2018
24
7K
May 1, 2022
by
Scantraxx
Completed a semi overhaul on my 2005 se
Apr 27, 2022
5
670
Apr 29, 2022
by
aveenav
Hyundai oem oil filter
03tibgts
Apr 19, 2022
8
1K
Apr 21, 2022
by
03tibgts
B
Problems after replacing camshaft position sensor
baltimoretiburon
Dec 16, 2015
9
8K
Mar 29, 2022
by
Charlie-III
J
Rattling Noise.. Searched and Searched online
January
Mar 6, 2022
2
914
Mar 8, 2022
by
peachferrari
SRS code B1511
Tibutrauma
Jan 30, 2022
7
3K
Mar 8, 2022
by
Tibutrauma
M
Need help please: Need to identify broken wire in pass. side seat track
Malo
Mar 5, 2022
4
924
Mar 5, 2022
by
Malo
O
Both power windows stopped working on the same time
Or Perry
Sep 13, 2014
11
7K
Feb 23, 2022
by
Avante00
D
What is correct ohms resistance of throttle position sensor on 2003 GT?
denster
Mar 8, 2011
11
33K
Feb 7, 2022
by
tino65
Tiburon 2.0 unlock door relay
Mtan
Jan 21, 2022
0
446
Jan 21, 2022
by
Mtan
P0304 code, cylinder 4 misfiring, unable to fix it. HELP!!!
DanDaTibbyGuy
Dec 23, 2021
2
2K
Dec 25, 2021
by
thijsp
OBD2 Port
chrisev
Nov 20, 2021
3
1K
Nov 21, 2021
by
peachferrari
0
Is your airbag light on?
03_tibby_CT
Feb 19, 2012
26
68K
Nov 15, 2021
by
Ldware9
S
2006 Body Control Module Question
saxman
Oct 5, 2021
3
2K
Oct 6, 2021
by
chase206
Cruise Control Will Turn On But Won't Set
Travis_McCormick
Jun 21, 2021
12
5K
Oct 2, 2021
by
sccarlso
Problem after shortcut aftermarket alarm
Winsis32
Sep 28, 2021
0
892
Sep 28, 2021
by
Winsis32
F
A/C Flickering
Furred
May 30, 2011
12
10K
Sep 23, 2021
by
Sycro5
Will the upper tie bar for a GTv6 fit my 2.0?
Jorgerod305
Sep 2, 2021
4
867
Sep 2, 2021
by
peachferrari
Desperate need for ABS serial numbers
Pulycs
Aug 6, 2021
3
1K
Aug 11, 2021
by
chase206
Maf?
Skarekrowxviper
Aug 5, 2021
3
697
Aug 7, 2021
by
Skarekrowxviper
N
GK FL2 temperature sensor problem
nehm
Jun 5, 2015
3
2K
Aug 4, 2021
by
snakeoilii
Does anyone know why there’s a spot for the abs on passenger but not driver???
Kn9ne
Aug 1, 2021
3
1K
Aug 2, 2021
by
peachferrari
Does anybody know what these plates are called so I can order them??? They keep hitting each other and the shifter gets stuck (5speed)
Kn9ne
Aug 1, 2021
0
757
Aug 1, 2021
by
Kn9ne
J
Speedometer doesn’t work
Josadams223
Dec 10, 2020
9
3K
Jul 28, 2021
by
Miah
T
o2 sensors
Tech39
Mar 31, 2021
2
42
8K
Jul 26, 2021
by
Tech39
Alternator Bolt
hades_the_gt
Jul 22, 2021
2
937
Jul 22, 2021
by
hades_the_gt
S
‘05 SE aftermarket rack & pinion part # verification
sccarlso
Jul 8, 2021
6
599
Jul 16, 2021
by
sccarlso
I need help please
Kn9ne
Jul 15, 2021
1
682
Jul 15, 2021
by
Faulcun
04' Tiburon GT V6 Automatic power steering problem
RachelC
Jun 25, 2021
2
810
Jun 26, 2021
by
RachelC
O
Timing Belt Whine
Ottoelite
Apr 21, 2011
4
3K
Jun 17, 2021
by
RAtib
I
Appalling Gas Mileage
ImPhobia
Mar 21, 2018
40
6K
May 27, 2021
by
James Edward
1
2 of 62
Go to page
Go
62
Hyundai Tech
17.4K
posts
5.2M
views
Vehicle technical problems and service bulletin information
Show Less
Join Community
Grow Your Business
Forum Staff
View All
chase206
Super Moderator
Charlie-III
Administrator
admin
Administrator
Top Contributors this Month
View All
S
Steve 710
chase206
The_Evenger
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
Information
