in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
NEW
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Menu
Log in
Register
Home
Forums
Information
Hyundai Tech
Follow Forum
Create Post
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
2
3
Go to page
Go
62
Next
1 of 62
Go to page
Go
T
Sticky
Official "Check Engine Light" Thread
tiburon_balla
Feb 11, 2005
7
8
9
178
152K
Apr 21, 2019
by
w_phillips95
Sticky
Very useful website
HyundaiCoupe2.7V6
Aug 2, 2016
10
3K
Oct 20, 2016
by
keepinitoldskool
Z
Sticky
SHOCKING!! TSB - What u need to know!
ZLuv7
Mar 1, 2006
2
3
4
61
58K
May 5, 2015
by
chinku
V
Sticky
Submit Complaints to the FTC for Ongoing Alignment Issues
ViperVin
Jan 29, 2007
2
3
44
38K
May 19, 2009
by
JPGreco
2
Sticky
Black Listed Hyundai Dealers
21978121781
Apr 10, 2007
Locked
11
24K
Aug 10, 2007
by
bms231
Sticky
Bulb Guide
YoYo
Aug 7, 2007
Locked
0
22K
Aug 7, 2007
by
YoYo
Sourcing a new Driver Front Steering Knuckle 05 2.7L
brileyshugh
10 d ago
1
87
4 d ago
by
Clarkdl19
Low voltage at mass air sensor
whiteboypattymelt6973
18 d ago
19
269
15 d ago
by
Yet Another Idle Issue
TGB41
Jun 2, 2018
2
24
5K
16 d ago
by
Scantraxx
Completed a semi overhaul on my 2005 se
19 d ago
5
207
18 d ago
by
aveenav
Hyundai oem oil filter
03tibgts
28 d ago
8
198
26 d ago
by
03tibgts
B
Problems after replacing camshaft position sensor
baltimoretiburon
Dec 16, 2015
9
6K
2 mo ago
by
Charlie-III
J
Rattling Noise.. Searched and Searched online
January
2 mo ago
2
212
2 mo ago
by
peachferrari
SRS code B1511
Tibutrauma
4 mo ago
7
532
2 mo ago
by
Tibutrauma
M
Need help please: Need to identify broken wire in pass. side seat track
Malo
2 mo ago
4
312
2 mo ago
by
Malo
Melted BCM Connector
smitty
Jan 16, 2009
6
3K
3 mo ago
by
Tyson4681
O
Both power windows stopped working on the same time
Or Perry
Sep 13, 2014
11
5K
3 mo ago
by
Avante00
D
What is correct ohms resistance of throttle position sensor on 2003 GT?
denster
Mar 8, 2011
11
29K
3 mo ago
by
tino65
Tiburon 2.0 unlock door relay
Mtan
4 mo ago
0
213
4 mo ago
by
Mtan
P0304 code, cylinder 4 misfiring, unable to fix it. HELP!!!
DanDaTibbyGuy
5 mo ago
2
333
5 mo ago
by
thijsp
OBD2 Port
chrisev
6 mo ago
3
468
6 mo ago
by
peachferrari
0
Is your airbag light on?
03_tibby_CT
Feb 19, 2012
2
26
57K
6 mo ago
by
Ldware9
Cruise Control Will Turn On But Won't Set
Travis_McCormick
11 mo ago
12
1K
8 mo ago
by
sccarlso
Problem after shortcut aftermarket alarm
Winsis32
8 mo ago
0
360
8 mo ago
by
Winsis32
F
A/C Flickering
Furred
May 30, 2011
12
8K
8 mo ago
by
Sycro5
Will the upper tie bar for a GTv6 fit my 2.0?
Jorgerod305
9 mo ago
4
343
9 mo ago
by
peachferrari
Desperate need for ABS serial numbers
Pulycs
9 mo ago
3
560
9 mo ago
by
chase206
Maf?
Skarekrowxviper
9 mo ago
3
346
9 mo ago
by
Skarekrowxviper
N
GK FL2 temperature sensor problem
nehm
Jun 5, 2015
3
1K
10 mo ago
by
snakeoilii
Does anyone know why there’s a spot for the abs on passenger but not driver???
Kn9ne
10 mo ago
3
738
10 mo ago
by
peachferrari
Does anybody know what these plates are called so I can order them??? They keep hitting each other and the shifter gets stuck (5speed)
Kn9ne
10 mo ago
0
616
10 mo ago
by
Kn9ne
J
Speedometer doesn’t work
Josadams223
Dec 10, 2020
9
747
10 mo ago
by
Miah
T
o2 sensors
Tech39
Mar 31, 2021
2
3
42
3K
10 mo ago
by
Tech39
Alternator Bolt
hades_the_gt
10 mo ago
2
406
10 mo ago
by
hades_the_gt
S
‘05 SE aftermarket rack & pinion part # verification
sccarlso
10 mo ago
6
359
10 mo ago
by
sccarlso
I need help please
Kn9ne
10 mo ago
1
447
10 mo ago
by
Faulcun
04' Tiburon GT V6 Automatic power steering problem
RachelC
11 mo ago
2
276
11 mo ago
by
RachelC
O
Timing Belt Whine
Ottoelite
Apr 21, 2011
4
2K
11 mo ago
by
RAtib
I
Appalling Gas Mileage
ImPhobia
Mar 21, 2018
2
3
40
4K
12 mo ago
by
James Edward
B
[V6 GK 2003] RPMs get stuck at 3k on neutral gear
b4tmanguy
Mar 15, 2021
10
1K
12 mo ago
by
b4tmanguy
2
07 tiburon v6 6 speed
20dylan07
May 16, 2021
1
616
May 16, 2021
by
chase206
1
2
3
Go to page
Go
62
Next
1 of 62
Go to page
Go
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
Hyundai Tech
Vehicle technical problems and service bulletin information
Show more
17.2K
posts
4.4M
views
Join Community
Grow Your Business
Forum Staff
View All
Charlie-III
Administrator
admin
Administrator
GeneralDuke
Administrator
Top Contributors this Month
View All
chase206
03tibgts
Join now to ask and comment!
or
sign up with email
Home
Forums
Information
