1 - 10 of 10 Posts
I have an 04 GT V6, this morning I went out to start it all lights came on door buzzer worked but no clicking no sound when trying to start.
was out all day saturday in the tib no issues. Sat sunday, then not start this morning.
Discussion Starter #4
Started the car after I got home from work. It started but now i have oil under the car and covering the engine.
First off....AT or MT?
If AT, when it won't crank, try it in neutral.
If MT, could be clutch switch which you can jumper to bypass as a test.
Oil leak......oil fill cap loose? Maybe leaking oil filter? I had a filter rust through the end of the filter. Maybe even a failed oil pressure switch.
Discussion Starter #6
it is the auto tranny
So, how did it start?
Also add info such as miles, recent maintenance. Use some engine de-greaser and check where the oil leak is from.
Check oil pan gasket along with other things suggested above.
Discussion Starter #8
It started normal
Discussion Starter #9
50,000 miles on engine - oil change every 5,000 miles
Discussion Starter #10
Could it be the oil pressure check relief valve going bad?
1 - 10 of 10 Posts
